fechter said:There are a few out there already. Maybe good to copy.
https://www.liftfoils.com/
https://www.youtube.com/watch?v=1yEmtz4ZVMM
bbq870 said:what about a jet engine?
high RPM and no need for gear reduction. I think that every additional part eats up efficiency.
would a jet be better? (longer runtime?)
Isham.padron said:Can a trolling motor be converted to operate like an efoil?
What kind of thrust is needed to get you riding and what are the thrust specs on the efoil?
Here is a trolling motor that I found on Amazon. https://www.amazon.com/dp/B00VYP3R82?psc=1
anbat8 said:According to you guys, which electric motor on hobbyking will give the same spec than the epropulsion spirit 1.0 in order to avoid the gearbox (speed reducer) in a construction of a efoil motor?
Thank you,
dirty_d said:I've been toying with the idea of making one of these. I've ordered a kit from http://www.clearwaterfoils.com/ already. I'm going to just use it as a wake foil behind a boat for now. The thing that's holding me back from making an electric one is the gearbox. Even the one that pacificmeister used doesn't look like it was made to handle the power of that motor. I don't think it will last long. I was thinking maybe go direct drive with a small impeller and jet pump, but I think at 20,000rpm or so there would be really bad cavitation.
nanni said:Hi anbat8, have you seen this? http://alienpowersystem.com/shop/brushless-motors/alien-6374-outrunner-brushless-motor-60kv-3200w/
or this? http://alienpowersystem.com/shop/brushless-motors/c80100-outrunner-brushless-motor-50kv-6000w/
