How To, 50A BBSHD Controller Mod
E-mil   10 mW
Re: How To, 50A BBSHD Controller Mod
Post by E-mil » Nov 15 2017 1:43pm
Climbing the ladder!
Yesterday I finally did the shunt mod. I reused a 5 mOhm shunt resistor from a dead smart-BMS, and soldered it on top of the two other on the backside of the controller. Everything works, so currently my BBSHD is running 15S 45A, and the boost is certainly noticeable!
I started depotting the controller, but realized I only needed to clear a cut-out on the backside of the board where the shunt resistors are located. Hence, there is more de-potting to do when I at a later time replace the cap for a 100 V version. (Still waiting for package from China).
As of now only the shunt have been altered. However, there are some possible caveats.
The FETs are the lesser NF75 type, but let's see how much they take. I have so far tested the system for 30 km, and so far so good. It actually surprised me it was the old FETs, because the controller has never been more than body temperature, and this has not changed now. If the FET's are to be changed it will be to 100 V FETs for future voltage upgrade compliance.
NF75 FET
BBSHD FET.jpg (58.99 KiB) Viewed 1751 times
It took me a ½ hour to get the controller out of its housing, and I chose a radical step to drill two holes in the FETs' cooling plate in order to better lift it out without possible damage to the wires, which I didn't like to pull too hard. In these bored holes some screws were mounted, and then they could be used to pry the controller loose. It worked flawlessly!
Screws mounted in bored holes.
Controller screws1.jpg (141.19 KiB) Viewed 1751 times
Controller lifted by prying the screws.
Controller screws2.jpg (151.18 KiB) Viewed 1751 times
Notice the bad contact area/fitting between cooling plate and housing. I repainted the contact area with a bunch of silvery cooling goo.
An interesting thing: What is this daughter board? Never seen that depicted before:
BBSHD unknown daughter board?!
Epyon   1 W
Post by Epyon » Nov 15 2017 2:31pm
Never seen that daughterboard either. Judging from the markings, a 6v regulator? But for what? Does yours have any extra wiring? Don't some have a lead for a light?
Mind linking to the 100v caps you got?
tomjasz   1.21 GW
1.21 GW
Post by tomjasz » Nov 15 2017 3:05pm
Epyon wrote:Never seen that daughterboard either. Don't some have a lead for a light?
It being for the added light in some versions, makes sense. I personally wish they hadn't added the 6V JST for a light.
E-mil   10 mW
Post by E-mil » Nov 15 2017 3:11pm
Epyon wrote:Never seen that daughterboard either. Judging from the markings, a 6v regulator? But for what? Does yours have any extra wiring? Don't some have a lead for a light?
Yes, my BBSHD does have the 5-6 V light connector, but I use my own rather customized lighting system, disregarding the BBSHD lighting output jack.
You might be right, it does look like a power board for the lighting connector.
Regarding the caps: These were the ones I bought, various values. I HOPE they are OK quality!
https://www.ebay.com/itm/100V-100uF-220 ... EBIDX%3AIT
https://www.ebay.com/itm/Electrolytic-C ... EBIDX%3AIT
Epyon   1 W
Post by Epyon » Nov 16 2017 2:16am
E-mil wrote:Regarding the caps: These were the ones I bought, various values. I HOPE they are OK quality!
Do you know the dimensions on them? You can only do about 27mm vertical off the board, or lay it on its side with long leads.
A little update on mine. Been running great! Zero electrical issues, just one broken chain.
I've got 2 6s LiPos inbound, gonna jump to 17s (71.4v full). I may add a trim pot or such to adjust the logic voltage, still cant find a suitable regulator.
GeoffS   100 µW
100 µW
Post by GeoffS » Nov 22 2017 4:36am
Mounting the HD unit for greater power later:
I'm starting with the 4th line down on E-Mill's summary (62.3V) and have had the battery pack built with 30Q cells in 15s 7p format with a programmable BMS (via phone and port) to make my life easier. <-- in the post. I'll review it when I have time to log a controlled discharge within specs at work.
