casainho
10 GW
- Joined
- Feb 14, 2011
- Messages
- 6,043
I tested again now with the PAS detecting that torque sensor magnets disk but the issue persist.
This new idea will make the need to solder more 5 wires, while using a PAS you don't need to solder.
Also adding the PAS, the code is already developed and tested.
If you need a PAS, please ask me and I can send you one fast, as I bought a few of them as spare parts.
Thanks for the info. I think you are correct and I saw with attention your graph and code. I think is possible but it needs tuning and filtering, as you do in your code. The filtering means it is slow to detect the inversion and it not always happens at the same magnet/pedal position, so the user can always have different results and is no good for what we want to achieve: precise control for ebraking.stancecoke said:I agree, that there is much scatter in the signal, but the algorithm can handle it. Even with the stock firmware of Lishui and Kunteg, you have to choose the right settings for your specific PAS.
These will make a risk to damage the original torque sensor disk, that we can't buy as a spare part: torque sensor $50 VS PAS $2.stancecoke said:Perhaps you can try to remove every second magnet from the PAS disc, then the signal should be much better.
Why the need to avoid adding a PAS? PAS costs only $2 and you can buy it at and the same time when you buy this torque sensor.stancecoke said:Another smart possibility to avoid an additional PAS is to solder in a 5-core cable und connect the additional wire from the second PAS-Hall to X4.
