Battery Advice Needed For Middle School Competition
- DrkAngel 100 GW
Re: Battery Advice Needed For Middle School Competition
Sonas @ $150 per 100 cells = 4 x 24 cell battery builds
A little learning is a dangerous thing;
Drink deep, or taste not the Pierian spring:
There, shallow draughts intoxicate the brain,
And drinking largely, sobers us again.
I enjoy enlightening ... and enlivening the spirit of the innovators.
New & Improved - Acronym Definitions
Index - Homemade Battery Packs - Updated - February 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
OMG, you should see what I get when Googling this!DrkAngel wrote:Sonas @ $150 per 100 cells = 4 x 24 cell battery builds
Can't seem to find Sonas lipo's on-line...
- DrkAngel 100 GW
Can't confirm Sona cells as 2000mAh ...BlueBell wrote:OMG, you should see what I get when Googling this!DrkAngel wrote:Sonas @ $150 per 100 cells = 4 x 24 cell battery builds
Not sure of replacement candidates.
Need:
180Wh ÷ 3.6V cells = 50Ah
12s2p (≤ 2080mAh cells) 43.2V 2000 or 2050mAh
13s2p (≤ 1923mAh cells) 46.8V
14s2p (≤ 1785mAh cells) 50.4V best ... if available
15s2p (≤ 1666mAh cells) 54V 1650mAh cells max recommended
16s2p (≤ 1562mAh cells)57.6V
180Wh ÷ 3.7V cells = 48.64Ah
12s2p (≤ 2026mAh cells) 44.4V
13s2p (≤ 1870mAh cells) 48.1V best ... if available
14s2p (≤ 1737mAh cells) 51.8V
15s2p (≤ 1621mAh cells) 55.5V 1600mAh cells max recommended
16s2p (≤ 1529mAh cells) 59.2V
Reputable possibilities:
Lipo ...
- DrkAngel 100 GW
Hobbyking!
11.1V 3200mAh Turnigy LiPo - $20
3s 11.1V x 3.2Ah =35.52Wh x 5 = 177.6Wh
15s LiPo 55.5V 3.2Ah = 177.6Wh
3s 11.1V 4000mAh LiPo
3s 11.1V x 4.0Ah = 44.4Wh x 4 = 177.6Wh
12s LiPo 44.4V 4.0Ah = 177.6Wh
DrkAngel,
I'm really starting to feel like an idiot here.
Not really sure what you're trying to beat me over the head with.
It looks like four different battery options...?
Is that right?
Is the C-number relevent here or are they all the same?
Knowing our requirements, is there one combination you would recommend over another?
If it's all the same then I would think the fewer number of pieces the fewer connections we'd have to make.
And what about charging?
The IMax B6?
Does that go between the panels and the battery?
What A/C charger were you thinking of or should we just use the panels leading up to the race?
I'm starting to get discouraged here, it seems like I'm missing something... something obvious.
<sigh>
Is that right?
The IMax B6?
<sigh>
- DrkAngel 100 GW
Sona 18650 cells may not qualify due to lack of documentation-verification of capacity.
2 different Lipo possibilities.
Higher C rate provides less sag but very high C rate tends to sacrifice reliability-durability.
Under your planned discharge C rate will be less than 3 C, so possibly 20-30C might be optimal.
iMax B6 is for testing, charging and balancing (equalizing) individual 3s LiPo, 4 individual charges for 3s LiPo packs.
Use panels to "top off" battery.
I recommend the 4 x 4000mAh as best choices. 5 x 3200mAh pushes charged voltage to 63V which is the probable controllers capacitor rating-limit. I don't recommend pushing to limit.
High Ah trades off Discharge in 18650 format, so 3.5Ah is the highest these days, best guess is 10A discharge. But them 2.0-2.5Ah's can get 25A-30A discharge.
I have not looked at pouches or other formats.
I know it takes a lot of energy to get the prop started
So what is the amp draw of the controller and add a few ? So 12s 2p of Samsung 25r cells 25amp cell. Price is going down. Maybe 3.75- 4.00 usd each.
"Sona 18650 cells may not qualify due to lack of documentation-verification of capacity."
Yes, you hit the nail on the head there.
They require documentation of battery specs.
Max 180 Watt-hours
Not sure which Turnigy 4000 you meant.
This one: https://hobbyking.com/en_us/turnigy-bat ... xt-60.html
How will we ensure 25 minutes out of this set-up?
