Small 72v 50A controller
Motormark
Post by Motormark » Dec 14, 2017 5:33 pm
Hi,
I'm searching looking for a controller where size is the most important. It can only be 74mm wide to fit INSIDE a Culbix 75mm frame
There is no need for housing.
72v
50A cont. And little bit more peak.
Only need a trottle and (progressive) regenerative braking. I'm using the CA to drive the controller.
I don't have the skills to build my owne Lebowsky controller.
Need it shipped to belgium.
Can you guy's help me, or point me in the right direction?
Motormark
Re: Small 72v 50A controller
Post by Motormark » Dec 15, 2017 7:47 am
Thanks Skeetab, it's perfect!
skeetab5780
Post by skeetab5780 » Dec 15, 2017 1:51 pm
No problem I really like mine!
Motormark
Post by Motormark » Jan 08, 2018 1:20 pm
I got the Kelly KBS72121X controller,
And i looks like its capable to handle 55A FASE current, not battery current.
Its only 26A battery current.
skeetab5780
Post by skeetab5780 » Jan 08, 2018 3:21 pm
Are you sure how did you test it?
you first set the motor current in percent, than you multiply this value (in amps) with the percent you set for battery current.
an example with 55/130A rated controller
motor current: 80%
130A * 0,8 = 104A phase
battery current: 50%
104A * 0,5 = 52A battery
I guess your right, 52a for 10sec boost and 26a continuous
Im sorry to mislead you phase current is an awful trick
madin88
Post by madin88 » Jan 09, 2018 2:26 pm
Yes, it can do 55A phase current continuous and 130A peak for 10sec, but what gives you the idea that this is only 26A batt?
motor current: 80%
that's right
if you set phase current to 100% than it's the 130A as specified.
batt amps can be only set to 70% from what i know, so 130A x 0,7 = 91A which would be about 8kW peak at max allowed voltage.
Not bad for such a small controller.
skeetab5780
Post by skeetab5780 » Jan 09, 2018 3:23 pm
I wish it put out 91A
Im pretty sure it only allows 50% battery current
how do you increase it to 70%?
50% is max in the settings
madin88
Post by madin88 » Jan 09, 2018 3:42 pm
I had it in memory that i could choose 70% batt current on the KBS48121-X which i used for some bikes when i was working for an e-bike company and i also have something about different firmware versions in my mind, but thats already more than two years ago so please don't nail me down on this.
skeetab5780
Post by skeetab5780 » Jan 19, 2018 12:11 pm
Spec sheet for that controller also says 50% is max. Not sure where the 70% is coming from
Motormark
Post by Motormark » Feb 12, 2018 5:55 am
Burned the controller anyway.
Bought a bigger 90A battery current 24 pc mosfet controller instead.
So there goes the plan. Must place controller outside the frame.
skeetab5780
Post by skeetab5780 » Feb 13, 2018 11:07 am
Did you just throw it in a fire? Or how did you burn it?
What model number did you buy instead?
interested
teklektik
1.21 GW
1.21 GW
Post by teklektik » Feb 13, 2018 11:35 am
72v
Was the Phaserunner too pricey (96A phase)?
Visit Grin Technologies at www.ebikes.ca
Build Thread: 2WD Yuba Mundo V4
Motormark
Post by Motormark » Feb 18, 2018 7:41 pm
Absolutely not teklektik,
The one i bouth was much more expencive.
Just didn't know the phaserunner existed. That is also the original reason of my first post.
skeetab5780
Post by skeetab5780 » Feb 21, 2018 10:52 am
Phase runner is pretty nice looking, I didn't know it was rated so nicely! I may have to give it a try myself
