ElectricGod
Hi folks,
Many people have PM'd me after looking at my Currie scooter conversion thread. I've been asked lots of questions on how to do their own builds or how I did certain things on the Currie. If you are not familiar with that thread, it is found here. This little machine weighs 75 pounds, accelerates like my Golf GTI while carrying my 240 6'4" hulk and tops out at 45mph. It's been a great build and so much fun to ride. Right now, it is getting a few changes made to it to fix some niggling details.
https://endless-sphere.com/forums/viewtopic.php?f=35&t=83830
This is the Schwinn S1000. They come in a few variations. This is not quite the best of the variants. For example it has a brushed motor and the forks don't use a disk brake. The factory motor will get replaced and I've found a source for the correct forks. A long time ago I put a set of S1000 forks on the Currie. This scooter will get that upgrade too. Regardless of the variant of the S1000, they are not very common machines. I've seen only 2 of them ever before. A friend in NYC has one and the other was in Denver. I've been looking for one for more than a year. i had to drive 90 miles to get it. This scooter will be the platform for this thread.
People keep PMing me with questions about how to build a scooter so my intention for this thread is to make it into a tutorial of sorts where I explain the various steps and show lots of specifics so that others (mostly the new folks to EV's) can learn and then be able to duplicate what I show below on their own builds. There will be choices I make that you might not agree with or have a better idea, feel free to post them. BUT, keep in mind that the idea here is to be helpful to beginners as much as possible and to do a build with that same information.
When finished, the S1000 scooter will do 45-50mph, accelerate like my GTI does and have around 30 miles of range at near continuous full speed. Piddling around doing 15 or 20mph ought to get me more like 40 miles. The Currie has similar specs. It has 24 miles of range while doing 30-40 mph, tops out at 45 and can run there for many miles at a time.
The Currie runs on an Alien Power C80100 at 80kv and 66 volts. At my watt meter, I see 4kw at 40-45 mph or under heavy acceleration. It is quite strong and at full power, the only person that can handle the Currie is me. It keeps up with cars on the road easily. I'm adding a 3 speed switch so I can program lower power settings into the controller for other people. Low will be weak and slow (2kw and 25mph). Medium will be strong and slow (4kw and 25mph). High will be full power and full speed (4kw and 45mph). The Schwinn will be using a Revolt RV-100 outrunner. The C80100 and the RV-100 series are essentially the same sized motors, but the RV-100 series motors are a fair bit stronger than the C80100. In talking to Revolt, they have a key between the shaft and bell so that there is no need to reinforce this union like I did on the C80100. They also provide the option of using sealed bearings in steel, hybrid or all ceramic. In my C80100, I had to do all of this myself. The Revolt motor will be stronger (better magnets, more wattage) and set up from the factory with everything needed for reliable EV use. As a result the S1000 ought to be a good bit stronger and faster than the Currie for about the same weight and about the same size. The Currie is already very strong. Keeping the front wheel on the ground while accelerating always requires leaning forward. I'm looking forward to whatever new amount of insanity the RV-100 provides.
Here's the link to the RV-100 motors.
http://www.revolt.org.il/rv-100-model/
Revolt has a sale on the RV-100-regular motor. They are $153 each so I bought one...just to see what Revolt outrunners were like. It is currently shipping to me.
http://www.revolt.org.il/sale/rv-100-regular-sale/
As a side thread, since I currently own 2 C80100 outrunners and have an RV-100-regular coming and soon an RV-100E, I'll do a review of these motors so that people can see for themselves the build quality and make their own comparisons. I also have a CA80-160 Turnigy outrunner. I might as well throw that in the mix too, but I can tell you it is inferior to the C80100 in just about every way. I probably won't ever use it on an EV. Here is that thread.
https://endless-sphere.com/forums/viewtopic.php?f=30&t=94975&p=1390825#p1390825
