It's windy outside. Gusts of 40+. At least it's not raining or snowing. I got to take out the Currie on the ASI today. It's set up with no field weakening and current set like on the PV 12 fet controller. I haven't used the ASI controller on an actual EV before, just for bench testing. I've never tried a torque throttle before. Frankly, I couldn't tell it was dramatically different from a speed throttle. The biggest difference I noticed was that low throttle was less harsh than the speed throttle. Since torque is the defining factor, at low throttle, the motor is a bit weak and at more throttle, it gets stronger. This makes for a gentle start. A speed throttle is full torque all the time so it makes for a harsher start up from a dead stop.
So then, onto the actual test ride. The motor sounded virtually identical to the straight sinusoidal controller. I couldn't tell any sort of acceleration difference. The only difference I could detect from riding was that my top speed was a bit higher. 42 on the PV controller and 43 on the ASI controller. Since it has a higher eRPM than the PV controller it will definitely run the C80100 at up to 82 volts, while the PV controller limited at 50,000 eRPM won't run it at that voltage. In either case the motor pulled strong all the way to full speed. After riding around a little while, I then started having a power drop off. I put my hand on the bottom of the controller and it was quite warm which was surprising since it's 60F outside and the PV controller gets to 85F after several miles of hard riding. I hadn't ridden 1/2 mile continuous. After the controller cooled down, I had full power again.
I then was developing a new problem. There was this ticking sound coming from the back end. I stopped, looked over the back end, couldn't see anything, rolled the back wheel around a little. Everything was smooth so I got back on and road some more. The ticking sound got more and more pronounced and then the back wheel got bumpy. I stopped and checked over the back wheel again and found this. Needless to say, the ride was then over and I essentially drug the scooter home a couple of blocks.
My guess is that the tire was over pressure, but it says right on the side 55psi and I was running at 55psi. I have a couple more tires of the same size and they too say they are made by Hua Jian, but they are rated to 40psi and the labeling on the side of the tire is different. Is one set fake?
