Sur-Ron - New Mid drive Bike
madin88   1 GW
1 GW
Re: Sur-Ron - New Mid drive Bike from China
Post by madin88 » Nov 29 2017 2:32pm
FlightService wrote:
Nov 29 2017 2:04pm
Nah. My degree from a top 30 Engineering School in Mechanical Engineering, 10 years of Engineering experience and http://ffden-2.phys.uaf.edu/211_fall201 ... urBar.html all disagree with you.
It's still a 4 bar linkage
On a 4-bar the swingarm is splint into chain stay, seat stay and rocker as you can see.
By doing so the virtual pivot point can be moved far forward to prevent squat during braking or pedal bob.
I am no expert, but doesn't the Surron have a fixed pivot point?
FlightService   100 mW
Post by FlightService » Nov 29 2017 3:30pm
(all caps added for emphasis on possible confusion points)
madin88 wrote:
Nov 29 2017 2:32pm
On a 4-bar the swingarm is split into chain stay, seat stay and rocker as you can see.
The rear SUSPENSION of the diagram above is the swingarm, upper A-arm, rocker arm, frame (not shown, but is the base of the system) and shock. The wishbone is just the bracket that attaches the rocker arm to the swing arm and is considered part of the swing arm. So the rear SUSPENSION SYSTEM 4 bar linkage is the swingarm, upper A-Arm, Rocker arm and the frame. The shock dampens the motion and suspends the weight yet doesn't dictate directional motion (if they did the math right, if they did it wrong they shock won't last long which is why I think in another pick the shock to rocker arm had another link).
madin88 wrote:
Nov 29 2017 2:32pm
The attachment of the SWING ARM to the frame is a fixed point arrangement. The swing arm IS NOT the entire suspension system. Just one part. There are 4 bar linkage SWING ARM setups out there, the SunRon isn't one.
But this is a 4 bar linkage SUSPENSION setup. The swing arm, on it own, is a single point arrangement, as is the upper A-Arm, on its own.
So you are correct in the SWING ARM being of a single point type, but the REAR SUSPENSION SYSTEM is a 4-bar linkage. It's the difference in saying that the rim is the wheel vs saying the hub, spokes and rim is the wheel. You are referencing a particular part of the entire system, instead of the system as a whole.
I hope this helps clarify.
Now if you really want to bake your noodle, look up Honda's Unit ProLink rear suspension used on their MotoGP bikes. The entire rear unit is held on with two bolts. The shock compresses against the suspension set up and NOT the frame.
Engineer: (n) en·gi·neer \ˌen-jə-ˈnir\ -Someone who does precision guesswork based on unreliable data provided by those of questionable knowledge. (See also: wizard, magician, miracle worker)
motomoto   1 kW
Post by motomoto » Dec 04 2017 12:41pm
Finally got some video.
devo1223   100 W
Post by devo1223 » Dec 04 2017 2:10pm
cool. what were you racing the last half,an 80cc? How long is your battery lasting at that pace?
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
madin88   1 GW
1 GW
Post by madin88 » Dec 04 2017 2:29pm
fantastic vid^^
It brings a lot of appetence for riding on such tracks :)
Drum   100 W
Post by Drum » Dec 04 2017 2:51pm
That's quite impressive performance on a motocross track, considering it isn't really being marketed as a motocross bike. Obviously the suspension is doing its job ok, and there is quite a bit of power. I'm keen to see how it will go on singletrack and semi-trials riding.. hope you get a chance to ride it in varying terrain, and get video / post reports.
motomoto   1 kW
Post by motomoto » Dec 04 2017 7:26pm
It was an 80 or an 85. I think 7 laps was 25% battery use at full pace.
Trail riding and single track would work great with this bike. I would watch it on the long steep climbs as it would
overheat. It's happened to me twice where something cuts the power in half suddenly. It's either the battery, BMS or the
controller. The motor is always barely warm when the power cuts out.
I am super impressed with the performance. It handles great but isn't as cushy as a motocross bike with only 8" of suspension
vs 12" on a full sided bike.
SlowCo   100 kW
Post by SlowCo » Dec 04 2017 7:32pm
Great video!
Seems to me that the simplest solution to combat the overheating is to gear the bike down a little. A 1 tooth smaller front sprocket might be enough?
motomoto   1 kW
Post by motomoto » Dec 05 2017 11:19am
Great video!
