Rix
100 TW
Emmett said:As recommended by Rix, I run a Shinko SR241 at about 10 PSI on a narrow 19" moto rim. With Tubliss. It just clears the chain on my Fighter. It's awesome.
Initially I was concerned about the additional unsprung weight and negative handling. But it has a huge benefit to handling because the fat spongey tyre becomes a very active suspension component. The rear is bucked around much less with this setup.
When I do smash into hard edges at speed the Tubliss high pressure liner takes the hit easily. I ride over 6 to 12" high square edge sandstone rocks routinely at 20 to 40 km/h and it's no problem. Zero punctures so far after 100+ ride hours.
Obviously it has more than double the rear grip. The bonus function is I think money saved in the long term, because the SR241 tyre lasts perhaps 10x one Razorback tyre.
Yep, that why I will never run a bicycle tire on the rear of anything that puts out more than 1 kw again.
