cell imbalance in new hobby king lipo pack
TimJ
Post by TimJ » Feb 12, 2018 9:01 pm
I received my Multistar lipos from hobbyking the other day and had tested out all cells in each pack over the weekend. Out of the box, everything was at 3.75V +/- 0.05 except for one pack where one cell was at 3.6V. Based on what I read in Neptronix's Lipo tutorial, I felt like this is probably a bad sign for the pack. I filed for a return of this 4s pack with HK but they rejected the RMA request today. This was the response I received:
Hello, From the information you have provided, we cannot determine your battery as defective. Lipo batteries have a storage chemical in the cells when they are new. This chemical dissipates after the battery is used for 5 to 10 cycles of normal use. This is called the "break in period". This chemical can cause the battery to not balance well in the beginning. Therefore, I would respectfully ask you to cycle (actually use the battery then balance charge it , do not just discharge on the charger and then charge) the battery between 5-10 times and see what the individual cell voltage readings are then.
Does anyone know if this is accurate? It sounded to me like it could be a strategy to see if the customer can correct a manufacturing problem by doing repetitive balance charging, or to get them to give up on a return after an extended period of time.
I was wondering if I should even be using this pack when it will be connected with 5 other packs for a 14s2p configuration (20 Ah total capacity). Should I just buy a replacement and keep this one for powering accessories like lights, phone charger, etc.? I would appreciate any suggestions for how to deal with this. I'm glad I stayed with the 10Ah capacity instead of the more costly 16 or 20Ah. Something others may want to consider if this is normal for HK quality and customer service.
-Tim
dogman dan
Re: cell imbalance in new hobby king lipo pack
Post by dogman dan » Feb 13, 2018 8:22 am
I'd have replied the same if I was HK. You are asking for a refund way premature IMO.
Charge them, and see if they are balanced then. Only if one shows severe symptoms will you get relief. Puffed all to hell, demonstrated severe low capacity, or self discharging itself.
If you run them, and one is hitting lvc way before the other, that does indicate lower capacity. Sure, its a bad sign for it to arrive less than the others. It may have self discharged, and taken a year to do it. See if it self discharges much overnight before you freak out.
I think if you have a bad pack, it will puff by cycle 5 or so. Run it like normal, after a full charge and watching it a day or so to see if it does self discharge more than .05v.
Personally, the few times I got a bad pack, I just bought another. I DO like to buy in the spring, after china new years, when the stock is likely to be new. After most old stock is bought up. You might have gotten an early 2017 pack, and the rest from 2018 stock.
motomech
Post by motomech » Feb 13, 2018 12:48 pm
Yeah, you worry too much.
Do what Dman said and if the brick puffs-up, take a pic and send it to HK.
the Multistars have a high turn-over rate and I suspect that one cell will fall in to line and everything will be ok.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/20Ah Multistar Lipo rear 5Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
https://endless-sphere.com/forums/viewt ... 8#p1237928
TimJ
Post by TimJ » Feb 13, 2018 8:01 pm
Ok, good to hear that I am over-reacting. I had just read thru the Neptronix lipo tutorial (again) and it said early on that a difference over 0.10 volts was a bad sign, so I was feeling concerned. Whenever I buy something new, I want it to work perfectly at the start, so this is part of my reaction too... I'll do the initial balancing later this week, but it will be a while before I can get the bike together and be ready to go.
I ordered my Leaf motor on 2/5. They told me the next day that their shipping company took vacation for the Chinese New Year (2/16) and will not begin making any shipments again until 2/22! All shippers in the city are the same, so it'll be a couple weeks before I can put things together. I have a large report due at work anyways, so don't really have a lot of time to work on the bike right now.
Thanks, guys!
-Tim
999zip999
Post by 999zip999 » Feb 14, 2018 1:15 am
I would like to know how things work out.
dogman dan
Post by dogman dan » Feb 15, 2018 7:32 am
It is a bad sign, which is why you want to check it out with a cycle or two to get it fully full and balanced, then see how the cell behaves.
There will be inbalance of some degree, that shows when the pack is fully empty, at 3.5v or lower. At 3/6v and above, it should do better.
BTW,, I call anything up to .1v off balanced enough, though better is nice. So if its turns up .05 off, I call this perfectly normal.
If it continues more than .1v off, you do have a weak cell. Still usable, but the cell you want to watch when you check voltages.
TimJ
Post by TimJ » Feb 15, 2018 8:17 am
I'll post back when I have results. I will do a normal balance charge to full and then will be storing them for a little while before I am ready to use. Will monitor periodically. Without doing anything else, the one cell was down another few hundredths of a V, while the others remain strong, so I am expecting it may have a permanent issue, but I'll check it out thoroughly with actual use.
-Tim
jordison
Post by jordison » Feb 19, 2018 2:41 pm
i have 14s pack made from 6s+6s+2s, the 6s they arrived betwen 3.78 and 3.8v, the 2s i bouth a couple months later and came with 3.9v, only after 600 cicles i had a problem with them, a bad cell in the 6s pack after not balancing or cheking them for several months of daily use . now has more than 800 cicles after replacing one of the 6s.
you should cicle them and not worry for now.
