Grin's weight sensing electric longboards #4 and 5, and kit!
justin_le
Administrator
Staff member
Vancouver
I thought I'd start a new thread for this. For those who aren't familiar I've been a big fan of hands free control of electric longboards where you just shift your weight forwards or backwards to either accelerate or brake the motors. First alpha prototype was completed in 2007, and the plan was always to build an electric board conversion kit around this concept, you know, when all the details were sorted out! The full thread detailing prototypes#0 (alpha), #1,#2and #3 is here and should be read as background:
https://endless-sphere.com/forums/viewtopic.php?f=35&t=49557
Anyways a lot has changed in the world of eboards in the last decade. We always wanted inline wheel hub motors on the boards and had to fabricate them from rotors and stators pulled from ebike and RC motor components, a rather tedious process. Now you can buy a huge range of electric skateboard hubs right off the shelf straight from china. Electric skateboards used to be quite a fringe component of the personal EV scene and now they are all over the news and the startup scene, and in some places all over the streets too. This is all great stuff, and it seems the stars are aligning such that we can finally come through with our 10 year-old plan and encourage a shift towards no-throttle control!
That involves weight sensing trucks suited for hub motors, a dual potted field oriented motor controller, a rugged modular battery pack, and a display/control interface, all of which I will detail in the next few posts.
So on this kit I just bolt the trucks, battery, and controller on any longboard? How much? If its cheap enough I can go for it... but I already have a Raptor2 on the way.
In most of our prototypes we were installing strain gauge sensors on the truck's hanger in order to do the weight detection, as shown here:
file.php
This worked reasonably well, but for production it meant that we'd have to be be in the business of CNC fabricating our own hangers with internal cable routing channels and special flats for the strain sensing etc. Plus the strain gauges on the bottom surface could be prone to damage from impacts, the amount of flex on the hanger is quite low so a high gain amplifier was needed which increased the amount of signal drift and sensitivity, and with inline wheel motors the truck hanger gets really quite hot as it is linked thermally to the motor stator and is actually part of the motor heat dissipation path. This heat would in turn cause thermal drift in the weight signal unless extra special attention was paid to low temp-co electronics throughout.
Then last year we heard about Avenue Suspension trucks and a lightbulb went off. The inside of the curved spring steel suspension provided a protected and smooth surface for the strain sensor, being on the base plate rather than the hanger it was not subject to the heating issues, no special cable routing was needed, and best of all the trucks had suspension! Since the skateboard hub motors have only a thin layer of urethane to absorb impact as most of their diameter is the metal motor shell, they are especially harsh when riding on rough ground compared to normal skateboard wheels.
This shows what it looks like with the strain gauge bonded and connected to the amplifier circuitry, which then folds overtop of the sensor and all gets potted in a silicone rubber:
Now finally we had a
Vanarian said:
Hi Justin huge job done here ! Are the strain gauges responsive enough ? Keep going! :D
Indeed, the strain gauges on the avenue trucks work perfect. There's a lot more intrinsic dampening of the signal as a result of the natural springyness of the material so the noise spikes on rough surfaces aren't as high, but it's still way more than responsive for sensing the weight shift. And unlike the previous versions with the strain sensing on the hanger, we've had no problems at all with signal drift. The zero point seems to stay consistent withing +- 1lb everytime the board is turned on.
Ohbse said:
Super keen for this! Please post as much gritty detail as possible :)
Will do!
The goal for the weight sensing trucks has always been to make them something that anyone could use regardless of whether or not they get the rest of the system from us. They'd be available as a stand alone product for anyone else who wants to experiment with their own weight sensing control scheme, and so for that we have all the signal conditioning done onboard the amplifier PCB so the finished truck has a single 3 conductor cable coming out of it. Gnd, 5V, and Signal.
The signal line sits at ~1V with no weight on the truck and increase to ~4V when there is 200lb of compression. This way electronically it is quite similar to a normal hall effect throttle, and should be pretty easy for people to interface with their own electronics if they don't want to use a Cycle Analyst.
For the motor attachment, we noticed that most of the hub motors from China seem to be standardizing around a 12mm square interface to lock the motor stator against rotation, so we just milled this same shape on the end of the Avenue hanger. The skateboard hub motors are quite a bit wider than the bearing spacing on normal wheels and stick out farther than the truck axle, and to accommodate that we put a threaded hole in the end of the axle so that you can use an M5 bolt to hold the motor on, and use a bolt appropriate for the motor length.
