Marin Stinson Euro Build Thread
tomjasz
1 GW
Out riding, MN USA
The Stinson 2010 has fork suspension with 63mm travel. All MTB solid forks are 45MM. I do not want a suspension fork. How will 45MM change the ride? Want a front fork with V brake and disc option. Have a set of BB7 for front brakes.
Finally found the PDF version of the catalogue without any gibberish as in the above cut and paste. Finally have 95% of the parts and the build begins. It was to be a 2WD however I'm slowing down and don't need the speed or power. Instead I'll use the front on a KHS Smoothie frame formerly a BBSHD.
Reserved
