My Bafang Ultra Mountain Bike! Frey AM1000
Re: My Bafang Ultra Mountain Bike! Frey AM1000
We improved the screw cover for the bearing in black in better finish on surface as below:
We might finally be getting somewhere with the internal gear transmission NuVinci N380x announced last year. They changed the name to Enviolo see http://www.enviolo.com/en/groupsets/sportive
They have a representative in China
Fallbrook Trading Company, China (Shanghai) Asia, xzheng@fallbrooktech.com +86 21 51880352
Great find !
I was wondering what was going on with that...
Enviolo! This would be great, especially on a Frey M600 version.
I want the AM1000 with it
Thanks. Looks like plenty of room. I'm going wireless to avoid cable hassle and ease of swapping to another bike.Ivanovitch_k wrote: ↑May 28 2018 6:54pmthe straight part of the seat tube on the M-sized v2018 frame is 250mm, immediately after you've got an exit point for the dropper cable.Cruncher123 wrote: ↑May 28 2018 1:14pmCan someone please measure the seat tube to see if there is enough available non-constricted length?
Any Canadians/ Pacific Norther Westerners (Vancouver, Seattle, Portland) looking to join in on a shipping contain, let me know!
Canada
Canada
Im in Kelowna, and I would be interested. I was quite surprised by the very high shipping costs. Count me in if we can save by group buying.
2008 Full Suspension Giant Reign 2 with 48v 750W BBS02. Click Here
2014 Specialized Stumpjumper FSR with Cyclone 3000w Mid Drive, 52V 20ah Backpack Battery. Click Here
2019 Hybrid SUV 27.5 with Bafang Ultra Motor, 48v 14ah Battery. Click Here
How many bikes in a container? And is Frey discounting for bulk purchases?
Surprised they haven't set up a local distribution agreement with someone.
Bit of an update. New derailleur arm, replaced the shifter cable and hanger. Bought a suspension pump and adjusted the sag properly. All good. Frey are helping with the cost.
Bike rides very well. Lots of torque in low gear up very steep hills and plenty of speed on the flat. Had a little bit of surging on the flat when in one of the higher pas levels and a gear that was too low. Basically the motor would quickly spin up and then cut off at it's rpm limit, slow down then repeat. It sounds worse than it felt. It was quite minor and shifting up a gear or down in PAS level stopped it.
As for the lighting situation, it's going to be a bit more complicated than I expected. There is no room to pull the anderson power connectors out once the cover plate over the motor is removed from the frame. Looks like I am going to have to drop the motor out to get at the power cables. The motor to frame bolts are extremely tight and blue loctited. Going to need the heat gun and 1/2" socket drive set from work. I only have a 1/4 drive set here and that ain't going to cut it.
The lighting connection wires at the handlebar had no power when enabled by the display. I found the cable, jammed in above the motor, was disconnected. Plugged it in and as I suspected very little power is available (less than 100mA @ 6V). So I'm going to use this signal to switch the full battery voltage for my light. Just means finding an appropriate MOSFET (PSMN017-80PS looks like it will do the job). But getting the motor off is the first challenge. To be continued...
The mini DC-DC converter for my tail light has arrived (LM2596HVS from ebay - make sure it's the high voltage variant). A bit of nerve-racking Dremmelling and removal of the potentiometer (replaced with a fixed value resistor) and it all fits.
Imgur album here: https://imgur.com/a/9wK4dXk
- Ivanovitch_k 10 W
They are just torqued quite hard, but not that much loctite'd.Tom L wrote: ↑Jun 01 2018 3:22amThere is no room to pull the anderson power connectors out once the cover plate over the motor is removed from the frame. Looks like I am going to have to drop the motor out to get at the power cables. The motor to frame bolts are extremely tight and blue loctited. Going to need the heat gun and 1/2" socket drive set from work. I only have a 1/4 drive set here and that ain't going to cut it.
I used a 40cm (16in) 1/2" ratchet and got them unscrewed really easy. However, be warned that once the nuts are unscrewed, you still need to punch at the bolts real hard to push them out. Plus, with the heat gun you risk cooking / melting the motor's seals..
not normal. This should provide up to 500mA.
There is a second light connector, also 6V and also 500mA max (shared by both or not, I don't know...).
As to which connector, quoting myself from this thread:
If someone here knows the answer regarding the black connector, that'd be great !Ivanovitch_k wrote: ↑May 27 2018 6:46amDoes someone knows the purpose & pinouts of the ultra's connectors ? Also, their make/model would be useful
edit: found them, they are JST's JWPF series and are surprisingly IPX7 rated (i.e. no ingress for at least 30min under 1 meter of water) !
here is what I know so far, all viewed from motor-side.
What I suppose the black one does is connection to compatible BMS over UART or CAN. The motor would forward the BMS data to the display in order to populate the detailed battery info page (on dpc18 at least)
- 8-pin white female: main EB-bus -> throttle, ebrakes, display uart & power (programming cable attach here)
- 2-pin blue male & female: lights connectors, 6 Vdc out, 3W max / 500mA (for both or per cable, unknown)
- 3-pin white female: speed sensor
- 3-pin white male: gear sensor ? to be confirmed
- 4-pin black female: ?
