Cycle Analyst V3 preview and first beta release
Ok so it turns out that it was the gnd cable in the CA plug on the controller side!!!!
It had blown in half! wasn't even a trace!
But now the controller is doing strange things and I think one of the groups of fets are dead :(
I forgot to mention that when the CA died it went wide open throttle and ended up running into a wall and the motor locked up, it still spun this time when I got the CA working again but probably spun for 30 sec and then controller failure. (wheel cogging etc, only on 1 phase in 1 direction)
fwiw, if ground opens up on a hall throttle connection, it tends to create a WOT condition. If the ground that failed was the only ground between CA and cotnroller, and throttle went to CA first and then to controller, then when the ground blew it couldve caused the WOT runaway.
As for the controller, if the motor was unable to turn long enough and the controller failed to limit current or shutdown from detecting no wheel spin, it could definitely have blown FETs. You can test them via the info on ebikes.ca learn tab, troubleshooting pages.
I finally got my Sempu installed on my daily commuter, and I noticed some odd PAS behavior, and so I looked through the manual and saw:
"In all modes, if throttle is applied even a small amount while pedaling, PAS assist is ignored and the throttle alone determines the output."
It would be nice to have the option for the maximum of the two to always be chosen. Having the PAS assist drop out whenever the throttle is returning to it's default/0 position feels pretty clunky - like the bike is dropping and surging for no good reason. My wife's exact quote when giving the bike a try was "Bionx this is not."
-- since nobody has replied, a quick edit to specify the use case: If I'm crossing an intersection and want to scoot across a little faster, I might hit the throttle while pedaling. I continue pedaling after crossing the light, release the throttle, and I'd like the assist to remain proportional to my pedal effort, and not drop below and then jump back up as I release the throttle.
Having throttle deactivate PAS is very handy when navigating peds, handling intersections, etc where precise control is necessary and an extra push on the pedals might otherwise cause an unwanted power application in tight or dangerous quarters. The alternative would be to force the user to manually deactivate PAS in these situations which would be an invitation to mishap.
The problem you are having is due to the PAS system relying on the Power PID controller which gets suppressed when you go to PassThru throttle mode. This makes it necessary for the power PID controller to wind up again when you release the throttle. If you have an aggressive DownRate, then the applied power due to throttle PassThru mode may drop before the PAS Power PID can wind up to reapply PAS power. You can go after this a couple of ways:
  1. Reduce DownRate so that power is removed more slowly. This will give the PAS system a bit more time to come up to speed.
  2. Switch to using Power Throttle. This will make the PAS and throttle use the same PID controller and the power will transition smoothly when switching between the two. Throttle response will also be much more linear and controllable than with PassThru.
Presumably you have WGain set pretty low anyway so PAS power is applied smoothly without a lot of jerking around. PasRate can help take the edge off power application, but general smoothness is strongly affected by WGain which controls how fast the PID controller tracks changes in pedal effort.
Anyhow a couple of things to try...
Thanks! Those settings did help quite a bit. I moved my PAS up rate from 4 v/s to 2 v/s, and the down rate from 4 v/s to 2 - but to be honest, I find it pretty unnerving when the motor pushes for more than a second after I've stopped asking it to. There's probably some combination of a middle ground value and just time getting used to it.
If in those same tight quarters you stop activating the throttle and bump the pedals, isn't it just as dangerous? It seems like there's several solutions available to mitigate that already in the PAS settings. Especially on a bike with a torque sensor.
Do you think anyone who is producing a steady Hwt would ever have the expectation that touching the throttle would reduce the power output?
2v/s is very slow for a DownRate. Although you may have achieved one goal, I think you need to explore other setup strategies that don't so markedly interfere with the stop-pedal delay.
PAS will not engage unless you actually pedal - 'bumping' the pedals does nothing.
That's helpful! I changed that and the throttle mode at the same time. I'll try going back to 4 v/s down and seeing if the throttle mode alone does the trick. It's less clear to me what I'd do with wgain - there's no weird oscillating if I'm all throttle or all PAS, so it seems like it's probably fine.
My point was that if your protection from accidental PAS acceleration is that you have the throttle activated, that safety goes away as soon as you let to of the throttle, which may well still be in a crowded situation.
