I found this at goodwill for a few bucks; the SLA are probably dead, there's no charger, and the brake handle is missing (appears to have fallen out of the handlebar clamp assembly, which appears intact including the ebrake switch inside it). The throttle looks intact, but wont' know if it works till I get power to it.
Side of the scooter says "100w", has a little brushed motor about 2/3 the length of a dogfood can and about the same diameter. That drives the solid-rubber-tired rear wheel via chain.
The plan is to widen the battery compartment a bit, and replace the SLA with a 7s EIG NMC 20Ah pack; I expect it'll perform a bit better than the original. (as long as it'll fit under the deck; havent' opened anything up yet). It won't likely be any lighter because the batteries will be larger and much higher capacity.
I have a few old RC LiPo packs I could just toss one or two into it with some padding but I'd rather have something that is a bit less fire-prone. (given that these were mostly well-used before I got them and they're getting on a bit in years now, all of them have one problem or another).
It doesnt' have to do much, just move me (or my brother Raine) around, mostly Raine for short trips to the store and such, or to go between places if he takes an Uber somewhere that's also close to other places he wants to go--then it doesnt' have to be left locked up outside like an ebike would, can be taken in with him.
The handlebar doesn't fold up on this one, AFAICS, but I'll fix that; should be easy enough to do, and will make it more portable.
Speculation:
Because of the higher battery capacity (and capability), and the small motor, (and probably small controller), it might be possible the motor or controller could overheat before the battery runs out, on a longer trip. (especially since this thing was made for kids, not 150-180lb adults :lol
If so, I still have a much larger (and less hand-portable) scooter, or at least most of it, that I could use bits of to "upgrade" this one if I had to...but I think I would instead see about using a small brushless hubmotor (like one of the old Fusin 350w geared hubs) to do the chaindrive instead. I also have powerchair motors but those have heavy gearboxes on them that put them in the same (or larger) size and weight as the other scooter motor, so not really something I'd wanna put on this. The Fusin hubmotor isn't as light as I'd like either, but it's much better than the other two options.
Hopefully I won't have to worry about it, but hey, if I didn't think about modifying something before I've even powered it on the first time, I wouldn't be me (or a proper member of ES ). :lol:
Speculation:
