maximusdm   100 W
Re: TSDZ2 mid drive -- Flexible OpenSource firmware for TongSheng TSDZ2 mid drive motor
Post by maximusdm » Nov 02 2018 12:18pm
I made a release for the min current feature from my branch for beta testing. This was already code reviewed.
=> 0.14.4.beta1.zip
I also made release for reaching easier the maximum assisted power level, better responsiveness.
=> 0.14.4.beta2.zip
0.14.4.beta1.zip
(50.96 KiB) Downloaded 45 times
0.14.4.beta2.zip
(51.08 KiB) Downloaded 43 times
EndlessCadence   100 W
Post by EndlessCadence » Nov 02 2018 12:27pm
maximusdm wrote:
Nov 02 2018 12:18pm
Nice! For next time: please don't use this version number and make clear that it's a beta! Otherwise, this will end up everywhere and will be called the 0.14.4 release :wink:
Call it 0.14.4-beta0 or 0.14.99 or whatever :)
Post by EndlessCadence » Nov 02 2018 12:30pm
@everyone
We're busy with preparing a few improvements:
  • Cadence low pass filter (LCD3)
  • Improved battery voltage reading and SOC (LCD3)
  • Improved speed reading (especially useful for low speeds / startup)
Next to this I'm implementing and testing walk assist!
gaber   10 W
Post by gaber » Nov 02 2018 12:56pm
EndlessCadence wrote:
Nov 02 2018 12:30pm
@everyone
Cheers! Thanks for your efforts!
sometimes you eat the bear, and sometimes, well, he eats you.
jbalat   10 kW
Post by jbalat » Nov 02 2018 6:15pm
Nov 02 2018 12:30pm
@everyone
Awesome EC :)
Please subscribe to my Youtube home page for Quadcopters, FPV and Bike Rides http://www.youtube.com/jbalatutube
My build log here http://endless-sphere.com/forums/viewto ... =6&t=55352
For some cool ebike talk join us on The Best ebike https://www.facebook.com/groups/193581737807033/
Tech talk TSDZ2 Opensource firmware https://endless-sphere.com/forums/viewt ... &start=150
Opensource TSDZ2 Wiki https://github.com/OpenSource-EBike-fir ... _wiki/wiki
jbalat   10 kW
Post by jbalat » Nov 02 2018 6:19pm
maximusdm wrote:
Nov 02 2018 12:18pm
=> 0.14.4.beta1.zip
=> 0.14.4.beta2.zip
Cool I have copied out the latest ebike_app.c and .h files from both pull requests and will compile and flash in eclipse. That way I don't have to redo all my settings again. I'm not sure what lcd hex I am using ??
casainho   10 GW
10 GW
Post by casainho » Nov 02 2018 6:41pm
Nov 02 2018 12:30pm
@everyone
Tomorrow I will go to mountains with girlfriend and I just flashed both of our ebikes with the code on branch for the walk assist: https://github.com/OpenSource-EBike-fir ... ssist-mode
I must say it seems to work well on a flat surface. On hills it may take some time to build up the motor current (as seen on LCD3). Although it is setup now 4km/h as walk speed, for hills I still think is to much as I can´t walk at 4km/h there... well, I will discover tomorrow :-)
- TSDZ2 OpenSource firmware
Developer of OpenSource knowledge and technology for ebikes: Wireless Ebike boar ANT+ and Bluetooth, Flexible OpenSource firmware for EBikes: TSDZ2 mid drive motor, KT motor controllers and displays: Bafang 850C color, SW102 Bluetooth and KT-LCD3.
If you like my work, please consider making a donation to help my developments: paypal.me/jorgecasa
Post by EndlessCadence » Nov 02 2018 6:48pm
casainho wrote:
Nov 02 2018 6:41pm
Great! Please let me know if you have any feedback. Keep in mind that it's not finished yet and quite rough sometimes.
The wheel speed sensor is a bit hard to work with because of the very low sample rate at low speeds. Tomorrow I'll try to experiment with a hybrid version of the controller which uses wheel speed AND motor ERPS. But I have to say I'm already really proud of the PI controller performance :D
casainho   10 GW
10 GW
Post by casainho » Nov 02 2018 7:30pm
Nov 02 2018 6:48pm
Yes, motor ERPS value change at fast rate like at least 50 per second while wheel speed sensor a values like 0.5 times per second... so ERPS is 100x faster.
