72 vott e-bike
Here is a mock-up of the pannels with battery box on the frame
before all the work
HOLY S**T 600 amp
https://www.aliexpress.com/item/8000W-APT-Sine-Wave-Brush-less-Hub-Motor-Controller-96600/32794155443.html?spm=a2g0s.8937460.0.0.6g00yd
I wish mine was 10cm longer like yours. Charge me something close to the original frame price and I'll buy 10-20 of the frames.
https://nsmb.com/articles/gary-fisher-e-mtbs
Uphillflow from the original mtb man
Hi all quick update rewired the motor and used white heat shrink with black braided over the top :D
Also purchased lights EL panels for sides light slots and chase wire from frame to motor.
will post pictures at end of build sorry needs must and all :idea:
this is the chase wire http://elwirecraft.co.uk/el-products/chasing-el-wire/chasing-el-wire-2-3mm-with-smooth-chasing-motion-effect/
and this is the EL panels http://elwirecraft.co.uk/el-products/el-panel-categories/el-panel-5cm-x-8cm/
I'll take some pictures of the chase wire when the battery's turn up :oops:
ps the chase wire will be a video
and here is the braided wires
Hi I can't seem to up load the video here so here is a link to the chase wire
https://www.pinkbike.com/u/the12be/channel/lights/
as you can see I can speed it up and slow it down and can also make it go both ways
I will be using transparent heat shrinking to add the chase wire in with the power and phase wire's :D
Update I have just ordered a speedometer but will not be able to show pictures until I finish the build :(
But it should look like this :
Hi all it's been a long time coming but here is a pic of my bike it's 4 feet tall and 2.10 meters long it's still not finished
Thanks soaresdacosta.
I can't wait to finish it should come togather fast know new 800lb titanium spring on the way and the wiring up should be easy hope my lights look the way I think they will :D
here is a update made I rear floating mud guard used 4mm alloy and the front of a top peak xc1 to make it also vinyl wrapped the arm in carbon fiber
can't seem to sort out the one near the spring tried with plastic too make it stronger but no luck :(
sorry also added a 800ib ti spring
