E-bike + downhill frame + Mxus hub motor + 24s lipo
soaresdacosta   1 kW
Re: E-bike build + downhill frame + Mxus hub motor + lipo
Post by soaresdacosta » Mar 26 2018 3:20pm
I buy some wires from Amazon, arrive very well packed and everything ok...but take 1 month to arrive...Jesus. :?
nmilanche   100 µW
100 µW
Post by nmilanche » Mar 27 2018 2:09pm
Next time buy directly...not via Amazon ;)
https://www.aliexpress.com/item/30m-22A ... autifyAB=0
Good job for now...downhill frame is always problem for fitting good lockig and big capacity battery box.And if you want the battery to be removable for charging outside the bike ( my e-bike project ) ... that's a big big problem :)
soaresdacosta   1 kW
Post by soaresdacosta » Mar 27 2018 4:36pm
Hello ev fans,
nmilanche, welcome to the forum.
Thanks for the tip. :wink:
My battery, will be removable. I want to charge, and store, in a safe place.
Just take some pictures, and show your build.
In the meanwhile, I start to install the pre-charge resistor...no sparks.
Luís.
nmilanche   100 µW
100 µW
Post by nmilanche » Mar 28 2018 3:58pm
Thanks for welcome! ;)
I will put some pictures soon...I am bulding 2WD e-bike, but for the start it will be rear hub 1500W...downhill frame...removeble batt pack 48v/cca 26Ah...
I am palning to use XT90-S (anti-spark) connector. It has built in resistor...
How do you connect that resistor? You only need him in a little part of a second...then you must disconect resistor...
Regards!
Milan
kachou   1 mW
Post by kachou » Apr 01 2018 12:57pm
soaresdacosta wrote:
Oct 20 2017 2:01pm
Hello guys,
Kachou, thanks. Glad you fell inspirarion. Just start. Do you have a frame ?
Hi Soares,
Just got my frame... you cannot imagine what I did to get the same frame as you... I bought a berg viper on a second hand website in Portugal (OLX.PT) and had a friend bring it to me in Paris when he travelled to Porto by car... :mrgreen:
I will start my own topic and hopefully can get your feedback
Thanks and Keep up the good work!
soaresdacosta   1 kW
Post by soaresdacosta » Apr 01 2018 4:15pm
Hello crew,
nmilanche, the pre-charge is a replica from my first bike. Work very well. I have a switch, turn on momentary, and then I can connect the positive wire. I do not have much luck, with the anti-spark connectors on the market .
More work on the next 2 days.
Luís.
soaresdacosta   1 kW
Post by soaresdacosta » Apr 01 2018 4:20pm
Hello,
kachou, really ? Im from Porto City. If I now, I should help.
Well done men. Its a nice frame. A bit small for the batteries...but...
Your first major transformation...torque plates. I have the drawings, if you need.
Just start a build page.
Luís.
soaresdacosta   1 kW
Post by soaresdacosta » Apr 02 2018 4:09pm
Hi guys,
Today, I was working on my key switch and by accident I damage my carbon cover.... :x :x Almost cry :x :evil: I stop everything, go for a walk and wen I return, I don't now how, but i manage to fix it. You just see a junction line, but even that, its gone be cover by the top-tube. What a relieve. :wink: :wink:
And my 30amps, various colors, anderssen connectors, arrive today. Its for the halls sensors connections and others small amperage connections.
Luís.
kachou   1 mW
Post by kachou » Apr 03 2018 10:48am
Apr 01 2018 4:20pm
Hello,
Luís.
Hello Luís
I just started my build page:
https://endless-sphere.com/forums/viewt ... =6&t=93615
- it's an exciting project.
I will have a lot of questions for you!
I am thinking of starting with a mid-drive (if the bottom bracket allows), so no Torque plates for me right now.
Talk soon!
:wink:
soaresdacosta   1 kW
Post by soaresdacosta » Apr 03 2018 5:00pm
Hello crew,
kachou, really glad for you. Enjoy the journey... 8)
In the meantime, Im really happy with the anderson connectors. They give a fast, reliable, no mess around, and beautiful connection..
Luís.
soaresdacosta   1 kW
Re: E-bike + downhill frame + Mxus hub motor + 24s lipo
Post by soaresdacosta » Apr 15 2018 3:37pm
Hello crew,
Start the final battery box assembly... start to put all the cables inside. Its a lot of cables...and fat ones.
Luís.
Vortecks   100 mW
Post by Vortecks » Apr 15 2018 8:55pm
I like the word "final", it makes it sound like it's nearly done :D
Vortecks   100 mW
Post by Vortecks » Apr 15 2018 9:27pm
I won't flood your superb thread with loads of photos but.... To give you some inspiration and drive to get it finished, here's mine now it's finally how I want it.