BBS'ed Radon ZR Team 8:
BBS02B 750W - DPC750C - 48V 17.5Ah GA shark - 11 spd 11-40 Shimano XT, 42T N-W Precialps CW, KMC X11e chain, Gearsensor, XT RD, XTR Shifter, F Saint Brake, R XT Brake, RT99 200/160 Discs, magnetic shutoff, DT Swiss X1900 QR9 wheels, Manitou M30 air fork, 2.4" slick balloon schwalbe Super Moto X tires @2 bars, Suntour NCX suspension seatpost, ergon SFC3 saddle, ergon GP3 grips, Supernova M99 Pro + E12 Taillight
"If someone here knows the answer regarding the black connector, that'd be great !"
Just ask that thing from the bafang? http://www.bafang-e.com/en/service/contact.html "Do you have any questions about our products, services or the company BAFANG? Simply contact us. Our service team will deal with your enquiry asap"
It could have been entering some sort of protection mode because my light draws more than 500mA @6V. It's rated at 5.5W peak, so it was trying to pull nearly an amp.
Thanks for the warning about the motor seal. The heat gun I was talking about is for de-soldering SMT components so using a small nozzle I should be able to direct the heat exactly on the mounting nut. I wont go overboard, just enough to soften the loctite.
I am in Vancouver but I am waiting for the M600.
Is there a lights connector with permanent power, since the new EU regulation 168/2013 (type approval ) requires permanent light? And, is there a way to connect/implement "a brake light that lights up as soon as you start braking”?
[/quote]
[/quote]
Isn`t that for motorcycles not ebikes??
[/quote]
- DaninSpain 100 mW
- Contact:
Hi guys
I messed up and managed to get oil on my rear disk and pads. Not being particularly knowledgable about MB's and their components, I didn't think it was too much of a big deal, that is until I started to read up about it on the web.
So it looks like I'll need to change my pads. Trouble is, I've never changed disk brake pads before and I've not been successful finding a how to video on the Magura MT5 brakes to help me out.
Can anyone offer any help / advice? A step by step would be really nice, or if anyone knows of a YouTube video for changing pads on the MT5, which incidentally is different to the MT7, can you post the link.
Sorry for being such a dumb-ass re bike maintenance
The best things in life are not things
[/quote]
[/quote]
Yes, the EU168/2013 consideres ebikes to be "light" motorcycles
Anybody else had problems with the battery connectors? Really annoying when you get going and voltage drops under 40,gently slap on side of the battery and voltage goes back to 50. I've already changed both the connectors once and really don't want to do that again. Never had this problem with good old xt60's in BBSHD, this just drives me crazy.
Any good ideas how to keep the battery in place, rarely remove the battery so more difficult approach don't matter to me.
It's not rocket science luckily so even i manage to do itDaninSpain wrote: ↑Jun 06 2018 6:26am
Sorry for being such a dumb-ass re bike maintenance![]()
Take the wheel off. Take a look at the calibers, press them full open so maximum space is available. The pads are connected by magnets so just press first one side and slide the pad down. Then another one with same method. I also tried to find video about it but couldn't find so had to just try. But it's really easy and quick job.
- DaninSpain 100 mW
- Contact:
Thanks NataSnataS@phnet.fi wrote: ↑Jun 06 2018 12:27pmIt's not rocket science luckily so even i manage to do itDaninSpain wrote: ↑Jun 06 2018 6:26am
As it happens, I did exactly that earlier today and worked it out as I went along.
I removed the pads, cleaned with degreaser heated the up with a blowtorch to burn off the oil, then sanded them down repeated the whole thing. Took off the disk, soaked it petrol and gave it a good old scrub then refitted everything, looked down and found a washer
I couldn't work out from which side it came so I tried both and decided on the disk side.
The brakes were binding a bit, so I loosened the whole brake unit, applied the brake then tightened it. Hey presto no more binding (I'm sure all the experienced bikers are pissing themselves laughing at the newbie
Tried it out and all back to normal.
It's actually not as complicated as I thought this bike maintenance
Isn't enviolo a groupset for rear hub motor? I know only about Continental implementing their stepless automatic shift gearbox on the same enclosure of the mid motor: http://www.continental-bicycle-systems. ... rive-Unitsicehunter wrote: ↑May 29 2018 12:00pmWe might finally be getting somewhere with the internal gear transmission NuVinci N380x announced last year. They changed the name to Enviolo see http://www.enviolo.com/en/groupsets/sportive
They have a representative in ChinaFallbrook Trading Company, China (Shanghai) Asia, xzheng@fallbrooktech.com +86 21 51880352
- Ivanovitch_k 10 W
The connectors used by Reention do look cheap. Overall the battery retaining system is not great. Still a step up from bottle rivnut ones but far from bosch/yam/... models. Anyways most of China-designed e-bike battery cases are meh...
I've started browsing industrial connectors from the usual suspects (Amphenol, Souriau, TE, ...) to get suitable quick-disconnect replacements. Something with self alignment, spring loaded contacts maybe ? Higher amps & reliability can be obtained for sure if we drop the OEM.
You mention replacing the connectors, can I ask where did you get the spares ones ? Frey or you found the matching OEM P/N ?
For what it's worth I should mention the male connector on my frame had it's locknut loose from the factory and was able to rotate. It's not supposed to be able to as there is a retaining tab on the plastic holder below. Tightening the locknut and applying a drop of loctite fixed that. Battery side should be examined too to be safe.
I will also switch the andersons on the motor pigtail in favor of XT90
Is it me or does anyone notice a lot of rattling of the battery when riding off road? Mine is really noisy clunking back and forth. I have a spare battery tried it too with just as much noise.
So must be design flaw?
Cheers,
DDF
Cheers,
DDF
