AVIAN featherweight mid drive
Ecyclist   1 kW
Post by Ecyclist » Sep 07 2017 4:14pm
Couple of years back I visited Japan. That trip was mostly about something called 88 Temples Pilgrimage.
Most of people on that pilgrimage are Japanese and majority do the 1400km loop around the Island of Shikoku by foot.
I decided to do it by bike. It was not easy because Japan is mountainous. Double digit gradient roads are very common and some of them are inside of long tunnels. On that trip I met James, a dude from Australia, who suggested to look at the e-bike option.
After coming back to the U.S. I found ES forum, and, after months of educating myself, I decided to build my own e-bike so I can take it with me to Japan and other places in the world. This thread is about that build. I named my build AVIAN because I would like to be able to take this bike on the plane in its own case, my goal is to keep it under 55lb. including the case. My second goal is to have a very light, single track e-bike.
I made some progress that I would like to share with you.
The build is based on a 2009 Giant Trance X0, Alien RC motor and VESC controller. It is not finished, but is getting there.
AVIAN 1
AVIAN 1.JPG (157.08 KiB) Viewed 8324 times
AVIAN 2
AVIAN 2.JPG (139.16 KiB) Viewed 8324 times
AVIAN 3
AVIAN 3.JPG (161.31 KiB) Viewed 8324 times
Don't expect from life to be easy and then it will be.
My builds:
Avian with hypocycloidal drive https://endless-sphere.com/forums/viewt ... 2#p1318056
2016 GNG extreme drive https://endless-sphere.com/forums/viewt ... 28&t=82252
MadRhino   100 GW
Re: AVIAN featherweight mid drive
Post by MadRhino » Sep 07 2017 7:43pm
Neat mounting. Looks good.
Small motor, how much power?
Battery is alway a problem when you plan to fly (double meaning) :wink:
What are your plans?
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
Ecyclist   1 kW
Post by Ecyclist » Sep 07 2017 8:42pm
MadRhino wrote:Neat mounting. Looks good.
Thanks.
It is a 3200W motor but I'm not going to push it over 2400W. BTW I can install up to 8072 6000W motor to that reducer and pull that bike apart. Just don't feel like doing it yet. 500/14 Rohloff might not like it either.
I already designed solder/spot welder free case and am planning on buying 18650 cells at destination or ship cells by sea and pop them in.
Battery pack 1.JPG (143.02 KiB) Viewed 8292 times
Hex cell 2.jpg (83.94 KiB) Viewed 8292 times
My builds:
12-C   100 W
Post by 12-C » Sep 07 2017 9:15pm
Beautiful build!
Really nice work with the battery setup!
I'm guessing you have access to a mill ? :D
Ecyclist   1 kW
Post by Ecyclist » Sep 07 2017 9:22pm
12-C wrote:Beautiful build!
And then some. :D
My builds:
flathill   100 kW
Post by flathill » Sep 07 2017 10:02pm
Cool battery pack!
Are the holders/connectors made of aluminum? If so what about oxidation? Aluminum oxide is a insulator. I guess you could sand before assembly and hope it stays air tight...
Maybe you know this and they are nickel plated copper? :)
Wolfeman   100 W
Post by Wolfeman » Sep 07 2017 10:53pm
Wow, just freakin wow.....
Trek 4300 w/ H3580 Crystalyte at 3600W
https://endless-sphere.com/forums/viewt ... =3&t=82738
Worksman Mover M2020-3CB w/DD 750W front hub
https://endless-sphere.com/forums/viewt ... =3&t=96873
Dyno Moto 7 BMX Cruiser w/BBS02
https://endless-sphere.com/forums/viewt ... 1#p1467001
ScooterMan101   1 MW
Post by ScooterMan101 » Sep 08 2017 12:57am
Great Work,
I have had the same Idea for about a year or so now, I just do not have the Machine Shop to do this myself.
( I Bought a Frame a year ago but just got around to building it up, since I finally see some improvements in regards to DIY Mid-Drives )
I have been wondering how to use a RC motor with a Infineon or Infineon Clone Controller, so as to use a Cycle Analyst to do easy Voltage and Amperage Limit's .
Would that motor work with an Infineon controller ?
What is the KV of the Motor ?
Are you going to be operating it with 5s pack or 10s pack, ... or is that a 6s x 10p Pack ?
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
Rube   100 W
Post by Rube » Sep 08 2017 4:52am
Wow, amazing work. Your battery construction deserves its own thread. Interested to see how you mount the pack. Any lessons or thoughts about your battery design? Would you change a future iteration? cheers
Ecyclist   1 kW
Post by Ecyclist » Sep 08 2017 10:01am
flathill wrote:Cool battery pack!
Thanks!
Yeah, these are aluminum and earmarked for electroless nickel plating.
My builds:
Ecyclist   1 kW
Post by Ecyclist » Sep 08 2017 10:03am
Wolfeman wrote:Wow, just freakin wow.....
Thanks dude. You made my day.