I'm going for a semi-conservative start, as I'm a noob, and need to get my head around things and at least experience SOME success with it before I kill the machinery pushing it to the edge.
I've been looking at mounting systems with greater power later (and stability now) in mind. Has anyone tried bolting through the back of the drive gear casing directly into the ISCG05 mounts that are on many bikes?
It looks feasible, but I have a couple of concerns:
1. the front lower bolt hole will be close to the front edge of the pedal assist sensor board. Do the wires go directly inboard ? or do they snake forward?
2. The casing strength? (issue is putting a bolt hole close to an existing gap where that circuit board sits). I'm less worried about this as the casing looks massively over-built.
3. is this a classic noob move to start mods before even riding it that will end in tears?
( sorry, I can't get the pic to attach :( )
GeoffS   100 µW
100 µW
Post by GeoffS » Nov 22 2017 5:27am
The back of the casing. The motor had been rotated as much as possible to facilitate a gap between the pedal sensor board and the hole.
the 3 black dots are where the holes would need to be.
IMG_3483[1] smaller.jpg (49.65 KiB) Viewed 1664 times
fechter   100 GW
Post by fechter » Nov 22 2017 9:26am
The hole locations look OK as long as the screw heads are low profile.
I'm not following why you want to put screws there. I guess I need a picture of the mating part on the bike. I don't think I have anything like that on my bike. I also haven't had any issues with the motor moving in the mount.
malkie0831   1 µW
Post by malkie0831 » Nov 23 2017 4:46am
ISG05 is an ISO Standard mount fitted behind the chain wheel around the BB for mounting chain guides, tensioners or chain protectors:
Common on MTB’s in my experience, particularly high end one’s.
Normally to fit a BBS XX you have to remove the bottom right lug as it hits the motor.
North Herts, UK
BBS01/350 on a Viking Hybrid bike
fechter   100 GW
Post by fechter » Nov 23 2017 12:14pm
I guess I've never seen one of those before. The BBSHD normally mounts so the motor is against the downtube, so can't rotate in that direction, but could slip down if you go over a big bump. My guess is if you mount the drive properly, you would really only need one of those holes to keep it locked in place.
E-mil   10 mW
Post by E-mil » Nov 24 2017 4:22pm
The questions about screws through the gear-plate have, strickly speaking, little to do with the purpose of the thread. ;)
None the less it is an interesting take on a non-existing problem AFAIK, because as mentioned the motor turns TOWARDS (up against) the downtube. I know that Luna sells a long "triangle" bracket for better mounting, but IMO you could just mount a metal band like on the Cyclone motor, or as I have been pondering, drill a hole or two in the cooling fins on the motor house and strap the motor to the downtube this way. Same, but different..
Back to main BBSHD tuning topics:
I am still waiting for the caps to arrive, but 15S/45A is still sooo much more engaging than my original 14S/30A, tho the bastard battery setup dips a little too much for my liking (ca. 6V drop under full load) . After all its BMS is only certified for 40A, and a 20Ah EIG cell piggybacks it as the 15th cell series.
And by the way, I have ordered the Grin Phaserunner + CA3 setup. It is brand new second hand but NOT set up for BBSHD, because not bought thru ERT. I expect a lot of cable/connector trouble and setup headaches, but certified top performance at 90 V / 50 A. 22S at 4.09 V/cell should be possible. Since this new controller is coming I have only the monetary value of the BBSHD's controller to lose, so to speak.
A very sweet spot with the BBSHD controller voltage could be the 18S at 4.15 V/cell for a system voltage of 74.7 V.
Benefits are NOT having to replace the 75 V FETs, as this operation seems vastly more difficult than just replacing the 63 V cap for 80 or 100 V version, and available battery capacity is about 95%. This is all provided that the display V mod works at higher voltages..