Our target is to get the pricing of the completed truck assembly (suspension base plate + integrated weight sensor + machined hanger) on the order of $90-$100.
From the getgo we've been using the field oriented controllers from ASI for our skateboard projects since they are awesome in all regards for doing high finesse control of EVs.
file.php
However the wiring process of hooking up two separate controllers to the same battery and signal lines was never very clean so we wanted to properly package two controllers into a single effective housing with a single set of plugs. The result is basically a squashed flat version of the Phaserunner with two controllers side by side, sharing a common battery, shunt, and CA plug.
We tried to make it as narrow as possible by nesting mosfet tabs of one controller under the PCB of the other. The finished size is 92mm x 98mm x 24mm. It's not exactly tiny by RC controller standards but it's small enough to be workable under the deck.
We have a daughtboard PCB to combine the signal and power inputs of both controllers and then has inboard MT60/XT60 plugs and convenient pads for the signal wires (hall sensors + CA). And then there is an aluminum heatsink for all 12 mosfets to bolt onto. This heatsink has threaded holes in it so that it can be securely screwed to the skateboard deck from above without much fuss.
And then finally, the whole affair is potted just like the Phaserunner so that there is no concern about exposure to vibration or water ingress. So this is more or less what the finished part will look like. So far we've made one red and one black, and the red definitely looks cooler.
The pricing on this dual controller isn't going to be cheap, probably $375-400 range. We're making it mostly as a high-end option for people, but there's no reason in principle that you couldn't run VESC's or some other controller so long as it allows you to modulatel both forwards and braking torque from a single signal (either 1-2mS pulses or an analog voltage).
The other critical piece to this build design is the control circuit that actually reads the two weight sensor signals and then drives the motor controllers accordingly. We've been using a Cycle Analyst for this since it already has all the signal and sense lines and a mature codebase that is well flushed out for EV's, even if it's not the most modern looking device. What is normally the torque signal input of the CA3 now becomes the signal for the rear weight sensor, while the Aux Potentiometer input line becomes the signal for the front weight sensor.
One issue with the CA is that it's not exactly a compact piece of electronics, and even when we switch over to the original small LCD module it's 84mm x 40mm x 20mm and requires some consideration for mounting. While it looks really nice embedded in the deck with a flush mount of the display as we did in the previous couple builds, not everyone has the means to machine their deck this way so we thought it should be possible to make a rugged CNC'd enclosure that would fit on top of the deck.
Here's our first prototype of that. We made it so that it uses the same bolts that hold the truck in place, and the advantage of locating it under the trucks is that it's easy to have a cable feed through and cavity in the deck here for all the connectors. A cavity that is then hidden by the CA on the top and by the truck on the bottom.
This worked pretty well, but definitely doesn't look as slick as the flush mount, and we found that the snug fitting aluminum enclosure was a prone to accidentally shorting out traces on the edge of the CA's circuitboard giving us some troubleshooting grief, so we later switched that over to clear plastic.
This whole skateboard project could give us some extra incentive to redo the Cycle Analyst board layout to be much more compact, but for now it's what we have and we'll roll with it as is in the initial release. Anyone with an arduino board or similar could also make their own interface circuit to read the weight sensors on both trucks and command the motor controllers accordingly.
The custom skateboard firmware is attached here in the CA3_Skate_FirstBeta.hex file.
Anyone with a V3 Cycle Analyst can load it on their device using the normal software tools. This is still very much beta and based on the earlier 3.0 CA codebase. But with Teklektik doing a ton of great work on the V3.1 CA firmware, I'm hopeful that we can have a more modern variant of the skateboard code in the works pretty soon.
In the setup menu, you'll see that the aux and torque menus are now changed to rear and front weight sensor menus.
The preview shows the voltage on the sensor and the currently scaled weight in pounds. Inside you set the weight offset and scaling factor (which you can easily calibrate by standing on the truck)
There is additional a fault voltage threshold, so if something severs a wire on the weight sensing circuitry it will either get pegged at 0V or 4.5V, while a properly operating sensor will always be in the 1-4V range. This way if there is a sensor fault the skateboard will effectively turn off rather than going into either full throttle or full braking mode.
