automan25 said:Is there a way to disable PAS in our systems, but still have the throttle work? I'm pretty sure there is. Anyway, that would be a way to get around the issue with the throttle not working progressively while pedaling.
Yes. If you open the controller and cut or disconnect the GREY wire going to the PAS sensor, the PAS will be disabled and the throttle will work properly. That's what I did on mine. I suppose you could wire up a switch to make this selectable.