About the display voltage mod, I have an idea I will give a try when upping the voltage above 15S / 63 V:
Simply use LED(s) as the display's voltage drop. As already mentioned a diodes forward voltage drop (Vf) is vastly less dependent on the display's power draw than a resistor is. The LED I have in mind could be one of these:
10W LEDs as voltage dropper for display power. (3x3 LED chips inside)
10W LEDs.jpg (82.34 KiB) Viewed 1606 times
Whats good about them? They are easy to come by, and only one component is required for a drop of 6 to 9 V.
A Vf chart for the two LEDs is according to my testing:
mA: White Vf: Amber Vf:
20 8.48 8.09
30 8.58 8.18
40 8.67 8.27
50 8.75 8.33
60 8.84 8.39
100 9.00 8.70
A combination of one of these LEDs with a standard diode (Vf ca = 1.3 V) can get a close to 10 V drop, and this will make it easy to calculate a factual battery pack voltage. A string of white or blue 3 Vf LEDs could just as well be used to get to the desired voltage drop. You could even let the LED's light be used as forward or side lighting :D
The best would of course be to alter the BBSHD controller circuitry, as specified by the wizards here earlier on. Then the voltage dropper becomes redundant!
E-mil   10 mW
Post by E-mil » Nov 28 2017 6:52pm
Reentry into the controller again today, as I got most of the capacitors ordered. But I need help!
The biggest problem is now to fit the cap(s) into the confined space between the other components in the controller and the motor housing itself. It seems that, with thorough measurements, it is possible to fit a 100V/1000uF cap IF the lighting daughterboard could be removed. The problem is that the cap needs two more mm to be flush with the controller board, and without these 2 mm it is too long to fit, and it is simply 1 mm too wide to squeeze down.
Another way out of the problem is to fit a 680uF cap in place, and another one outside the controller. Could this pose some inductive problems?
Another rather important question: The other smaller cap which is still halfway under potting; does this one also need replacing for 100 V?
Caps and controller1.jpg (149.27 KiB) Viewed 1541 times
Caps and controller4.jpg (134 KiB) Viewed 1541 times
Caps and controller2.jpg (71.18 KiB) Viewed 1541 times
Old cap compared to ideal replacement cap.
fechter   100 GW
Post by fechter » Nov 28 2017 10:50pm
E-mil wrote:
Nov 28 2017 6:52pm
Yes. It's in parallel with the larger one.
Adding one outside is about the only solution. I've seen this done on other controllers and many RC controllers are like this. You want it to be as close as possible to the FETs, but a few inches won't be a big deal.
E-mil   10 mW
Post by E-mil » Nov 29 2017 3:16pm
Thanks for quick answer!
I managed to cram a 680uF in place of the 1000uF 63 V, and a 470uF in place of the 220uF 63 V.
If the caps truly are connected in parallel their values will add up nicely already, but I will fit an external one as well, either at 470 or 680 uF.
It took forever to replace them and hopefully all the circuitry is still alright.
Edit: Pic of new caps added on controller. It sure was a tight fit when mounting the controller to the motor house, but system booted up nicely at 15S. Tomorrow I'll post about the venture into the realms of 18S. Cross your fingers! 🎉
fechter   100 GW
Post by fechter » Nov 30 2017 9:21am
I just double checked on a dead controller I had here. The caps are not exactly in parallel. They are on opposite sides of the shunt. For our purposes, I think this will work out the same.
It probably wouldn't hurt to add one outside too, but it would be ugly. Here's how it looks on the old BMC motor:
BMC capacitor.jpg (84.63 KiB) Viewed 1495 times
E-mil   10 mW
Post by E-mil » Dec 01 2017 6:56pm
18S / 45 A -- IT'S WORKING !
