adamsavage79
Question. How easy or hard would it be to build a battery pack, using Headway 38120 screw top cells ?This would get rid of the need for soldering. On paper, it seems quite bit cheaper, vs buying a premade pack. I have a pack that has new and old cells mixed, and defective BMS that tends to kill cells, in the exact same spot. So I could salavage some of the wiring from it, like the XLR plug and the discharge port.
If the BMS comes with simple wiring directions, it looks like it would be a simple process. I could use the existing pack, as a reference point for how the cells should line up. I guess the harder part, would be finding high qaulity Headway cells.
