Qulbix 165/140 Raptor /NYX Carbon - Sabvoton/Adaptto - 20s/22s Build #5
- liveforphysics 100 GW
Re: Qulbix 165/140 Raptor /NYX Carbon - Sabvoton/Adaptto - 20s/22s Build #5
Nice work on the drop outs! I will copy that if my own dropouts spread.
- ridethelightning 1 MW
I was worried about those dropouts spreading, so made clamping stainless "spanners" to shift the leverage up the swingarm. I got a stainless 12mm thick block lazercut that press fits tight in the dropout socket, welded on a piece of flatbar with a single 8mm bolt that is not visible in the pic(behind phase wires) that transfers the torque ~8ich up the swingarm.
(sorry about the crap resolution
Looks promising...
Maybe you can post more detailed pics?
For the seams I would sand the top coat off fill the seams with a carbon epoxy mix sand then respray a top coat.
Solar charge station on wheels join the Revolution
- efMX Trials Electric Freeride 1 MW
I think they are more concerned with the misalignment issues (with the suspension etc) more than the aesthetics of the seams not matching up.. although it would be nice if it both works and looks perfect, for the price paid..
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale..
yeh, my seems also dont match perfectly, but the bike seems to be well aligned and havnt had any issues with the plastic bushings wearing.
yep that gap isnt a Problem. changed the M6 Bolts 8.8 to strongest 12.9 + filled it just with black silicon.
you cant epoxy that because you have to open minimum one side if you need new bushings.
Thanks Merlin, maybe i will try some washers and see if it stops excessive wear of bushings and movement on swing-arms
The more I read about the frame the stronger it resembles knock off Chinese junkefMX Trials Electric Freeride wrote: ↑Apr 11 2018 5:34pmI think they are more concerned with the misalignment issues (with the suspension etc) more than the aesthetics of the seams not matching up.. although it would be nice if it both works and looks perfect, for the price paid..
Plastic bushings. Buyer beware
eCue wrote: ↑Apr 12 2018 4:07pmThe more I read about the frame the stronger it resembles knock off Chinese junkefMX Trials Electric Freeride wrote: ↑Apr 11 2018 5:34pmI think they are more concerned with the misalignment issues (with the suspension etc) more than the aesthetics of the seams not matching up.. although it would be nice if it both works and looks perfect, for the price paid..
They are made from POM sometimes called Delrin. It's self lubricating and often used in engineering.
Swingarms pivots need bearings, bushings are wallbikes domain.
Current bikes
Street:
Dirt:
Santa Cruz V10. 50mph
Current bikes
Street:
Dirt:
Good to hear it is a proper material for bushings etc , I was worried for the owners wobbling down the road
I replaced Motorcycle bushings before do to play/ wobble being steel they were hammered out and pressed in using a vise.
Could be the Raptor uses ABC bushings as I was reading that my RM element uses plastic bushings as well.
description: ABC a self-lubricating plastic bushing injection molded from a blend of thermoplastic materials, embedded with reinforcing fibers and solid lubricant.
A RM manual instructs to lightly lube "ABC" bushings at assembly and infrequently after.
ABC Bushings https://www.igus.com/wpck/6410/plastic_bushings
iglide® plastic bushings have a low wear rate, superior chemical resistance to sintered bronze bearings, and operate quietly. They are dirt, dust, UV, and corrosion resistant and have a high load capacity.
About time we hit the woods in Belgium Merlin
Qulbix Q76R QS205 Sabvoton 72150, Qulbix Q76R, QS205 Max-E. Bafang BBSHD. 14S6P GA pack. Zero DSR 2016.
absolutley
but not too hard please, iam afraid my frame could self-disassamble while riding
No problem Merlin, i always carry duct tape in the backpack
Not build related but iam tired of seeing only stealth chicken doing wheelies
Yo, how does that thing work to make you do wheelies?
in the description of the video
@Rix
What a beautiful feature / mod / add on I can see this also having applications in other areas where balance is useful
I don't see any mod or Gyro in the video, I believe you just know how to wheelie well?
of course its just a joke
but sketch has build one. not for sale yet but i think only a matter of time.
Hey Merlin i send pm u did u got?
no...not even one.
if you read my messages, just click above in the message "send reply".
or write me here your email. then i email you back.
