Allex
Offroader said:Ap0fls, that is interesting with the heat. Are you 100% sure you are pushing the same phase amps?
Do you have OVS set the same on both controllers? OVS really overheats the motor. Does Sabvotan have OVS?
What about PWR setting, this makes a huge difference in acceleration and how powerful the motor feels, I assume this means it causes more heat. Is this set the same on both controllers?
I would compare both bikes for how the power feels, or dyno the bikes or something.
There is a chance that the adaptto could be running the motor with more power that is causing it to heat more.
PWR can make a huge diff yes. And also the other two. Keep in mind that this controller may overshoot the current by a lot. When I set my midi-e to 120A it spikes to 147A!
