fechter said:
n2mb said:
Does anyone know if the serial number on the box matches the one on the head tube of the bike? Should be 15 digits long. I'm trying to see if I can buy the Sur Ron from Luna, but have them hold off on shipping it and send me the serial number. Then I'll try to register it at my DMV following the instructions posted on the Facebook page. Hopefully I'll know for sure if it goes through before having it ship to me...
Thanks!
Can you post a link to that page?
Here's the link:
https://www.facebook.com/photo.php?fbid=10157721323918677&set=gm.814625332078599&type=3&theater&ifg=1
In case it doesn't work:
I followed the California moped registration path that we have used for a dozen mopeds from the 1970s.
This is the link to the CA form:
https://www.dmv.ca.gov/portal/wcm/connect/8bf1936a-a49a-4063-a819-a5dfc8ff5691/reg230.pdf?MOD=AJPERES
Basically, the only main thing you need to justify to yourself is that you will not put your sur-ron into sport mode on the streets because the moped route is limited to 30 mph. If you can agree with this and or disable the switch then you can sign the doc and feel okay.
Second caveat, you should send in a $25 check with your application. The actual listed fee is lower but if you believe in magic, send in the $25 because they pass it along with no issues.
The whole process takes about a month and then you will be plated with a permanent plate. This means that once you register there is nothing else you need to do ever. When you sell the sur-ron just transfer the title like you would any other vehicle.
Last, people can not hear you, riding this on the road is a risk. We have upgraded our head light and are adding break lights. You should really think about doing the same thing.
Attached is the picture of a form with the info.
Good luck and welcome to the fun and exciting world of mopeds!
