Can sticky threads be put in their own subforum?
This section will contain posting guidelines for the forum along with any other information that is relevant to this forum.
CGameProgrammer   10 kW
Post by CGameProgrammer » Mar 02 2009 12:44pm
I think some forums have way too many sticky threads; you have to scroll down to view the normal ones, which is usually the ones you care about. It would be nice if the stickies could be grouped up somehow and moved out of the way. Another option, but one that probably requires programming, is to have an account option that hides stickied threads that haven't been updated since the last time you read them.
knightmb   100 kW
Re: Can sticky threads be put in their own subforum?
Post by knightmb » Mar 02 2009 2:05pm
CGameProgrammer wrote:I think some forums have way too many sticky threads; you have to scroll down to view the normal ones, which is usually the ones you care about. It would be nice if the stickies could be grouped up somehow and moved out of the way. Another option, but one that probably requires programming, is to have an account option that hides stickied threads that haven't been updated since the last time you read them.
I think in the mean time, just moving some of the stickies out of the way is a good idea. The hiding stickies with account settings will take a little longer. :D
Ypedal   100 GW
Post by Ypedal » Mar 02 2009 2:12pm
Stickies tend to be section specific, having them all in one section could be confusing.... hard call...
ES site status page:
Post by CGameProgrammer » Mar 02 2009 2:15pm
Actually I meant a subforum of each category just for stickies, at least temporarily to get them out of the way. So under "E-bike Technical" would be a "Stickied Threads" subforum. Probably a better idea is to make it a child of the root category: General, Electric Vehicles, Electric Bicycles, etc.
johnrobholmes   1.21 GW
1.21 GW
Post by johnrobholmes » Mar 02 2009 7:29pm
Another method is just one Sticky to point to all the stickes in the subforum. It reduces clutter and you have have 100 stickies at the top in the one stuck thread.
Post by CGameProgrammer » Mar 02 2009 7:56pm
Actually that's probably the best idea as well as the simplest. So basically each forum has only one sticky thread, which contains links to the other previously-sticky threads (which would be unstickied).
1.21 GW
Post by johnrobholmes » Mar 02 2009 8:04pm
i really just see one forum with more than a few stickies, ebike technical. They aren't really related threads either. Would hiding them cause more confusion?
Toorbough ULL-Zeveigh   100 MW
Post by Toorbough ULL-Zeveigh » Mar 02 2009 8:18pm
except for the locked part, how is it any different from this?
particularly posts 4 & 11 which turns out was very forward thinking.Image
might also serve as the home for the repository of a smilie superset.
fechter   100 GW
Post by fechter » Mar 02 2009 8:34pm
In a way, that's what I had intended the technical reference forum to be.
When I get time (who knows?), the plan was to take an edited version of those stickies and put them in the reference section, which is locked. The original thread gets unstickied and floats to the bottom eventually.
bobmcree   10 kW
Post by bobmcree » Mar 07 2009 3:12am
personally i find the stickies annoying and think they should just be done away with altogether. it is becoming increasingly difficult to skim through the topics to see what has seen the latest interest. One central place for all the stickies would be my vote, or maybe just some segmentation delineating the start of the current topics with the stickies above it. of course it is just one vote among many.
I do not approve of this group any longer and regret what it has become. I could once share ideas here freely that is no longer possible.
TylerDurden   100 GW
Post by TylerDurden » Mar 07 2009 9:52am
bobmcree wrote: it is becoming increasingly difficult to skim through the topics to see what has seen the latest interest.
Folks can use the "view active topics" link at the top of every page... It's much more efficient.
Code: Select all
http://endless-sphere.com/forums/search.php?search_id=active_topics
Have a Nice Day,
TD
FYI: Adding pictures?
bobmcree   10 kW
Post by bobmcree » Mar 07 2009 12:57pm
good idea, thanks. i don't know how much trouble it would be to insert a blank line or two between the stickies and the rest of the posts that would certainly help some of us. Sometimes i try to keep up on a small portable unit and it is difficult to tell the icons apart when they are so small.
