QS 3000w midmotor
eee291   100 kW
Re: QS 3000w midmotor
Post by eee291 » Aug 21 2018 7:26am
This one 100%
larsb   1 MW
Post by larsb » Aug 27 2018 12:46am
bionicon wrote:
Apr 06 2018 3:59pm
i am going to try it on my derbi senda frame with a sabvoton 72200 controller,need more torque....hope that it will satisfy me :D
Do you have the mounting figured out yet? I have a rough idea how to do it but ideas are welcome. I'm soon posting in my Rieju thread
Ride on!
bionicon   1 kW
Post by bionicon » Aug 27 2018 5:19am
Its on the bike for a couple of months now and i am using the support for the suspension to attach it :D
larsb   1 MW
Post by larsb » Aug 27 2018 6:32am
Could you take some pics? I will use this mounting also but since i will go with belt drive then the assembly needs to be stiffer and alignment is more critical..
Ride on!
bionicon   1 kW
Post by bionicon » Aug 27 2018 1:03pm
Under the motor i attach it with bolds, i drilled new holes with tread.
eee291   100 kW
Post by eee291 » Aug 27 2018 1:14pm
Very nice, was planning pretty much the same thing.
BTW are you using something stronger than a 420 Chain?
bionicon   1 kW
Post by bionicon » Aug 27 2018 1:34pm
eee291 wrote:
Aug 27 2018 1:14pm
No this is a 420 chain :D
eee291   100 kW
Post by eee291 » Aug 27 2018 2:04pm
How does it hold up? I'm kinda worried that I might need a 520 Chain at +10Kw.
Also how is the noise at higher speeds?
I'm not worried that it'll be too loud. I'm just curious.
bionicon   1 kW
Post by bionicon » Aug 28 2018 5:10am
The 420 hold up good there is a little stretch but that is normal i guess
larsb   1 MW
Post by larsb » Aug 28 2018 11:37am
Nice mounting! I will need a position to the front of the pivot point by 12cm to fit the belt length so i'll need to make an extension to fix the motor. Some things are better with chain..
I will not miss the oil splatter though :wink:
Ride on!
larsb   1 MW
Post by larsb » Sep 07 2018 12:01pm
bionicon wrote:
Apr 30 2018 2:21pm
this is a picture of the rotor does anybody know why the magnets are posisioned like that?
Do you know how many slots this motor has? I cannot find any data.
Ride on!
bionicon   1 kW
Post by bionicon » Sep 09 2018 5:03am
Only thing i know is 5 polepairs, what do you mean by slots?
larsb   1 MW
Post by larsb » Sep 09 2018 5:51am
slots in stator. I thought you maybe knew since you had that picture of the rotor?
Ride on!
madin88   1 GW
1 GW
Post by madin88 » Sep 09 2018 8:01am
larsb wrote:
Sep 09 2018 5:51am
hey Lars, i think you need to open up your motor then :mrgreen:
larsb   1 MW
Post by larsb » Sep 09 2018 8:28am
Bah! It hurts since it's so nice and new, and i don't have to know just yet. :wink:
Ride on!
bionicon   1 kW
Post by bionicon » Sep 09 2018 10:05am
larsb wrote:
Sep 09 2018 5:51am
That was a picture send by qs to show the stator :D
bionicon   1 kW
Post by bionicon » Sep 09 2018 10:12am
Made a 3 hour trip today with the 72150 set at 250battamps and 450 phaseamps this at 58 volts.
The motor runs strong and with no overheating, i am very happy with the motor :D
Tested also foc and set it at 150amps, now with a 6 to 1 reduction it can run at 90km/u :o
SlowCo   100 kW
Post by SlowCo » Sep 09 2018 1:35pm
That's 14kW max... :shock:
Great motor indeed!
larsb   1 MW
Post by larsb » Sep 09 2018 2:25pm
Looking forward to trying this :D
QS forgot to send me a programming cable to the new votol EM150 controller so i have to wait. Argh!
Ride on!
devo1223   100 W
Post by devo1223 » Sep 13 2018 2:27pm
Bionicon do you have a full pic of your bike with the QS 3000? I searched but couldn't find it
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
bionicon   1 kW
Post by bionicon » Sep 13 2018 3:53pm
bionicon   1 kW
Post by bionicon » Sep 13 2018 4:02pm
just found one from the other site:
bionicon   1 kW
Post by bionicon » Sep 13 2018 4:05pm
bionicon   1 kW
Post by bionicon » Sep 13 2018 4:09pm
devo1223   100 W
Post by devo1223 » Sep 13 2018 5:11pm
nice, the QS 3000 looks like it was made for that frame. Is that a custom frame? Do you have a build log? I'm thinking of the QS 1000w for my next build. Does anyone know the weight of the 1000w? I can't find it. If you're getting 16kw from the 3000 I'm thinking I can get 5kw from the 1000. These motors are so long I've been thinking hard how to fit them between my pedals.
