Qulbix 165/140 Raptor /NYX Carbon - Sabvoton/Adaptto - 20s/22s Build #5
Quokka   1 kW
Re: Qulbix 165/140 Raptors - Sabvoton/Adaptto - 20s Build #4
Post by Quokka » Feb 14 2017 9:06pm
Thanks fellas. Changed my order to a 17. Will look like a brumbrum clone.. hope I can wheelie better as well
Qulbix Q76R+ QS205+MaxE
Merlin   1 MW
Post by Merlin » Mar 06 2017 10:17am
yes...iam an Asshole :D
but it was too funny finding her trapped under her bike :lol: :mrgreen:
MadRhino   100 GW
Post by MadRhino » Mar 06 2017 12:06pm
I was trapped under a Harley Chopper once. Right in the middle of the street, my front wheel stucked under a car. I recall this was when I started thinking about lighter bikes. :D
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
Quokka   1 kW
Post by Quokka » Mar 17 2017 10:27pm
Hey Merlin, do you have your multistars hooked up to the adaptto BMS? And how do you charge them? Can you bulk charge the whole thing through the adaptto or do you need to do the packs separate? Thinking of swapping to lipo but still learning about charging the things and how to run with adaptto
Merlin   1 MW
Re: Qulbix 165/140 Raptor /NYX Carbon - Sabvoton/Adaptto - 20s/22s Build #5
Post by Merlin » Feb 27 2018 9:00pm
hey, sry looks like i have missed this reply :(
to complete the question:
yes, Multistars was hooked up to the Adaptto BMS.
Simply putting 3 of them in Parallel and 5 of them in Series.
so i had 15x 4s16000 in my Frame.
Made simply parallel and series wires for them and plugged them with the 4s balance wires direct in the BMS.
meantime switched all my parts to a NYX frame. unfortunately there is no space for big lipo bricks, so i switched also to 18650s 30q (22s)
did my best for a low RI pack to compensate the voltage sag from 200amps.
worked very well.
Adaptto Display give me 18kw on a fresh battery. so a bit more punch on the top.
switching to the NYX saved me also sweet 9Kg of weight penalty =)
not because the weight about 6.9kg is simply fake or wrong or early model from 2015. narrow tires, no kickstand yet, plastic fenders, 18650 battery....
too bad i expected a better quality from nyx. beside a poor finish on the carbon part(s), fitting the "halfs" with missalligned gaps the most frocking crap was the swingarm. its simply not alligned with the bottombracket. i thought it was only my "cheap" version of the nyx but it looks like its normal.
as i read your post about the bushings it was clear.
let me put some pics inside to show what i mean.
at the end i put spacers between the swingarm parts to bring this thing in shape. switched the M6 screws to 12.9 strong steel.
some days ago i had finished the bike. battery, electrics, dc/dc, bms and xenon light controll unit are inside veryyyyyyy tight, but it fits =)
Merlin   1 MW
Post by Merlin » Feb 27 2018 9:41pm
some shiney pics after alot of work =)
Fenders are "Mudhuggers"...Front and Rear.
225mm Hope Disc front. 220mm Custom Disc on the Rear (2,1mm thick)
Rims SmPro 19x1.6 Front, 17x1.85 Rear
Tires Shinko F540 2.75x19 Front, 2.75x17 Rear
Fox 40, Fox RC4
Magura MT5e Front / Rear
litespeed   100 kW
Post by litespeed » Feb 28 2018 7:33am
Now that is one great looking ride!
Tom
brumbrum   100 kW
Post by brumbrum » Feb 28 2018 7:35am
Nice build! I’m loving those tyres, they are going on a future tyre choice for me.
I’d be tempted to turn the front mudhugger backwards to stop face spray and mud flicking up.
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
Rix   100 GW
Post by Rix » Feb 28 2018 8:03am
litespeed wrote:
Feb 28 2018 7:33am
Tom
What Tom side, looks sweet! Yah, alot of work involved.
