N.E.S.E. the no solder module
schorschMZ   100 µW
100 µW
Re: N.E.S.E. the no solder module
Post by schorschMZ » Oct 28 2017 9:35am
Hi Agnesium,
please pm me a qoute for 23s8p hardware - thank you.
agniusm   10 MW
Post by agniusm » Nov 05 2017 4:30pm
I think i found a nice bms(not pcm this time) to fit into 6P NESE module. It will be 10S 30A solution with built in blutooth and android app to set parameters and view cell state. Kust need to figure out BT drain
Microbatman   1 kW
Post by Microbatman » Nov 08 2017 8:31pm
Love the 8 cell module
Any update on when the hardware be in?
Website shows it is on backorder
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
agniusm   10 MW
Post by agniusm » Nov 09 2017 1:20am
Punch dies are being made. I expect to have them around 20.11
Rube   100 W
Post by Rube » Nov 09 2017 4:34am
agniusm wrote:Punch dies are being made. I expect to have them around 20.11
Sounds like an interesting development, what is the impact on production?
agniusm   10 MW
Post by agniusm » Nov 09 2017 5:09am
Higher quality, rapid manufacturing, less intense work, a llt less manual labour.
agniusm   10 MW
Post by agniusm » Nov 15 2017 7:17am
Ordered BMS. Will adopt 6P case to house bms and have 15S connector for balancing. It will be possible to build a battery of upto 14S with upto 30A discharge/charge current or unlimited discharge/30A charge currents using contactors. Bluetooth module will be integrated so whole battery including BMS in seamless design. Smart battery from now on :)
agniusm   10 MW
Post by agniusm » Nov 18 2017 12:26pm
The tabs are made. Some issues with plating but being corrected.
agniusm   10 MW
Post by agniusm » Nov 20 2017 2:14pm
Started designing BMS enclosure to fit the NESE design. BMS will be available up to 15S and 30A charge/discharge or unlimited discharge/30A charge with external disconnect (controller logic or contactor hard disconnect).
First i was gonna implement 15pin JST XH 2.5mm connector at the top of the modules (Need 16pin but that does not fit), but it introduced a second wiring loom failure point and i could not utilize full 15S capability, only 14S max. Also this meant a lot more work so more expensive. I started to look for grommets online just realizing that i can print them the way i need. here is what i came up with. The grommet will exit 16 wires to 15 cells or less depending on system voltage. Here are couple of teaser pics:
Minimum enclosure size is 6P or 123mm in length.
agniusm   10 MW
Post by agniusm » Nov 22 2017 9:23am
Got some tools and supplies. Will start making test samples of BMS harnesses.
P.S. Just this once i can offer a pre-built battery, 10S6P with bluetooth BMS and chosen cell type from www.nkon.nl with free assembly for EU.
agedashidofu   1 W
Post by agedashidofu » Nov 27 2017 12:55am
This is so awesome...looking forward towards the 8P module as well.
Would you mind sharing the sizing details for each module as well? That will help us plan the configuration (series & parallel) that will fit within the space requirements.
Many thanks!
agniusm   10 MW
Post by agniusm » Nov 27 2017 1:36am
Hi. Thanks mate. Probably you have missed it but there was a link to my website. If you would follow this link: http://18650.lt/index.php/resources/ you can find there all dimensions, technical drawings, approximate weight, 3D view and other information.
Thank you
agedashidofu   1 W
Post by agedashidofu » Nov 29 2017 1:37am
Thank you! Not sure why I completely missed it! The measurements are indeed extremely helpful!
Speaking of which - are you planning to come up w/ 10P or 9P? Thx a bunch!
agniusm   10 MW
Post by agniusm » Nov 29 2017 2:19am
Hi. No, i will not do 9P and 10P. I just payed hefty sum for punch dies and its all i am planed for. 9P and 10P are very large and you are arriving at the point where there are cells that could be acquired for good price.
On the other hand, if you have a means of printing i could scale it up to whatever size quick, but you will need to work out how to join additional 2P of tab. i just don't think its viable. The current path for the last cell increases. I don't think it will increase by amount it will be significant to influence cell somewhat but still.
If you need 10P, you could just use 2 x 5P, parallel 2 modules then series them to whatever voltage.
olivier2604   100 µW
100 µW
Post by olivier2604 » Dec 04 2017 5:03am
Hello Agniusm,
Does hardware (hardware set, printed modules 6p) are avail for a 6p20s ?
It still expecting to ship on 21.11.2017 on your website !
Regards
agniusm   10 MW
Post by agniusm » Dec 04 2017 5:13am
Hi. I am receiving bus bars tomorrow, inspecting and this week i should start shipping. There are assembled modules on my website too so you can just purchase them and add other bits like series busbars, protection caps if you need them. On a 20S battery 19 series busbars required and 19 twin caps plus 2 single caps (different colors available).
Regards, Agnius
agniusm   10 MW
Post by agniusm » Dec 04 2017 12:16pm
Good news. All back in stock. Tonight will sort out preorders and post them out tomorrow.
agniusm   10 MW
Post by agniusm » Dec 12 2017 2:19am
:santa: Till the end of the year small present, 10% off. Coupon code - christmas :santa:
agniusm   10 MW
Post by agniusm » Dec 19 2017 2:47am
Here is one way to use NESE on a e-skateboard. Printed in color changing ABS:
Build thread: http://www.electric-skateboard.builders ... ings/41278
LewTwo   100 kW
Post by LewTwo » Jan 02 2018 5:47pm
Very Interesting Thread --- subscribed.
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
nathan89   1 mW
Post by nathan89 » Mar 14 2018 6:32pm
Looking for help with some of the 3d printer settings as I'm a noobie. Using Cura with a CR-10.
Seems these settings are for a different slicer, and just named differently in Cura.
Perimeters - 4
Bottom solid layers - 5
Top solid layers - 6
Thanks for any help.
agniusm   10 MW
Post by agniusm » Mar 15 2018 1:00am
Hi. For cura you will need some math :)
Perimeter is shell thickenss in cura expressed in mm. 4 perimeters will equal 1.6mm in cura.
Top and bottom solid layers would mean that you need to multiply 0.2 × = 0.8mm and 0.2 × 5 = 1mm
You also need to find a setting to fill small gaps. Particular place to watch is bottom enclosure part at the top where the groove is located for lid.
I will look it up later for you cause i have cura but not use it
parabellum   10 MW
Post by parabellum » Mar 15 2018 8:45am
Or just go to Settings>Setting Visibility and in 'Shell' check "Wall line Count","Top Layers" and "Bottom Layers". After that you get new fields in Cura settings list, line count change will recalculate shell thickness automatically. :wink:
agniusm   10 MW
Post by agniusm » Apr 18 2018 12:07pm
Jehus live show tomorrow on NESE kit:
http://18650.lt/index.php/2018/04/18/je ... v-battery/
StanSimmons   1 µW
Post by StanSimmons » Apr 19 2018 1:17pm
Any plans on creating a 26650 version?