My builds:
Ecyclist   1 kW
Post by Ecyclist » Sep 08 2017 10:11am
ScooterMan101 wrote:Great Work,
I recommend VESC or RC controller for a RC motor.
The motor is 125Kv.
My builds:
Ecyclist   1 kW
Post by Ecyclist » Sep 08 2017 10:28am
Rube wrote:Wow, amazing work. Your battery construction deserves its own thread. Interested to see how you mount the pack. Any lessons or thoughts about your battery design? Would you change a future iteration? cheers
Thank you.
You need to be really careful with these cells. Steady hands or welding goggles are at premium. 8) :D
This is my third rev. and I think that for 6P it will work OK.
After I install it on the bike and put it through real life situations I will be able to tell more.
For now I only used it for testing the motor with my transmission on a fluid exercycle.
I will build more compact 4P for single tracking and short range.
My builds:
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Sep 08 2017 12:02pm
Umm... I'm really glad that I clicked your link. Wasn't sure what to think based on the name and TOTALLY did not expect to see that battery setup.
I would absolutely love to hear anything you would care to share about the construction, design and manufacture of that beauty.
Seems like you may have also designed your own motor mounting as I have never seen one of those on offer before.
Subscribed in the hopes of learning more about your creations!
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
Ecyclist   1 kW
Post by Ecyclist » Sep 08 2017 6:11pm
cal3thousand wrote:Umm... I'm really glad that I clicked your link. Wasn't sure what to think based on the name and TOTALLY did not expect to see that battery setup.
I'm glad you did.
It would be very hard for me to write about everything I build. I doesn't look like much, but just the transmission was a big project in itself. So if you have a specific question, just shoot it my way and I will do my best to answer.
You are correct about the motor mount. Giant bikes have goofy rear shock linkage so I had to come up with something that works. That was the price I was willing to pay in order to have ample space in a triangle of the bike. I can fit everything in that space. These brackets are very short. Short mount makes for a very rigid structure.
My builds:
ScooterMan101   1 MW
Post by ScooterMan101 » Sep 08 2017 6:25pm
Is that regular bicycle chainring on the outside of the crank that has the chain to the motor ?
Regular bicycle sprocket on the motor ?
8 or 9 speed chain/chainrings and sprocket up front ?
Ecyclist   1 kW
Post by Ecyclist » Sep 08 2017 6:44pm
ScooterMan101 wrote:Is that regular bicycle chainring on the outside of the crank that has the chain to the motor ?
No, these are BMX 7075 aluminum chainrings. Both are 104 BC. The outside is 42T and inside 44T. The transmission is running 20T right-hand EXCESS freewheel with backing plate.
My builds:
sephespid   100 µW
100 µW
Post by sephespid » Sep 14 2017 12:20am
Wow, amazing. subscribed
It looks like bobc's lazer cut cycloidal gearbox. I need this type of gearbox. Compact and simple.
But I think there is a problem of protecting the motor from water or mud.
anttipaa   10 W
Post by anttipaa » Sep 14 2017 5:02am
Wow this looks very good. Are you going to sell those gearboxes? How much does that gearbox weight?
Canyon Torque DHX + Cyc X1 Pro
Rouckie   10 W
Post by Rouckie » Sep 14 2017 6:23am
I'm also very interested in the gearbox. Could you show some more details of the internals? Is it something I could duplicate (I also have a cnc).
thank you
SlowCo   100 kW
Post by SlowCo » Sep 14 2017 8:51am
Subscribing to see if you'll share more on the internals of the gearbox as well. Great little machine!
Ecyclist   1 kW
Post by Ecyclist » Sep 14 2017 7:49pm
I designed and built the hypocycloidal transmission based on three different Sumitomo transmissions that I bought and studied. Sumitomo makes industrial type of transmissions, which are not restricted in size and shape. I had to rethink the whole thing for the bike use.
@SlowCo Next week I will have some free time and I will take the transmission off the bike, weigh it and take a couple of photos.
Below, I posted a photo of the first revision of my transmission. The one on the bike is rev.3.
@Rouckie You will need CADCAM and second software to design cycloidal shape. From what I understand, you can use Solidworks for everything but it is very expensive.
@sephespid If you cut cycloidal shape with laser, you will get a rattle box. Sumitomo uses profile grinders to get a perfect shape. CNC milling is barely acceptable. I'm not worried about the motor too much. E-sk8s have these motors mounted couple of inches off the ground and can live with that. Worst case scenario, I will swap it with Astro Fight inrunner. No problem.
@anttipaa At this point my focus is on building mid power super light e-bike for myself, but I might make a short run of 10 to 20 units once I get positive singnals from the community. The time will tell.
Hypocycloidal transmission rev.1
Trany 1.JPG (135.58 KiB) Viewed 7812 times
My builds:
Amiran   10 W
Post by Amiran » Sep 14 2017 10:20pm
Crazy stuff.
Great thread.
Mongo1   10 mW
Post by Mongo1 » Sep 15 2017 12:01pm
Brilliant work!!!
neptronix   100 GW
Post by neptronix » Sep 15 2017 12:15pm
That is cool as hell. Too bad it's a one-off.