Allex   1 GW
1 GW
Post by Allex » Mar 01 2018 3:52am
Your wife still with you? :mrgreen:
How does the swingarm moves on this thing, no ball bearings?
Oh, and the rear disc brake is facing wrong direction I think.
Merlin   1 MW
Post by Merlin » Mar 01 2018 9:38am
Yeah still there :D
She got a new battery and saved some weight.... :p
What do you mean with moving swingarm?
Ball bearings? Do you mean the delrin stuff?
Rear disc is right. Discs layout is like maguras. Brake force is pulling on the surface. If you flip the direction it would be pushing surface.
If pushing discs tend to start "singing"
SlowCo   100 kW
Post by SlowCo » Mar 01 2018 12:01pm
Great looking bike!
It might be wise to use a bent aluminium plate or rubber flap from the controller to the underside to protect your wires and connectors from getting wet and dirty.
Merlin   1 MW
Post by Merlin » Mar 01 2018 12:11pm
Iam allready on the search since I got the frame.
Had no luck yet.
Sucks a bit... Buying "this" where its clear something to protect is a must have. But nooooo..... Diy "something"...
One idea was a plastic fender from a dirt bike. Cutting in shape I need.
But fixing it to the frame not easy. Battery needs all space inside and not sure if I can drill some threads in this carbon/gfk "chassis"
tahitiboob   1 W
Post by tahitiboob » Mar 01 2018 5:32pm
in french :Put...n qu'est ce que c'est beau !!!!!!
Quokka   1 kW
Post by Quokka » Mar 02 2018 8:18pm
I am completely pissed off with the guys at NYX. Absolutely zero help when i comes to replacing the delrin swing arm bushes. I am going to have to have some custom made. I will have a few spare just un case lol
Merlin   1 MW
Post by Merlin » Mar 02 2018 8:28pm
fully agree...took me weeks to come in contact. After that no help and not understand the real problem. he offered me a new set of bushings.
but how can they help? anyway. cant recommended them and a Qulbix Q76 is also lighter then the NYX frame. the advertised weight is simply not true.
Quokka   1 kW
Post by Quokka » Mar 02 2018 8:38pm
I have a controler shield you can have. Just need to wait till august when i go home so i can post it to you (if you want it just pay for postage)
Merlin   1 MW
Post by Merlin » Mar 02 2018 8:39pm
send you PM next minutes ...
Merlin   1 MW
Post by Merlin » Mar 02 2018 9:19pm
I know you all guys like pics......so...here are some impressions of my "sample"...
brumbrum   100 kW
Post by brumbrum » Mar 03 2018 4:11am
Those images are shocking. The alignment issues are very bad.
Did you pay full price for the frame? Or was it reduced price sample for business purpose?
From getting an nyx frame early on in their production it was very easy to get contact with Cedrick of Nyx.
All of a sudden he disappeared as if he no longer part of nyx. Only Eloi is left who does not speak english.
Communication was quite slow when i ordered new bushings, but it did get sorted. Price for a pair of bushings was ok at $30, but shipping was a whopping $40.
Willow   10 kW
Post by Willow » Mar 03 2018 6:35am
Lovely job on the NYX. At 18KW it certainly must feel good.... those tires too look the business. :twisted:
ridethelightning   1 MW
Post by ridethelightning » Mar 03 2018 7:58am
brumbrum wrote:
Mar 03 2018 4:11am
id be looking at other alternatives like zbike if wanted one now
litespeed   100 kW
Post by litespeed » Mar 03 2018 10:07am
ridethelightning wrote:
Mar 03 2018 7:58am
Looks like their web site is down due to non payment!
Going to hell in a hand Basket! I tell you.
Tom
efMX Trials Electric Freeride   1 MW
Post by efMX Trials Electric Freeride » Mar 03 2018 10:31pm
litespeed wrote:
Mar 03 2018 10:07am
Mar 03 2018 7:58am
Tom
here is their (new?) website :
http://zabobike.lt/
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