I don't think that's really an argument for why it shouldn't be an option that can be chosen, but I'd totally buy it if you told me that it's baked into the code and not particularly practical to make it optional.
I ended up tweaking my PLL settings for the Phaserunner, as well as going to a very low wgain, and it's definitely going in the right direction. I'm still trying to figure out the right size dead band to have on the aux pot so that I can set it to not assist at all, and the other morning it was sitting at .2x rather than going down to 0, and initially I only noticed because of the CA display.
I've noticed a couple of things that seem odd.
After using the throttle, sometimes all it takes is a weight change on the pedals and the motor will jump up to ~200 watts for a moment, even if I'm on a fairly low assist multiplier. The Hwt I'm producing during that weight change are below my "Assist Start Level" of 35 watts - so I'm surprised that the motor is turning on at all, but then it also seems to be applying a power at something like an 8x multiplier, even if I'm set at something more like 2x.
I've also noticed that the relationship between my human wattage and motor wattage being mismatched in the other direction under more normal usage, like, when I'm set for 7x and producing 100 Hwt, I might only see 500 watts as the power reading. Does that mean I have something configured incorrectly, or is it not necessarily intended to be a perfectly 1-1 kind of thing?
I'm still trying to figure out the right size dead band to have on the aux pot so that I can set it to not assist at all...
The default values should work fine. However, if the % shown on the AuxA Preview screen does not go from 0-99% as the pot is turned min to max then follow one or both of the procedures below:
Setting the Lo Deadband:
  1. Turn the pot to the minimum
  2. Set the LoDeadband to 0.00V
  3. go to the AuxA prefix screen and check the %Limit.
    If non-0 then increase deadband in 0.01V steps until the %Limit goes to 0.
  4. Increase the deadband by 0.1V
Setting the Hi Deadband:
  1. Turn the pot to the maximum
  2. Set the HiDeadband to 0.00V
    If not 99% then increase deadband in 0.01V steps until the %Limit goes to 99%.
I've finally managed to configure the CAv3 with firmware 3.1b to behave like I want to, except for the throttle response when riding. I had to employ strict throttle ramping to prevent the bike from flipping backwards when accelerating from a standstill so it's no longer dangerous and takes off smoothly, but that also means a sluggish throttle response when riding. I think I should use UpRate and FastRate for this, but I'm not sure how to set them. The UUG seems to suggest they are used for the opposite purpose:
• FastRate is similar to UpRate and is typically set to a faster rate. Values of 4-8V/s are typical.
• FastThrsh sets current at which the CA switches from FastRate to UpRate.
• If FastThrsh = 0.00A, FastRate is ignored and UpRate is always employed, otherwise:
• When current is less than FastThrsh, the CA uses FastRate to quickly advance Throttle OUT to the point where the motor is bearing load. When already underway, this shortens the ramping delay that would otherwise occur if using the slower UpRate ramping.
• When current is equal to or greater than FastThrsh, the motor is bearing load and the CA switches to UpRate to apply slower ramping.
FastThrsh should be set higher than the current necessary to accelerate the unloaded wheel to maximum rpm. This is always greater than the maximum unloaded current. Setting the current too low will cause the CA to prematurely switch to UpRate. Typical DD values are 0.5-1.0A, gear motor values are typically 2-4A.
How can I use these features to get a conservative throttle ramping from a standstill but a quick one while riding?
brickwall said:
I've finally managed to configure the CAv3 with firmware 3.1b to behave like...
Although you don't specify which beta version you are using, you should really upgrade to the production 3.1 release which has the issues repaired that were discovered in the beta versions.
FastRate is really designed to be of assistance with drivetrains employing a freewheel clutch so the motor could spin up to speed rapidly and then regular ramping would take over after the clutch engages. There is no mechanism in the CA to alter UpRate at speed.
I suggest that you switch to Current Throttle so the throttle control is more disciplined at low speed which should not require such strong UpRate limiting. You will need to adjust AGain which will again have effect over the entire speed range - low values can make the throttle a little laggy so it's a balancing act.
A complimentary strategy is to reduce the phase current limit of your controller which will only have effect at very low speeds. By reducing the aggressive motor behavior at low speed, you won't need such aggressive settings in the CA and CA operation won't have such an adverse effect at higher speeds. Although reducing the available motor torque off the line (max phase amps) may seem Bad, if you are suppressing use of it through CA settings, then the high phase current limit isn't really being used anyway - you're just limiting it indirectly via the CA and paying a price for making the CA do the controller's job.
