Sabvoton User's Guide (unofficial) [sabvoton.wire.bike]
Get real world experience and user feedback on the electric bicycle products.
alec   10 W
Post by alec » Dec 22 2017 6:58pm
Hi everybody,
I've started an unofficial Sabvoton User's Guide at http://sabvoton.wire.bike
I'll be constantly updating it with new information.
Please feel free to critique, contribute content on or leave any other comments here.
:idea: Update log:
Code: Select all
v.0.9 12/22/17 - Initialization
:arrow: If you like or appreciate this content, please donate any amount of money to the Cancer Research Institute.
❝ With great power comes an even greater PG&E bill.
12kW+ Greyborg, Cromotor V3, SSC96150
sabvoton.wire.bike [unofficial user's guide]
wire.bike [personal projects]
ridethelightning   1 MW
Re: Sabvoton User's Guide (unofficial) [sabvoton.wire.bike]
Post by ridethelightning » Jan 13 2018 6:24am
a good start to a neat and tidy guide there.
I have just purchased a 200A version sabvoton svmc72200 (M), and having only used the adaptto system till now, need to get my head around it.(paticularly using the cav3, programming etc)
i got mine through QS recently(september 17)came with usb cable. am i right in thinking that ill need to buy a new usb cable thing for it or have they sorted that by now?
cheers
RTL
alec   10 W
Post by alec » Jan 25 2018 2:50am
ridethelightning wrote:
Jan 13 2018 6:24am
cheers
RTL
Sorry for the very late response! Been busy here as of recent.
And no, you'll probably be fine considering you have an M! They're standard with RS232 during that era... if you're lucky. You never know! I think we both know the best way to find out... hook 'er up! :D
matt912836   10 W
Post by matt912836 » Jan 31 2018 9:15am
Hey alec, i ran into your guide looking for help with my sabvoton, very helpful so far. I have one of these controllers:
The (M) indicates it's a newer model conpatible with Bluetooth, correct?
Can you provide any input on how to set one of these up for Bluetooth? The guide says you need both the dongle and USB cable to program the dongle correctly but doesn't go into further detail. Any further help on how to do this? This also means you never need to hook up the controller to the computer, just the dongle right? I don't have access to a computer right now so if I can program the dongle easily at a buddies house without having to bring the whole bike that makes it a lot easier.
matt912836   10 W
Post by matt912836 » Feb 11 2018 2:51pm
I'm trying to wrap my head about using the HC-06 in place of a dongle. Never touched an arduino before so while it may be a simple concept its all new to me (at the same time learning how much Im missing out on, an arduino can add so many functions in an ebike). My goal is to reprogram my sabvoton solely through my android. I don't have access to a computer directly right now, and In the sabvoton guide it states you need a serial to usb cable to program the hc06 via AT commands to work with the sabvoton. Shouldn't I be able to do it with just the HC-06 alone? Wire it to a USB cable, connect it to the sabvoton to power it on, then connect to it via Bluetooth on my android and just reprogram it with the same AT commands through a bluetooth terminal? Or is changing the baud rate/name not possible while using bluetooth to connect to it? Any input? I can pick up an hc-06 locally in NYC so the faster I can get it running the better.
Newbeast   1 µW
Post by Newbeast » Feb 12 2018 8:22am
Amazing work mate! been trying to figure out how to get my sabvoton controller running for 3 months now, your a true hero. just bought a JBtek USB to RS485 on express delivery, but have no clue what cables i have to plug into it lol. waiting eagerly on updates! :D
matt912836   10 W
Post by matt912836 » Feb 13 2018 11:18am
Got my hands on an Hc 06 and serial usb cable. I sent all the commands to the hc06 from terraterm on windows as the guide says to set the baud rate name etc... everything saved ok. When I connect the hc06 to the sabvoton and run the app, the app says unconnected and does nothing... any help? I assume the app is supposed to automatically connect when you open it? as there seems to be no way to establish connection. The one button in the corner does nothing. swapping the tx and rx pins on the hc06 to the sabvoton does no help... restarting the app many times and nothing. any advice? If I short the pins on the hc06 and talk to it through a bluetooth terminal I get an echo of what I sent, so the bluetooth is receiving and sending data... also when I connect to it through the bluetooth terminal the red light stops flashing meaning something is connected, when I run the sabvoton app the red light stays flashing meaning nothing has tried to connect to it and it's ready to be connected to...
UPDATE: seems like the hc06 is hooked up properly to the controller, I'm able to connect to it and change parameters through the windows app. I guess it's true that the android app just sucks bad... someone needs to develop a good mobile interface for this controller! it has so much more potential
There seems to be another app other than the SVMC app, there's one called MQCON found here.
http://www.mqcon.com/menu/downloads.html
Has a lot more functions similar to the windows app.. still can't get this one to work either though :?
E-Zero   100 mW
Post by E-Zero » Feb 19 2018 5:35am
Although mine is a 96150 I think you might help.
Was working fine, I had to disconnect the motor for maintenance and now error 25 is on. Tried everything, even reset to factory default but nothing. It shows 2v only but the battery is full...
Help will be welcome!
