Rix   100 GW
Re: E-S Stealth Electric Bike Owners
Post by Rix » Mar 10 2018 3:53pm
When i gain some speed and pull the "front brake Only" the bike pulls to the left
This is a sign that your axle clamps aren't evenly tightened or not tightened enough, provided your triple clamps are tightened properly and evenly. Make sure both axle bolts on each leg are tightened evenly.
regen button produces less braking power, less than half, compared to the older model.
Thats a program setting issue, and I am betting that Stealth changed the regen values, as the older models shunted so hard during regen, the rear wheel would actually break traction and skid on loose terrain.
Athaneco   100 W
Post by Athaneco » Mar 11 2018 5:49am
Thanks Rix. The clamp screws were loose in fact. I tightened them. Shall i use thread lock? I will test the bike tomorrow to check , sqeaky sounds have been reduced too.
Rix   100 GW
Post by Rix » Mar 11 2018 10:52am
Athaneco wrote:
Mar 11 2018 5:49am
Thread lock wont be necessary, just keep an eye on it and check it from time to time. I have found that when tightening steel screws into aluminum, they tend to take a set after a ride or so.
Cowardlyduck   10 MW
Post by Cowardlyduck » Mar 12 2018 2:16am
For those with a Fighter who want to know how their 2 speed gear works, have a watch of this. It popped up in my youtube feed today:
It's not exactly the same as the 1:1.65 unit used in the Fighter, but it's basically the same with the planet gears being located on the outside of the BB instead of inside a hub.
Cheers
Modified Stealth Fighter - Force air cooled motor @ 6KW, Adaptto Mini-E. 49AH, 52V 18650 - 2.5Kwhr
deemos   10 µW
10 µW
Post by deemos » Mar 12 2018 8:53am
Hi all,
Can anyone tell me what settings I should use for different types of riding for shocks and compression?, IE: Jumps,speed, etc.
Any help is greatly appriciated in advance.
DunkenKBliths   100 W
Post by DunkenKBliths » Mar 12 2018 8:25pm
Anyone got a clue.. ?
Fully charged battery (B52) - 150 cycles only (new battery)
Went to start out for a ride today.. to find it started and as soon as I started to ride pull the accelarator it kills the power...
the digital display drops to low point and then bike is non respondant....wait a 5 seconds can do the same thing...
Appart from a "pull sides off" and disconnect the battery, for a reset......anyone got an idea..
I have over 40,000kms of use of this bike...and never seen this...todate...
DUNKEN K BLITHS / crazy goole+ animator...
https://plus.google.com/u/0/101241183982769454084/posts
DunkenKBliths   100 W
Post by DunkenKBliths » Mar 13 2018 3:18am
After messing around got it working intermitantly... which leads me to believe its the hall effect plug
anyone know where the heck I can get both of these ?
Looks like one of them has come adrift...corroded...
DunkenKBliths   100 W
Post by DunkenKBliths » Mar 13 2018 3:19am
Also need to know what wire is attached to what !!! .. anyone got that info ?
Cheers Dunk
Allex   1 GW
1 GW
Post by Allex » Mar 13 2018 11:53am
But try to find another plug, the stock one is not that water tight
Mattof37   1 mW
Post by Mattof37 » Mar 13 2018 2:30pm
Hi guys,
After a bit of advice , looking to get a bomber control and the bomber Dc1 computer on to my fighter, where if possible can I get a battery with the same power as the bomber that would fit in the fighter?
Has anyone else tried this?
Thanks in advance.
Trelos   1 mW
Post by Trelos » Mar 14 2018 4:23am
DunkenKBliths wrote:
Mar 13 2018 3:18am
Ive got some new spares and im in SA
ygpm
Stealth bomber ,PowerVelocity 24 fet ,17kw
Stealth fighter, 96v lipo
DunkenKBliths   100 W
Post by DunkenKBliths » Mar 14 2018 11:21pm
thanks guys... hoping fixing this plug is going to fix the issue...
I ordered a set from Stealth in the end...as needed to get the bike going ASAP..
