casainho
10 GW
- Joined
- Feb 14, 2011
- Messages
- 6,037
Would be ok for me. But I think that if we can agree on having only one and trying to discuss new features being rational, would probably make it stronger.geofft said:Guys, can I make a small suggestion here?
It's clear that you both have differing ideas about the way some things should be done - that's completely normal with intelligent minds of course.
Would it not be best to develop this as two separate 'master' branches (maybe stancecoke master and casainho master, (call them what you like) to prevent 'treading on each others toes'. You would still be able to exchange ideas and code between yourselves, and it would be good for end users to have different options to see what works best for them.
I would be perfectly happy to test and feedback on all available options I have hardware for, I'm sure new takers coming along would also be so.....
I feel that TSDZ2 motor users are in a big number, probably because the system already has torque sensor and has a clean install. Also this type of motor is easy to install on cargo ebikes, etc. And because there are almost no combinations of hardware; firmware program can be done without soldering wires and open the controller; original firmware is available, I am curious to see the adhesion of users to use the OpenSource firmware. The controller hardware and available firmware is even more limited than Kunteng controllers and so the differentiation / added value can't much big.