The control algorithm is quite simple, the code measures the front and rear weighs, subtracts them, and then this difference is added to the throttle output signal. We set things up in the dual controllers so that a 2V signal results in no torque on the motors. More than 2.1V and they have increasing forwards torque, less than 1.9V and they have increasing regen braking torque. The Min Throttle Output voltage is the resting voltage of the CA when either the front and rear sensors have equal weight on them, or whenever there is any kind of fault
The brake output voltage is the lowest output signal the CA will put out, while the max throttle output would be the higher voltage output that the CA will send to the controller for max forwards power.SkateCABrakeOut.jpg
In the control mode setup menu, you set the assist factor in terms of mV / lb. So with 30mV / lb as shown here, and a MinOutput of 1.94V, if the rider has 20lb more weight on the front truck than the rear truck, then the CA's output signal to the controller will be 1.94 + 20lb * 0.03V/lb = 2.54V. Similarly, if they lean back so that there is 35lb more weight on the rear truck than the front, the output to the controller will be 1.94 - 35lb*0.03 V/lb = 0.89V.
We've also included a minimum weight term, so that the skateboard requires the sum of the front and rear weight sensors to be higher than this value for the output to do anything. This then acts as a simple safety to detect if a rider is actually present on the deck or not.
If the weight is less than the Min Weight setting, there's an option with the Vout Min Weight term to have the skateboard apply a small amount of regen braking force on the wheels. That way if you bail at high speeds, instead of the board coasting down the street until it crashes it will effectively have the brakes on and come to a pretty quick stop.
One of the display screens on the CA shows in real time the weights and voltages on the front and rear trucks and it's pretty handy to look at this while testing and experimenting with values.
  • CA3_Skate_FirstBeta.hex
Justin, thanks for the skateboard firmware upload! I have downloaded it for use on the prototype e-assist Rowbike as discussed over on the CAv3 thread.
May I assume I have your permission to become a 'half' beta tester for this project?
I will be using only half of the torque signals (the forward/throttle portion), since I'll be using the traditional regen/brakes system of an ebike for the vehicle stopping duties. We got to this point because a PAS-less CAv3 firmware apparently is the best candidate for meeting my project's needs.
I assume it will become obvious to me to hook my (forward/throttle) torque input to either the CA's standard torque wire, or to go the AUX input route.
My prototype strain gauge amplifier is right at home with the ~ 1-4V signal range, and the "pounds" of torque should also be a realistic unit to use. I'd love to see a schematic of the amp you're using on this version, since it's obviously different than the earlier "Strain4" board you developed -- and which I've also been using for development over the past three years.
Actually, I think you're gonna become a full tester here! You'll hook up the load cell of the rowbike to the front weight sensor (the aux input), and for the rear weight sensor you'll hook up any kind of throttle or potentiometer device to control braking and regen. You can still have the ebrake input line on the brake levers, but you could also just have a thumb or twist throttle and when you turn that it simulates weight on the rear sensor causing the CA's output to go into increasing regen territory for variable braking control.
For the scaling factor, you'll be able to calibrate it so that more or less the lb. display on the front sensor is the same pounds as you are pulling on the handles of the rowbike, so it will be meaningful units. And the data output rate of the CAskate code is 11Hz, so if you log the data with an analogger or laptop you can see the force curve of each rowing stroke with OK resolution, kinda like what they have on the rowing machines at the gym.
Oh it's just the same circuitboard but stripped of the PAS pass thru signals and wiring pads to make it more compact. This way it folds over and sits right over the strain gauge and is then potted in a silicone protection
The process of getting this skateboard kit project worked out has involved 5 key components; 1) the hub motors, 2) the weight sensing trucks, 3) the motor controllers, 4) the control/display, and 5) the batteries
China took care of the skateboard hub motors so we no longer need to do that. The avenue suspension baseplate has made it straightforward for us to produce the weight sensing trucks. Our experience developing the Phaserunner controller for ebikes gave confidence in making a dual version for skateboards that is fully potted for the rigors of being on a skateboard deck. The Cycle Analyst has been something of a given for the control and display device. And then finally, for the batteries, we have the LiGo packs.
These are 36V 98 Wh battery modules detailed here:
https://endless-sphere.com/forums/viewtopic.php?p=1264382#p1264382
[youtube]zjaUeh3jbFM[/youtube]
Our reason for choosing a flat 10s x 1p layout was in part driven by the desire to have a convenient battery option for powered skateboards. It also does allow them to stack well for building up into larger conventional ebike batteries which is a much more familiar market for us, but the skateboard application was always in mind in the design. You can fit 2 end to end down the middle of the deck easily, or 4 packs by having them side by side as well if you wanted a lot more capacity.