If we fall short by even 20 seconds we are disqualified!
"I know it takes a lot of energy to get the prop started"
Not really, especially considering the high torque of electric motors on start up.
It takes considerable more power at speed, ~8 - 10 knots ( ~4.5 m/s ).
Max 180 Watt-hours
- DrkAngel 100 GW
Not sure on the 4Ah RC LiPo.
1. Median C rate, (20-30C for better consistency-reliability)
2. good brand name. Ask others about "good brand name".
Watt meter has watt function.
... think I figured this for you already ...
Keep throttle positioned for determined watt usage (400W?) battery output.
Important to test drive before actual race.DrkAngel wrote:2. Watt-watt Hour meters are fairly accurate and inexpensive. If a throttle is used, maximum safe battery output can be regulated fairly precisely!
180wh x 60/25 min = 432w
Should maintain 400w+ battery output for 25 minutes
Ah, yes indeed, you did show me that, thank you and my apologies for overlooking it.
I've just read through the thread a few times and believe I'm getting a firm grasp on reality, finally.
So, 25C constant with 50C burst isn't okay?
You pick one.
You pick one.
- DrkAngel 100 GW
Either look good!
If budget allows, might recommend 2 sets of batteries or at least 1 spare, in case of accident or failure?
Graphene is newer tech with greater reputed lifespan.
Yes, we are advised to have a second battery in case of poor weather and the solar-only heats will run on battery instead.
But I thought you didn't like the first one, the HobbyKing R/C one.
Graphene you say. Perhaps that has something to do with the differing three letter abbreviation associated with the different lipo listings.
Come on, stick your neck out and recommend one... please.
Or your two top picks, then you're not on the hook.
Is the heavier battery, of the same rating, the better way to go?
Thanks again.
Thanks again.
- DrkAngel 100 GW
Lol, ok, graphene it is... even though it's lighter.
With them RC lipo its just like lego, you plug whatever you want together, making sure to pay very very very very close attention to what you are doing. Buying or making a parallel adapter, I used a 5.5mm connector with 10awg that split into six 4mm 12 or 14awg wire, then I bought some 5.5mm bullets and some wire to solder the main wire. Its pretty simple to learn. Then you got to take care in charging and discharging. One day I will buy LiPo again.
Did you mean it takes a lot to get the motor going?999zip999 wrote:I know it takes a lot of energy to get the prop started
I've been told we may have a problem when running on panels only getting the motor turning due to it's high start-up draw. The panels may drop below the min voltage cut off in the controller.
DrkAngel,
I noticed the upper limit on the motor controller is 42.5 +/- 0.5 Volts.
Is this going to be a problem at 44.4V?
This is printed on the controller, the spec sheet differs, same for LVC.
- DrkAngel 100 GW
... Edited!
Better contact seller to confirm!
States 36-48V capable! ... ?
Very often 36V controllers have no HVC (High Voltage Cutoff) 42.5V might be hypothetical?
42.5V upper limit would be bad for 44.4V or from panels!
~31V LVC with 44.4V ≥ 50.4V charged capability required.
... Edited!
42 volt is 10s fully charged.
Ok srill guessing 42v fully charged x 42,000mah equals 176 wh ?
- DrkAngel 100 GW
Volts x Amps = Watts
Volts x Amp hours= Watt hours
V x Ah = Wh
"V" (Volts) is based on the average discharge voltage during a full discharge.
EG. 4.2V >> 3.2V MFG rated @ 3.7V
Wh is based on Ah x V averaged
Wh is rated at mfg rating of average voltage at modest discharge rate 11.1V (3x cell 3.7V) x mfg rated mAh (4000mAh) = 44.4Wh
(12s) 44.4V x 4Ah = 177.6Wh (180Wh limit)
edited previous post ... clarified expanded.
V x Ah = Wh
Aren't we stuck at 42.5 volts because the upper limit of his controller or 10s ?
Can we pick the direction of rotation on this motor or is it predetermined?
We are proposing to thread an aluminum tube onto the shaft threads of the motor.
If it turns counterclockwise, it will tend to unscrew our propeller shaft!
- DrkAngel 100 GW
Youtube search shows motor turns clockwise, facing gear.
BM1418ZXF(BLDC)
Brushless motors, typically, are not reversible, without special controller.
BM1418ZXF(BLDC)
