bzhwindtalker
Got a sample from Vasiliy in Paris Mondial tech, the display features are impressive.
We can't wait to test them on our bikes.
Adam
Adam
bzhwindtalker said:Got a sample from Vasiliy in Paris Mondial tech, the display features are impressive.
Adam
ElectricGod said:Any chance that you will open one up and take pictures of both sides of the board?
Adam
Altair said:ElectricGod said:Any chance that you will open one up and take pictures of both sides of the board?
Why don't you just ask for the schematic, while you're at it...
Don't you have any respect for the work of others?
VasiliSk said:I have made detection for lmx motor, sound was good, probably should work
VasiliSk said:do not publish or distribute any information about internals. China guyz are watching
csc said:Ok so I won't post pictures, but I'll tell you that I'm super impressed by the power / size ratio. In fact my feeling is that this 12f is easily comparable to a max e in terms of energy transferrred to the wheels : efficiency probaly much higher. So far motors heat less.
Programming a little more before a first video
VasiliSk said:Well, later is okay, i just need to have some extra time
Great news!csc said:Ok so I won't post pictures, but I'll tell you that I'm super impressed by the power / size ratio. In fact my feeling is that this 12f is easily comparable to a max e in terms of energy transferrred to the wheels : efficiency probaly much higher. So far motors heat less.
larsb said:Which ASI was that? Thinking about buying a BAC8000. Are they that hard to program?
Sorry Vasili to clutter the thread. I anyway think your controller will have a looong waiting list, and i'm not on it yet so it doesn't make a difference
csc said:Rear motor is now a qs273 4000w 4t (magnets gaps epoxied, sprayon coated, 20ml ferrofluid). Really huge acceleration and no heating. I bet on field weakening, based on the idea that the most challenging situation for an ebike is start and stop in a city, or high mountain climbing. This genearates more heat than FW on fast road according to my experience. Currently real on road max speed (at 82v) is 92 kmh, without knowing exactly what margin I have with the field weakening on the rear
Front motor is still a mxus 3k 3t, but it behaves very differently than with the max e. Much more torque, I had to reduce power to avoid burning the front tire too fast. Which makes me think I could keep it, as I was formerly thinking of a 4t for the front too
Clearly all what I thought about motor temp has to be reset. Rear saw no more than 45°c (ambient 18) (short distance under 15km) where the max e would have generated 80° at least with the rear mxus 3k 3t (rear takes the whole effort during accelerations). (would appreciate a way to check both motors' temps on the single display, currently you have to chose one motor or the other)
Can't say precisely what's the repartition of improvements between motors and controllers.
But it's a great combo !
Work in progress
csc said:Front motor is still a mxus 3k 3t, but it behaves very differently than with the max e. Much more torque, I had to reduce power to avoid burning the front tire too fast. Which makes me think I could keep it, as I was formerly thinking of a 4t for the front too
