haibike sduro with 150mm/150mm suspension and 27,5" x 2.8" plus magura mt5
Sduro Ultra
10 µW
Hey guys,
i am new member here, but i red some threads before. my bike is a haibike sduro with 150mm/150mm suspension and 27,5" x 2.8" plus magura mt5.
i have a bafang ultra with a 52v 17,5a battery and a 4a charger which i modified, because it was very loud (put two 4000 1/min fans in instead of 1 8000 1/min fan).
i already installed the programming software and changed the "spd0 start(kg)" and "return(kg)". it worked well. i want to change a bit more, i just started. when i stop pedaling the motor pushes about a second still forward. i want it to react more spontaniously.
i think the "0 speed boost time" [120] (x10ms) will change this behavior. do you agree with me?
can someone help to get the best configuration?
thanks for exchange
Sduro Ultra said:
Hey guys,
thanks for exchange
I thought Haibikes used Bosch or Yamaha motors?
woggs1 said:
Sduro Ultra said:
Hey guys,
thanks for exchange
I look at Haibikes website, they didn't offer bike with Bafang Ultra M620 or their new range of product? Bosch or Yamaha couldn't hold a candle to the performance to the Ultra and on different league.
View attachment 1I modified the frame to fit and weld the bafang motor plate in and i am not the first one doing this with a haibike sduro. Its a nice conversion.
Have a good ride
Sduro Ultra said:
20180319_173012-02.jpegI modified the frame to fit and weld the bafang motor plate in and i am not the first one doing this with a haibike sduro. Its a nice conversion.
Have a good ride
Nice, where do you bought your Kit from? If from Luna for Ultra Ludicrous 2500 watts, you might want to follow Karl
https://electricbike-blog.com/2017/11/23/i-void-warranties-hacking-the-bafang-ultra-max-mid-drive-ebike-drive/#more-6836