I've still got to do an update video because I've changed a lot since the last video but here's the YouTube playlist.....
https://www.youtube.com/playlist?list=P ... lj0LHdCG7S
soaresdacosta   1 kW
Post by soaresdacosta » Apr 16 2018 2:56pm
Hi guys,
Vortecks, yes. I use that word, to make me feel better :D :D I really want to finish this. I have a change in residence in near future, and I want this finnish by then.
With a quality build like yours, you can put many photos, as you like... its really nice. I follow your channel on YouTube.
Take care.
cheeko   10 W
Post by cheeko » Apr 16 2018 7:23pm
soaresdacosta And Vortecks.
I love both your builds and has given me insperation to start my build iv had my bike for 5 years for this idea i would make it electric. I will be going with Giant AC3 dual Suspension, Lyen Controller just ordered just bits a pieces.
Thanks again guys, hope you all like my build when i finally start it probably wont be smooth sailing.
Cheers
Cheeko
24s5P Futr Beta Mxus3k with 24Fet Powervelocity controller (quick)
soaresdacosta   1 kW
Post by soaresdacosta » Apr 18 2018 3:36pm
Hello guys,
cheeko, welcome to the e-bike world...and to the forum...and to my thread... :D Im really happy, my build was an inspiration to you.
To give you some extra inspiration...
Luís.
cheeko   10 W
Post by cheeko » Apr 18 2018 6:36pm
Thanks Soaresdacosta
I have just ordered all parts, have my Hub on way and controller, Sticking with Lyen for now and probably run 24s Lipo's But i think ill go the fancy batteries in the bag thing, Legal limit in Australia is only 250w so dont want to much attention with be box.
How do you find it to pedal without any power, as i couldn't fit cassette i need to do same option.
Can i ask about chain used etc.
Thanks again for pics.
Peter
Vortecks   100 mW
Post by Vortecks » Apr 19 2018 1:58am
cheeko wrote:
Apr 18 2018 6:36pm
The legal limit in the UK is also 250w. I have a sticker on my motor that says "Bosch 250w 24v". In reality, I'm pulling 15kw :D
cheeko   10 W
Post by cheeko » Apr 19 2018 7:52pm
Vortecks wrote:
Apr 19 2018 1:58am
cheeko wrote:
Apr 18 2018 6:36pm
Yeah, ill have to do that are you pulling 15KW out of the Mxus 3K and you have the Sabvoton controller?
What amps is she pulling @ 24S
I have watched your videos on Youtube, gets cold over there hey :)
And hows the thumb :(
Cheers
Peter
Vortecks   100 mW
Post by Vortecks » Apr 20 2018 2:06am
I don't want to hijack this thread but.....
Cold? It's a balmy 24c today. Probably gonna snow now I've said that.
I'm now running between 12s and 20s (via removable bus bars). According to the CA shunt, it pulls 170a before the breaker trips (it's actually a 125a breaker). The Sabvoton will give out a lot more than it states and the MXUS will handle the power but only for very short (5 second) bursts before it overheats. I'm not fitting any extra cooling because it'd make me leave my brain at home all the time :D
This thing is now at the absolute maximum of ability - the acceleration is so brutal, I can't get my head over the handlebars enough to keep the front wheel down. If I go any further forward, I leave tyre marks down the road.
soaresdacosta   1 kW
Post by soaresdacosta » Apr 20 2018 4:02pm
Hello crew,
cheeko, in here (Portugal) its the same 250watts. I will use (not install yet) a chain, normally use in BMX bikes. In the rear I use one speed free-wheel, and one speed in the front. No gears change...no need to that. Pedal this bike...forget about that. The pedals is just for legal purposes.
Luís.
Vortecks   100 mW
Post by Vortecks » Apr 20 2018 4:37pm
You attention to detail is faultless, Luis.
I'd love to own a bike that you've built but I certainly wouldn't want to pay you to build one. The cost would be massive! (there is a compliment in there somewhere) :D
soaresdacosta   1 kW
Post by soaresdacosta » Apr 21 2018 4:47pm
Hi guys,
Vortecks, thanks man. From a builder like you, it mean something...
Working in extend the controller wires. They are too short...
Luís.
soaresdacosta   1 kW
Post by soaresdacosta » Apr 22 2018 2:46pm
Hello crew,
Just trying to finnish...
Luís.
soaresdacosta   1 kW
Post by soaresdacosta » Apr 29 2018 4:03pm
Hello crew,
Working on small stuff...this time, is extending the wire from the Magicshine back light...
Luís.
