Electric Surf Board
Boats, Jet Skis, Kayaks etc., including hovercrafts
toto44   100 mW
Re: Electric Surf Board
Post by toto44 » Aug 19 2018 2:39pm
Today I tested my 3D printed jetdrive. Could not do any measurements, but gives a lot of power.
https://youtu.be/NewKjySw2ko
srn   10 W
Post by srn » Aug 20 2018 1:56am
Hello toto44,
good video, looks like a lot of thrust for this small motor. Do you have a log of motor/esc power during this run ?
srn   10 W
Post by srn » Aug 30 2018 3:37am
Hello,
i changed my carbon impeller to a 3D-printed steel impeller. It is really impressive quality and less vibration.
today I will make first measurements of power consumption. Will provide results later.
madin88   100 MW
Post by madin88 » Aug 30 2018 4:37am
srn wrote:
Aug 30 2018 3:37am
Hello,
how much did it cost?
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
srn   10 W
Post by srn » Aug 30 2018 6:44am
madin88 wrote:
Aug 30 2018 4:37am
I ordered a 62x62mm. They said that it will shrink 2-3% after thermal treatment and finally I got a 60.5 x 60.5 impeller.
It is ~95€.
toto44   100 mW
Post by toto44 » Aug 30 2018 10:04am
Hello SRN
what pitch does your impeller have? Did you balance it?
srn   10 W
Post by srn » Aug 31 2018 9:36am
toto44 wrote:
Aug 30 2018 10:04am
Hello SRN
Hello toto,
the pitch is 60mm or equal to D if you scale it.
I have not balanced it yet.
ropower86   1 W
Post by ropower86 » Sep 02 2018 2:24pm
srn wrote:
Aug 30 2018 3:37am
Hello,
How much did it cost you to 3d print in metal?
srn   10 W
Post by srn » Sep 03 2018 12:36am
ropower86 wrote:
Sep 02 2018 2:24pm
It is ~95€.
srn   10 W
Post by srn » Sep 05 2018 12:06pm
hello guys,
i am still testing in my small pool.
now my remote control is working fine. Also the new propeller is doing a very good job.
here my current MGM log. I wonder that I have really small power consumption at 10.000 rpm. At the moment I limited the MGM to 10k rpm for testing. Will try 12k rpm in a bigger pool soon.
fabianpusch   1 W
Post by fabianpusch » Sep 05 2018 2:40pm
Hi
are you sure that there is really load on the system?
It seems to be really a too low power consumption.
Could be an issue of water mixen with air, less stress for the motor to handle / put through your jet...
On the other side, try to accelerate up to 14000, and measure the pulling force.
Christyy   1 µW
Post by Christyy » Feb 19 2019 3:59am
Hello, about electric surfboards, and more specifically to buy one. What do you think of these https:// awakeboards.com, is it worth investing?
fabianpusch   1 W
Post by fabianpusch » Feb 22 2019 1:45am
It is absolutely clear, you have an issue with a mixture of water and air.
Normally you should have during ramp up by 10000 rpm something between 120-160 Amps.
fabianpusch   1 W
Post by fabianpusch » Feb 22 2019 1:46am
Important, not the peak Amps....the real Amps from the battery
ropower86   1 W
Post by ropower86 » Jun 11 2019 6:53pm
I see we all went ghost on this post :lol: :pancake: . It seems like we all figured it all out. I will be testing soon, in the fiberglassing stage then Gel coat. I will be making a mold and start producing DIY jetboards if things go well with my new design. :bolt:
fabianpusch   1 W
Post by fabianpusch » Jun 13 2019 2:49pm
That Sounds really nice...
Now I am a little curious :D
Show some pics please to reanimate this old and dusty thing....
ropower86   1 W
Post by ropower86 » Jun 18 2019 11:45pm
Here it is fabianpusch
ropower86   1 W
Post by ropower86 » Jun 18 2019 11:47pm
Where are you standing now with your project? :?:
Bazaki   10 kW
Post by Bazaki » Jun 22 2019 4:09am
Everybody moved to the efoil builders forum:) so many are already riding there electric hydrofoils
efMX Trials Electric Freeride   100 kW
Post by efMX Trials Electric Freeride » Jun 22 2019 12:26pm
Bazaki wrote:
Jun 22 2019 4:09am
link?:)
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
fabianpusch   1 W
Post by fabianpusch » Jun 24 2019 12:42am
https://efoil.builders/
Here it is...
But they are really focused on Foilboards.
But still interesting....
At ropower any test rides done yet?
Looks short, really short.
I am interested about the feedback.
srn   10 W
Post by srn » Jun 24 2019 12:49pm
I did some progress and now only wait for vacation to do some water tests.
I especially modified my batteries. Now running on 48 pcs 20700 liion cells, 12S4P. Each parallel pack with own 60A BMS.
I also build a power distribution board, where I put in all battery packs and charger (for charging all of them simultaneously. It has a display with voltmeter, a hall sensor for current measurement and 8 additional capacitors.
chris_kline   100 W
Post by chris_kline » Aug 01 2019 3:57am
I spent a year messing around with my jetboard, but every time i took it out, there would be some electrical problem. the esc kept blowing the caps, mgm are literally the wors company to deal with from a customer care perspective.
i made external caps banks, which helped, and made an additional watercooled heat exchanger for the esc, which helped again.
by now my batteries have been cycled around 50 times, and im starting to loose individual cells, so the packs need to be pulled apart and cells individually checked.
heres a video of the last run i did on new years eve https://www.youtube.com/watch?v=QnzaSyV ... e=youtu.be
chris_kline   100 W
Post by chris_kline » Aug 01 2019 4:06am
eventually i got so sick of the problems with the esc, mgm, and the cells, that i built a gas jetboard from a 2 stroke racing kart engine.
i know this is an electric power forum, but i hope you dont mind me posting a couple photos and video of the second jetboard i made.
here it is part way through construction
IMG_7333 2.jpg (460.44 KiB) Viewed 665 times
IMG_7334 2.jpg (485.91 KiB) Viewed 665 times
IMG_7340 2.jpg (490.24 KiB) Viewed 665 times
chris_kline   100 W
Post by chris_kline » Aug 01 2019 4:14am