Post by ridethelightning » Feb 20 2018 10:05pm
i have been working on my 72200 and got it working but when a friend fired it up for a test, it seems to have bbqd the fets. i suspect the halls combo was not saved correctly somehow
does anyone have any advice about spares/support for sabvoton?
i have made a thread about it here-
https://endless-sphere.com/forums/viewt ... =2&t=92954
MoonBassMan   1 W
Post by MoonBassMan » Apr 01 2018 1:47am
Hope you get the guide up soon. I'm looking into purchasing a Sabvoton 72200. Was hoping to do a little research in advance.
My build: https://endless-sphere.com/forums/viewt ... =3&t=84738
If I knew ES would remember account creation time, I would have waited 7 more minutes...
bionicon   1 kW
Post by bionicon » Apr 01 2018 6:22am
Very interesting i will folow this up :D
alec   10 W
Post by alec » Apr 12 2018 10:44am
MoonBassMan wrote:
Apr 01 2018 1:47am
I’m happy to answer any questions.
I’ve misplaced the files for this website, I’m desperately looking for my backup so I can get this back online!
alec   10 W
Post by alec » Apr 12 2018 10:53am
matt912836 wrote:
Feb 13 2018 11:18am
The HC06 will work as a serial bridge for sure. The problem that I’ve faced with writing a third party configuration app is that all of MQ’s software is compiled and spits out quite confusing serial data. The amount of time required to reverse engineer the 64-bit string sent from the app via serial is time I didn’t have then to spend and don’t have time now.
The reason KH6xx controllers have so many third party apps is because a few open source configuration tools were released which allowed developers such as myself to see what the conversion algorithms are, and what commands allow communication with the controller.
In the future, I will be shifting my focus away from Sabvoton. After countless months of research and development with huge hopes of nursing their products into a daily driver, I’m deeply saddened to say it’s an inheritely good product, plagued by awful proprietary software, closed-source communication, shoddy customer support and shady trading business deals.
Luckily, there are plenty of high-powered sine controllers available in 2018 being sold by incredible, smart, helpful members of our community. I know WestCoastElectric offers a 24 mosfet sine controller which would be a much smarter option than going with a Sabvoton/MQCON.
Of course, anybody who is willing may reach out to me if they are in the boat I once was: Sitting in front of a Sabvoton, that’s not working, unable to find anything other than dodgy Russian YouTube videos for tips, nobody knows anything; feeling helpless — PM me. I’ve faced every single problem you can while working with these products and promise that, unless the unlikely case your unit is defective, I will be able to solve your issue almost immediately.
Disclaimer: I do not sell these units. I simply am an enthusiast.
I hope everybody is having a great 2018!
evolutiongts   10 kW
Post by evolutiongts » Apr 12 2018 12:38pm
Sabvoton are not bad controllers at all, I've been using them for the last 4 years in virtually all my setups.
I actually toured their factory in Suzhou, China. Yes they're manufactering equipment is old. The components are soldered on by machine but the final assembly is still done by hand. They test their controllers, before putting on a QC sticker.
They sell primarily to the OEM market, not so much to us enthusiasts. So getting a order of Sabvoton controllers with the correct connectors and features is problematic at times. That and they don't really speak english.
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
atarijedi   100 W
Post by atarijedi » May 30 2018 12:59am
So what is up with Sabvoton now? Their website no longer works. Emails bounce back. The only way to get any info on them is to contact QS.
Not very trust inspiring. Are they going belly up or something?
Aeron   10 W
Post by Aeron » Jun 20 2018 10:52am
alec wrote:
Apr 12 2018 10:44am
Any news ?
Dan   1 µW
Post by Dan » Feb 11 2019 9:16am
Hello Alec,
Thanks for writing an unofficial user guide. Is it still available somewhere?
Thanks,
Dan
Gbcarnage65   1 µW
Post by Gbcarnage65 » Feb 27 2019 10:41am
I have a sabvoton svmc 7280 and I'm getting an error code of 30H. Anyone know what this means.
mark5   100 kW
Post by mark5 » Feb 27 2019 5:53pm
Dan wrote:
Feb 11 2019 9:16am
... unofficial user guide. Is it still available somewhere?
Archive.org has a copy, v0.9 as of 1/26/18, but missing the wiring diagrams & software downloads. Were there later versions than this?
alexplatts18   100 µW
100 µW
Post by alexplatts18 » Jun 20 2019 1:09pm
I have the same issue
Sent from my CLT-L09 using Tapatalk
adrock8519   1 W
Post by adrock8519 » Mar 14 2020 8:54pm
Gbcarnage65 wrote:
Feb 27 2019 10:41am
30 h is because the settings lock cable isn't plugged toghter.
Silence#2   1 µW
Post by Silence#2 » Mar 25 2020 3:20am
Error 30H comes up when communication plug is not joined back together, communication plug is yellow, green, brown, connect to yellow, green, black. I went back to adjust parameters after getting new controller up and running and had issues with app until I realized I had to disconnect these wires again before the app works properly. When I contacted supplier about Error 30H they said it's normal when communication plug is not connected. Hope that helps clarify things...
Everything is anything and nothing is as it seems.
