eyebyesickle
John and Cecil said:Maybe it does support a throttle, a seller on aliexpress has an entire package including motor and throttle and vlcd6 (but no brake handles)...
Yes, even when 'hard wiring' a throttle with the xh18 display, the brake signal actually interferes with the motor/display functions... so thats a thing... beware also, the 'hard, or forced' wiring of a throttle from an 8 pin controller, to a 6 pin display can cause your controller to burn up... as I mentioned above