Done and done! I just brought out my bike after a long Swedish winter.
I use power throttle in one of my three modes, for smoother acceleration. I will experiment with current throttle to see if that's even better. The really dangerous bit is passthrough throttle with no power limiting. Fun, but scary.
This is probably what I should do, though I need to open up the controller and do some soldering in order to be able to program it. I love the simplicity of the CA.
As always, thanks for your suggestions, teklektik. Very helpful!
EDIT: Yup, changing to current throttle was a much better solution. I could remove the throttle uprate limiting altogether after limiting current instead. Great!
Great this worked out. That said, I'm a little surprised that Current Throttle worked better than Power Throttle - they are essentially the same but Power throttle can work better for saggy batteries to keep throttle performance more constant over the discharge cycle.
I suspect that in your case you are seeing the differences in Current/Power Throttle behavior because of your AGain (Current Throttle) and WGain (Power Throttle and PAS) settings - perhaps with the AGain giving somewhat softer response...
Anyhow - no need to turn this into a science project - sounds like it's working fine so better to just be riding and enjoying it. :D
Thanks for posting back with results!
You're right. I've been tweaking WGain quite a lot but I don't remember even touching AGain since I haven't enabled current limiting or throttle until now. In other words, I should be able to achieve the same results by going back to power throttle/limiting and reducing WGain a bit. Maybe to the same level as AGain is currently at?
Tuning this thing to perfection has been so exhilarating, enjoyable and educational. Science project or not, I like to learn as much as possible. :)
Yep - that's the ticket.
I'm not sure about the relative values - I haven't visited that blob of code in a while...
That said, it can sometimes be useful to use Current Throttle if you have PAS so WGain controls the motor for PAS (soft response) and AGain is separate and controls things for the throttle (brisk response). This business is pretty subjective - but, more options... :)
while reading that: any update on "slow rate" feature? you remember? applying only a little throttle for really powerful middrives until all the drive train slag is gone, and then apply full throttle.
Hey izeman!
To be honest we've been swamped so far this year: big push to get out 3.1, push to get out 3.11, push to build the SolarAnalyst for Sun Trip 2018, and a couple of other custom firmwares. If we decide to move forward with the 'slow rate' feature, it won't be until later in the year at the earliest due to other things in the wind before then. I appreciate this is something that you'd like to have in hand, but it's a resource issue...
That said, 3.11 should be out very soon with a couple of fixes for some annoying bugs as well as a nice PAS improvement. :D
Justin should be posting up some stuff about the Sun Trip Solar stuff soon as well...
I updated my CAv3 firmware to enable the aux dig and aug analog seperate settings and I was running the Grin switch for PAS and a 3 speed to change the amps. Today out of nowhere the screen alternates between 55a 65a and 75a by itself then 3 speed cut out and stopped working and the PAS only works to change up but down does not function? Later today I had issues with the throttle cutting in and out and only the PAS input is constantly working? what the heck could be up with my CA?
brickwall said:
Ooooohhh what is this?
http://thesuntrip.forumactif.org/t510-progress-and-details-on-the-sun-trip-databox-and-solar-ca-code (images load very slowly)
https://endless-sphere.com/forums/viewtopic.php?f=6&t=93482
All part of:
https://www.thesuntrip.com/presentation/presentation-en/
Details to follow....
Hey ABINY-
I'm guessing that you have run into a bug in the 3.1 firmware that is addressed in the coming 3.11 release. My advice would be to roll back the firmware to a pre-3.1 release and then upgrade with 3.11 (next week?). PM me if you want to try an interim firmware solution instead.
Just a quick confirmation from you before I make anything dumb. :D
Does the Cycle Analyst supply battery pack voltage out from that 3.5mm headphone jack looking adapter?
So I could connect step down converter there and supply 12v to PAS, about 40mA.
It would be awesome that PAS would not use any sleep current. It would power on immediately when CA turns on.
I don't think I understand the question.
There is only one shunt setting for a shunt, and that's the actual shunt value.
(unless the value is too low for the low range and isn't accepted, in which case you have to switch to high range to enter it, basically moving the decimal point over one place in the various associated readouts).
