Dui said:999zip999 said:#1 safety. Yes I found the high quality of these cells is the #1 they stay balance just bulk charging. What is the source for these cells and how much will you be paying ? I understand the need for a strong battery with that bike. What motor and controller do you run. Nice ride. Taking the let out and putting some high-powered cells in you would have a hard time keeping the front wheel down
I'm using a 3000W QS motor and a software unlocked version of the sabvoton 72150, currently set up at 200 Amps continuous.
That's nice but not really amazing in terms of perfs so far. About an equivalent to a 125 or 200cc bike I guess.
I plan to make some mods to the sabvoton, using shunts to the current sensors to hopefully go around 300-400 Amps if it can actually go that far (still have to open it to check the mosfets first).
In which case, of course, I'll add watercooling so that it won't explode instantly
First step is to get the right battery and then I'll upgrade the other stuff, probably change the motor etc.
Ultimate goal is to make a bike with comparable specs as a basic 400-600cc engine.
Just want to know how much fase amps are you pulling? And whats the max faseamps that a unlocked 72150 can handle?
