macribs
- Joined
- Jul 22, 2014
- Messages
- 3,702
rberger maybe yet another hubsink is what you need? Didn't catch what motor you run, but if you got enough width between motor flanges to fit two hubsinks side by side that should help with the added thermal mass. Heat should be drawn even faster out from the motor. Worth trying as you say, depending on where thermal rollback happens the rollback could be hi risk. Better to try to avoid thermal rollback.