Since the batteries are each individually under 100 Wh, this means that when you unplug them it now becomes a device with sub-100 Wh batteries allowing you to take it on a plane. This is one big advantage of the smaller modules compared to having a single 200 Wh or 300 Wh battery. 100 Wh by itself is really not nearly enough capacity to be truly useful, while 200-300 wh is about right (Still light enough to carry easily but sufficient range for 15-25km trips.) Here you see a closeup of the andersons that make the parallel pack connection, and the extra anderson that becomes the charging port.
The LiGo batteries have 4 bolt holes in the corners allowing them to be bolted or screwed to the deck, though some consideration needs to be given if it's a flexible deck to put spacers under ends of the pack so that the deck can bend while the batteries stay mostly flat.
lets see the new setup in action with agressive accel and braking on a rough roads (flat, uphill, downhill)
vid please & tanks
As they say on Route 66, Nice trucks! :mrgreen:
Any update on this? I'd be interested in purchasing a kit to piece together for myself!
Yeah, I suppose if the market has ever ripened and blossomed for this it's definitely now! Neat to see how much electric skateboards have finally taken the fancy of quite a large part of the population.
I brought this board to a booth we had at a university career fair this past Friday since I thought it might resonate with the mechatronic students. Turns out it didn't just catch their eye, a bunch of students had already formed a campus electric board club and invited me out to their first group ride of the year around the Stanley Park seawall!
So that got me to dust it off and have a fun ride on Saturday before we got blanked in snow yesterday.
I'm 4th from the left with the weight sensing board. Most of the other drives were pretty standard RC motor with a belt drive an LiPo battery with either an RC or VESC speed controller.
At this point, we have the weight sensing suspension trucks totally dialed in, and have finally (after testing about a dozen skateboard hub motors) found the one model that hits all our needs. But I'm not so happy with the size of the controllers, and the CA as a control device is a bit bulky for a skateboard application.
So our plan will be to sell the weight sensing trucks and motors initially and hope that others will do a custom VESC firmware to accomodate weight sensors over a remote. Or people can do their own simple control board with an arduino or micro.
Would you guys be interested in that aspect of the kit even if it left the speed controller out of the mix, knowing that each truck just puts out a 1-4V signal much like a throttle?
I love your concept and have been following it's development for many years.
My dream board would be the skateboard equivalent of a pedelec - an electric assisted LDP setup. Check out http://pavedwave.org for the theory behind LDP.
Mark at http://www.gbomblongboards.com has been hard at work over the last few years developing the Torsion Tail. It would seem to me that this design is screaming out for an electric touch.
I would definitely be interested in this. :bigthumb:
Yes for sure, the whole idea of a pumping action instead of a kicking action seems like the ticket for having electric assist on longboards. Above ~20kph there's just a limit to how fast you can swing your leg and still add thrust to the machine.
The weight sensing trucks in this application could then be used to activate a different style of control scheme. Rather than driving the motors based on the weight difference between front and rear as I'm doing now, instead the power output would be controlled by the amplitude of your pumping forces. The weight sensors would be picking up an undulation and the control circuit would look at the difference between the peak weight and minimum weight to determine appropriate motor power.
Thanks for the Torsion Tail tip, I think I'll go order one of these right now actually :)
Now you've got me really excited!
I'd definitely be interested in what you can develop with this concept… it's been far too long since my last board project :D
In the end I didn't get the torsion tail since it means I can't install the avenue suspension trucks but would have to install strain gauges on the torsion tail piece. So I picked up the the smoothstar dolphin cruiser board after watching a few video reviews of different surfskate boards online. What I liked is that it has a high flat deck making it easy to do the battery mounts with lots of clearance, and is decently long so that I should be able to fit 3 LiGos in a row for a good range.
Anyways the board with the special pivoting front truck came in on Friday and I've had my first serious session getting the hang of riding it. Wow, what a totally different sensation for skating and boy do I hope this works out. I was able to make it up about a 3 degree incline with pumping and on the flats it's such a trip to keep propelling without kicking the ground.
It's not clear to me yet that at eboarding speeds (say 25+ kph) the pumping action is still viable for adding human propulsion power gracefully without having a wiggle like a madman.
At those kind of speeds I think you may have to reconsider using traditional geometry trucks and move over to a reverse kingpin setup. Traditional geometry trucks such as the legendary Bennett make for a great front pumping truck with a nice deep dive but can be quite 'squirrelly' at speed. RKP trucks are inherently more stable with a more linear turn progression.
Pumping style (oscillations and power) change according to speed as well - the faster you go the deeper the pump with more power at a lower oscillation. LDP boards can be regarded as overgrown slalom boards, as such wheelbase should generally be set around 30"