But if we would know the gear ratio the user has on bicycle gears, we could direct relate motor ERPS to ebike wheel speed.... I think we can!! We just need to look at ERPS value at a specific wheel speed and them we calc the ratio!! We can assume user did not change gears from last time wheel did rotate, we can store the gear ratio on EEPROM to keep of power on/off cycles.
Knowing the ratio, we can them ramp up ERPS value from 0 startup up to desired value in say 1 second or 2.
Seems complex and it should because of limitations of very low wheel speed but I think we can do it :-)
jbalat   10 kW
Post by jbalat » Nov 03 2018 12:05am
maximusdm wrote:
Nov 02 2018 12:18pm
=> 0.14.4.beta1.zip
=> 0.14.4.beta2.zip
Hi Maximus I have tested both versions, I know I said I would compile myself but I ended up using the hex files above just so I was starting fresh
beta1.
There is still lag there, I could not feel any difference from the original version. There was no evidence that any extra amps was at work while wheel speed is greater than zero, Amp readout would fall to zero in the display.. should I be able to see any amps on the display if it was working ?
UPDATE: I think "wheel_speed" should be "ui16_wheel_speed_x10"
After changing this and setting minimum current a little higher. I would get some current but it would cut out about 2 seconds after I stopped peddaling
it may be this
Code: Select all
 // if ui8_startup_enable == 0, put duty_cycle at 0
  if (ui8_adc_battery_target_current && ui8_startup_enable && (!brake_is_set()))
and this
Code: Select all
// start when we press the pedals
  ui8_startup_enable = configuration_variables.ui8_power_regular_state_div25 && ui8_torque_sensor ? 1 : 0;
it may be resetting its state after you stop pedalling here
Code: Select all
 switch (ui8_tstr_state_machine)
    // ebike is stopped, wait for throttle signal
    case STATE_NO_PEDALLING:
    if ((ui8_torque_sensor_raw > 0) &&
        (!brake_is_set()))
      ui8_tstr_state_machine = STATE_STARTUP_PEDALLING;
    break;
    // now count 2 seconds
    case STATE_STARTUP_PEDALLING:
    if (ui8_rtst_counter++ > 20) // 2 seconds
      ui8_rtst_counter = 0;
      ui8_tstr_state_machine = STATE_PEDALLING;
hmmm... confusing
beta2.
Haha that was fun. When you start peddling it gives you a massive boost, but the fun part (and scary) is that it would run on for about 2 seconds despite I had stopped pedaling. Reminded me of my old PAS bike. Anyway the lag was still there also and temperature was not working it only displayed zero. Lucky for that 2 second cutout, this could have ended differently since I don’t have ebrakes. Hey EC, did you end up making that change where power cuts out at Assist level 0 ?
What does work
So far the only fix is to change the inverse ramp value from 75 to 25. That actually works really well !!
Please Try again...
Thanks for having a go, much appreciated. :)
Please try again with beta 1, its like any amps you add gets knocked back down to zero again, just need to understand the logic ???
jbalat   10 kW
Post by jbalat » Nov 03 2018 12:13am
casainho wrote:
Nov 02 2018 6:41pm
Tomorrow I will go to mountains with girlfriend and I just flashed ....
Enjoy !!!
So jealous I would love to do some bike packing one day, maybe I can join you guys in Portugal ???
I have been inspired by this guy Iohan, but have to do this on an ebike !! not sure exactly how I would charge every day but...
https://www.youtube.com/watch?v=lIbcBZubsUY
shaddi   100 mW
Post by shaddi » Nov 03 2018 2:59am
jbalat wrote:
Nov 03 2018 12:05am
beta2.
whow, that was the same experience i had with the "official" 0.14.3 version i reported about!
A massive boost, have not to pedal hard to keep going and a delay after i stopped pedaling...
Have to try some different releases on this weekend and try again the 0.14.3....
maximusdm   100 W
Post by maximusdm » Nov 03 2018 3:03am
Hi Jbalat,
Thank you for the valuable testing.
For beta1: Please make sure that you always get the latest code. I made the changes at work in a simple editor because I do not have the dev environment. I fixed the problem in the evening when I made the 2 releases.
For beta2:
I tryed to make configuration for the feature quite easy.
Code: Select all
#define MIN_ADC_TORQUE_UNITS            8 //maximum 30 units
#define MIN_CADENCE_RPM                    25 // standard cadence
I am not happy that I made an other boost version :(. It shoud be a permanent assist. At start it should have a small boost but the power should remain with you as long as you pedal.
I added an aditional check so the new assist is done only if old cadence is not 0. It should stop assisting exactly like before.
Also the assistence is half now.