I was thinking the same thing. For that track a 10% change would make the bike faster out of all the turns and not hurt the top end speed.
A guy sent me some video of me that day.
fechter   100 GW
Post by fechter » Dec 05 2017 3:16pm
motomoto wrote:
Dec 04 2017 7:26pm
That sounds like the controller. That should be easy to fix or at least improve on.
Merlin   10 MW
Post by Merlin » Dec 05 2017 6:55pm
great video.(s)
and for what it is, really nice performance.
still looks very tiny...how tall are you?
motomoto   1 kW
Post by motomoto » Dec 05 2017 8:48pm
I'm 5' 11" and 180 lbs.
sn0wchyld   1 MW
Post by sn0wchyld » Dec 05 2017 11:55pm
fechter wrote:
Dec 05 2017 3:16pm
motomoto wrote:
Dec 04 2017 7:26pm
I suspect that like the other golden motors the heat path is very poor, so unless your talking about the actual winding temps it could be that the inside is cooking while the outside is still only warm - ie might be a issue with the motor rather than the controller.
motomoto   1 kW
Post by motomoto » Dec 06 2017 11:53pm
You are right, it does have lousy heat conduction from the coils to the outside.
3000 golden inside.jpg (110.85 KiB) Viewed 2867 times
motomoto   1 kW
Post by motomoto » Dec 07 2017 9:18am
Does anyone have any suggestions for a better motor to replace the 180 mm diameter Golden motor?
macribs   1.21 GW
1.21 GW
Post by macribs » Dec 07 2017 10:47am
The HPM-10KW from golden motor? Water cooled good for 20 kw peak.
motomoto   1 kW
Post by motomoto » Dec 07 2017 2:13pm
Wouldn't fit. Need something more power concentrated with 180 mm diameter maximum size
dirkdiggler   10 kW
Post by dirkdiggler » Dec 07 2017 2:32pm
Ask Skeetab how the Denzel 7.5 kw motor is working for him. I don't know if he ever said if it was worth it or not. They are smaller than 180mm for sure.
http://www.eastgem.net/d7500.html
Plus they are only $320 shipped.
Are you really tearing the bike down already? Your video seems like the bike works very well for what it is. I guess the problem with most of us here, you always think things could be better. My wife tells me I have a problem with that, too.
I pushed out my purchase of the bike till Spring as its too cold to ride for me here. They weren't quick enough to get it to me in the Fall.
JuiceMeUp   100 mW
Post by JuiceMeUp » Dec 07 2017 3:57pm
Could you use the Ferro-Juice (Transmission Fluid) that the hub guys are using?
Or is the frame of this motor wide open.
Drum   100 W
Post by Drum » Dec 07 2017 5:54pm
Re: Motor cooling.
I remember a Russian guy saying that fitting forced air cooling to a Cyclone motor made a huge difference to how hard / long he could ride before temperature rise became a problem.
From your photo it looks as though there is a bit of room for air to circulate around the windings, so it might be worth a try cutting 2 holes in the case of the motor, fitting a small 12V centrifugal fan and duct its output to one of the holes.
I haven't seen the motor, so I don't know how well sealed or how open it is already. If it is well sealed, then cutting holes would have some disadvantages, allowing ingress of water, dust, mud etc. But I thought it worth making the suggestion for you to consider.
KalSteve   1 W
Post by KalSteve » Dec 07 2017 7:12pm
Has anyone tried oil filling one of these? Looks doable and should massively improve heat shedding.
Aebrennan   100 W
Post by Aebrennan » Dec 07 2017 10:46pm
Post some detailed pics of the motor and I will post pics of our bike motors, as I’ve been told that they are the NEW motor...
The bikes will get a workout this weekend so I will be able to update soon.
Drum   100 W
Post by Drum » Dec 07 2017 11:24pm
Oil filling a low rpm direct drive hub motor has worked well for conducting heat from the windings to the casing. At the low speeds involved, the viscous drag is apparently not too much of an issue.
However this motor is spinning MUCH faster, and oil or other fluid inside the motor would probably cause significant drag, which would be counter-productive: the extra drag would require extra current in the windings to overcome the drag, creating yet more heat.
The windings might not get hotter, but the wasted energy would not be a good thing.
KalSteve   1 W
Post by KalSteve » Dec 08 2017 1:23am
Good point Drum. Forced air cooling looks like the only option.