Theodore Voltaire   1 MW
Post by Theodore Voltaire » Mar 16 2018 11:11am
Mar 14 2018 11:21pm
The first time I washed my bike, it ran the same as yours. I thought I had ruined it. It took 2 days to dry out, and after that it was fine again. I always figured that hall plug was the culprit. From then on I was always careful not to get it wet.
Last summer my son, and my best friend rode our bikes downtown about 20 miles away. My son was riding his B52, and Bruce, and I were on our lowly Storms. We stayed out late, and had a lot of fun. Finally, drunk, stoned, and full of pizza, we headed home long after midnight. About 5 miles into the return it started pouring rain. At least it was warm, so we soldiered on. 10 miles later guess who's expensive ass bike stopped running. I'll give you a clue, it wasn't the cheap ass bikes that come from deepest darkest china with all waterproof connectors.
My son was really pissed having to pedal the last 5 miles in the rain, while, me and Bruce kept on truckin. After sitting in my garage overnight, his bike ran fine the next day.
Allex   1 GW
1 GW
Post by Allex » Mar 17 2018 3:26am
Yep, see what the legend have to say about it:
http://www.ebikes.ca/learn/connectors.h ... 045-series
"At one point a decade ago Crystalyte switched from using the JST-SM connector for their hall signals to a metalic round 5-pin plug that was erroneously referred to as a "mini XLR". There actually is such thing as a mini XLR plug, but this particular connector seems to be a knockoff of a Japanese made Tajima connector. At first glance it seemed to be a high quality contact, but in practice had no practical advantage over JST connectors, tended to corrode with exposure, and was a pain to solder. We stopped dealing with these plugs a long time ago, but many other Crystalyte vendors continue to use them."
Post by Theodore Voltaire » Mar 17 2018 4:21am
These lowly German connectors come on the cheap Chinese bikes.
https://e-bike-technologies.de/index.ph ... connectors
Mattof37   1 mW
Post by Mattof37 » Mar 17 2018 3:58pm
Any battery builders / suppliers on here?
Or can anyone recommend?
Thanks Matt
Post by Theodore Voltaire » Mar 17 2018 4:56pm
Mattof37 wrote:
Mar 17 2018 3:58pm
Thanks Matt
Just ask for Allex
Cowardlyduck   10 MW
Post by Cowardlyduck » Mar 17 2018 5:21pm
Mattof37 wrote:
Mar 17 2018 3:58pm
Thanks Matt
Depends where your based. I can help you out if you are in Aus.
Cheers
Mattof37   1 mW
Post by Mattof37 » Mar 18 2018 7:02am
Hi,
I'm in the UK, ?
Mattof37   1 mW
Post by Mattof37 » Mar 20 2018 4:43pm
Alex,
I should be able to arrange postage collection from my end if you are ok with this?
Thanks Matt
LockH   100 GW
Post by LockH » Mar 20 2018 10:16pm
Hehe... In this thread "Search found 13 matches: Clone"... per Wiki:
Charles Caleb Colton (1780–1832) was an English cleric, writer and collector, well known for his eccentricities.
... and:
One of Colton's most famous quotes: "Imitation is the sincerest [form] of flattery".
CL orange co > for sale > bicycles - by owner
8000 watt Stealth Bomber Clone - $4800 (Santa Ana):
https://orangecounty.craigslist.org/bik ... 53045.html
:lol:
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
Hyena   100 GW
Post by Hyena » Mar 20 2018 11:59pm
it has the power to handle any kind of terrain.
Except it has zoom forks, so you'd best not take it off more than a tapered gutter :lol:
www.HyenaElectricBikes.com
Allex   1 GW
1 GW
Post by Allex » Mar 21 2018 4:51am
Mattof37 wrote:
Mar 20 2018 4:43pm
Alex,
Thanks Matt
PM me if you are interested. I will be getting new cells soon and can start a build for ya.
Rix   100 GW
Post by Rix » Mar 21 2018 7:38am
Hyena wrote:
Mar 20 2018 11:59pm
The best component on that bike is the QS273.
redline2097   100 W
Post by redline2097 » Mar 21 2018 3:48pm
Rix wrote:
Mar 21 2018 7:38am
Hyena wrote:
Mar 20 2018 11:59pm
And that's the second reason to not handling every terrain. :D