Theoretically a power-up of 100% from 14S / 30A to at least 3 kW :P
Had a short test earlier today. No misbehaving whatsoever, though batteries (14S + 4S) where at ca. 3.8 V/cell.
I also mounted an external 470 uF cap just outside the controller, intravenously into the wires (no soldering! :? ). This brings the combined capacitance to 680 + 470 + 470 = 1620 uF, well over the original 1000 + 220 = 1220 uF.
For the DPC-14 / C850 display to allow controller to turn on, I used two LED's in series; the amber 10W 8.3 Vf + a smaller white 3W 3.2 Vf (ca.). The LED's do not heat up due to their size, so atm they are just wrapped in tape. The display showed 54.6 V, which is approx what the original 15S battery would display at this state of charge. Just doing a rough calculation, I will need another 3 Vf LED to allow charge to 74 V ..
I think I will quit the voltage game at this sweet spot (18S / 4.15 V/cell) for the controller, at least for now.
As previously mentioned, this is just under the limit for the FETs' 75 V max. Going any higher requires new FETs, and at 20S also another power supply chip in the controller (according to our sources).
Was it worth all the hours fiddling, depotting, pondering and soldering? Definitely yes. I learned a lot and it was quite fun. :D
Next step will actually be true to the thread's subject; going to 50 A by virtually throttling max amps to 25 A in the settings and putting another 5 mOhm shunt in parallel. This - of course - first after verifying controller temps. Bear in mind my controller has the inferior nf75 FETs! (Has anyone ever blown their BBSHD's nf75 FETs yet?)
I will bring some feedback later. Hope you guys post your BBSHD adventures in detail as well. Cheers!
(Edit: Corrected incorrect cell Vmax of 4.09 V to 4.15)
Matador   10 kW
Post by Matador » Dec 02 2017 10:57pm
Wow nice one E-mil!
What voltage did you run exactly ? (no load voltage)
Matador
Epyon   1 W
Post by Epyon » Dec 03 2017 1:43am
Good stuff happening here!
I made my maiden commute this morning at 71.4v. Had to up the resistor(s) to 200ohms. I lowered the current to ~45A (27 in config) to keep the wattage the same (~3200w) for now. Off the line acceleration feels the same. Top end increased slightly. The pull at the top end is noticeably stronger. I might drop my gearing another tooth or two. Gotta squeeze as much fun in as possible before the snow hits. Already looking at motorizing another of my bikes as a dedicated snow machine. :D
E-mil   10 mW
Post by E-mil » Dec 03 2017 6:29pm
Matador wrote:
Dec 02 2017 10:57pm
Wow nice one E-mil!
Thanks guys - it's always nice to have an audience however few we are upping the game for BBSHD! :)
I have done two 5 km runs yesterday and today at resting voltage of approx 71 V, but the sag of 5-6 V at 45 A effectively removes a little of the kick-ass factor. Nonetheless my bike is now easily brought up to 60 km/h whereas before the same was true for 50 km/h. I guess a top speed of a good 70 km/h is generally possible.
@ Epyon -- A word of advice, although speculative: Maybe it would be a better solution to use LED's instead of resistors for the display mod. I mean if its PSU chip is designed for 60 V max you could burn it. The LED method secures that there always is the Vf drop regardless of power draw from the display. The display could be in standby mode and have its caps charged even when turned off, and resistors do not drop the voltage at minuscule loads. Thoughts on this are welcome!
Anyway I soldered an extra LED in series, so I can be sure the display is not overvolted at full charge.
The Vf is now: 2.8 + 2.8 + 8.3 = 13.9 Vf. (at 50 mA load).
Not much headroom at full charge of 74.7 V (4.15 V/cell), since 74.7 - 13.9 = 60.8 V. (but it will suffice, and I won't charge higher than 4.0 V generally).
Hey, if the snow hits, please DO take it out for a spin! I had a blast on a late night run in February where the city streets for some hours had so much snow on them, that the evil salting machines hadn't been everywhere yet. This was with stock 15S controller, but leaning forward, it could still drift. Imagine with double the power now :)
Epyon   1 W
Post by Epyon » Dec 03 2017 7:11pm
E-mil wrote:
Dec 03 2017 6:29pm
I don't run a display, the current draw without it is pretty steady around 20mA. Anything over 61.4v and the controller simply won't power on, so no worries about frying anything. Though I imagine there is a limit on whatever component controls that.
E-mil wrote:
Dec 03 2017 6:29pm
I considered doing the necessary weatherproofing, but just decided to build a dedicated winter fatbike. Either gonna do another modded BBSHD or a Tangent. I enjoy the build even more than the finished product :lol:
fechter   100 GW
Post by fechter » Dec 03 2017 7:12pm
The internal voltage regulator is rated for 80v.
The load on the power line is not constant, so using a resistor will give a variable amount of drop. Also keep in mind when you first turn it on, there will be a surge as it charges some caps. I tried a zener diode and it just fried. A TVS diode might work well though.
fechter   100 GW
Post by fechter » Dec 04 2017 10:37am
On my test controller, I measured the current at about 25mA on standby, to about 40mA with motor running and display lit. From this, and knowing the amount of voltage drop, we can calculate the amount of heat that needs to be dissipated.
There are a number of ways to drop the voltage. The simplest would be to pick the right TVS diode. Large LEDs stacked in series work in a similar manner. Just a bunch of regular diodes in series will work also, but you need some 1A rated ones like 1N4001 or similar. At this current, you get about 0.74v per diode.
This circuit will give a voltage drop of about Vz + 0.7v, where Vz is the voltage of the zener diode. The transistor will dissipate most of the heat so needs to be sized large enough. The transistor only needs to be rated for more than the drop voltage, but a higher rating won't hurt.
Amplified Zener 1.jpg (13.96 KiB) Viewed 1408 times
Small LEDs stacked could be used in place of a zener diode.
Yet another version using a MOSFET:
Adjustable voltage dropper (crude).jpg (9.46 KiB) Viewed 1408 times
This one is adjustable but the amount of drop is dependent on the gate threshold voltage of the FET, which will depend on temperature and load current. Over the typical temperature range, might vary by 1 volt or so.
Edited to remove incorrect circuit...
E-mil   10 mW
Post by E-mil » Dec 06 2017 2:23pm
Thanks for the circuits and insight, Fechter.
About the safety voltage drop, I was talking about the display, not the controller. I don't know if the display's caps and voltage controller can take damage, and that's what I was worried about :)
fechter   100 GW
Post by fechter » Dec 06 2017 3:25pm
E-mil wrote:
Dec 06 2017 2:23pm
That's a good question. Since the display unit I have is potted, it's not easy to open up and check. Mine still worked after I blew a 12v zener dropper, so it seems to be good for at least 72v. I suspect it uses the same LM5007 voltage regulator as the controller. 80v rated. I suspect the display also uses 63v caps. As long as the voltage dropper is good, the display won't see more than the normal voltage.
E-mil   10 mW
Post by E-mil » Dec 06 2017 6:00pm
Well, here's to the rescue, Fechter:
DPC-14 / C850 Opened up
DPC-14 opened_crop.jpg (245.94 KiB) Viewed 1361 times
DPC-14 Display solder pads_crop.jpg (149.85 KiB) Viewed 1361 times
I can detail how to safely break it apart if you wish.. I rubber-glued it together, and it's without problems since.
Gotta say I opened it because "ERROR 30 - Communication FxxxxP". The whole freakin display connector had bad solderings. Took me 4 hours to locate and fix the wire bugs. Had to test each lead! Unfortunately it was not in scope to detail the components of the display at the time :(
Shitty solder job.jpg (68.32 KiB) Viewed 1361 times
Connector repair_resize.jpg (35.97 KiB) Viewed 1361 times