@beta testers: Keep in mind you do not need to flash the LCD if you have 0.14.3, only the motor. And thanks for help :)
0.14.4.beta3.zip
(51.11 KiB) Downloaded 27 times
Rafe   10 W
Post by Rafe » Nov 03 2018 5:42am
Would it be possible that when MPH is the selected speed display option to have the odometer and trip to revert to Miles as well please?
maximusdm   100 W
Post by maximusdm » Nov 03 2018 1:00pm
Today I did a small test with 0.14.4.beta3. I manged to get my cable working and did a quick connector for the LCD.
Code: Select all
#define MIN_ADC_TORQUE_UNITS            4 //maximum 30 units
#define MIN_CADENCE_RPM                    15 // standard cadence
I was able to achive 500w on 500w assist level. The power is delivered with a nice ramp, no hard boost.
The assist stops when you stop pedaling.
It still needs some good testing for finding the best values, but is a good start.
PS: Do not use power levels like 2000w or it will get violent :). Use assistance levels proper for your motor. I use 150-300-450-600-750.
jbalat   10 kW
Post by jbalat » Nov 03 2018 7:14pm
Maximus, power levels are now more logical for sure but I did get some run on and not much reduction of lag that I could tell.
I tried beta1 again but the extra power is still reset after you stop pedalling. I guess if it was working you should just push the bike and it would cut in
casainho   10 GW
10 GW
Post by casainho » Nov 03 2018 8:56pm
jbalat wrote:
Nov 03 2018 7:14pm
motor_set_pwm_duty_cycle_target (255);
else
motor_set_pwm_duty_cycle_target (0);
I would say that even if adding min adc current value, ui8_startup_enable may be zero and stops the motor. Maybe the code should keep ui8_startup_enable = 1 also after adding the min arc current value...
jbalat   10 kW
Post by jbalat » Nov 04 2018 4:55am
casainho wrote:
Nov 03 2018 8:56pm
else
What sets startup_enable to zero ?
Is it only enabled when torque sensor is >0 ?
Code: Select all
casainho   10 GW
10 GW
Post by casainho » Nov 04 2018 2:01pm
jbalat wrote:
Nov 04 2018 4:55am
Code: Select all
Yes, it is 1 if assist level configured on LCD is not 0 and torque sensor signal if > 0.
I would change to (only for the test you are trying to do):
Code: Select all
  ui8_startup_enable = configuration_variables.ui8_power_regular_state_div25 ;
maximusdm   100 W
Post by maximusdm » Nov 04 2018 3:07pm
At the moment I have a problem with the min assist code. It gets very fast to max power and remains there as long as I pedal.
Even if I configure very small assist levels for cadence and torque. I think I am missing something just can't figure it out. Any idea is wellcome.
Also the ui8_startup_enable lead sound interesting. Worth testing with it forced to 1.
Thanks,
max.
casainho   10 GW
10 GW
Post by casainho » Nov 04 2018 3:16pm
maximusdm wrote:
Nov 04 2018 3:07pm
I don know what can be the problem...
WARNING!!!
You should use brakes while development or you can end up in a situation that motor start as soon you power the system, then what you do?? If you stop the code execution for debug (or flash??), the coils will be powered up and current control will not happen as firmware stops and you will burn the motor controllers very fast!!! With brakes, you just keep then pressed at startup and system will not power on while the brakes are pressed:
Code: Select all
int main (void)
  brake_init ();
  while (brake_is_set()) ; // hold here while brake is pressed -- this is a protection for development
casainho   10 GW
10 GW
Post by casainho » Nov 04 2018 3:45pm
casainho wrote:
Nov 02 2018 6:41pm
My feedback for walk assist, when using on mountains:
1. Ebikes has the disadvantage that are heavier than regular bikes and when pushing them by hand on step hills, it is a BIG disadvantage!!
Walk assist mode reduces that disadvantage because the ebike pushes itself. PLUS, on this mode the ebike push the rider and here is an advantage over regular ebikes because for instance, on mountains, the rider can go very tired to walk and the ebike helps pushing him.
2. The walk assist speed of 6km/h is about law and law does not represent the needs for users on mountains, or users that walk slow because of special needs like kids, older people, etc.
3. On mountains, for instance, users need different speeds at different moments: different speeds because they are tired and can´t walk faster; because they are at a very step hill and should go slow because of safety; because they are going on rear of other rider walking slow, etc. Ideally the speed is changed in a very quick way, maybe like we change assist level.
4. Walk assist speeds need to be very slow, like 2.5km/h. I saw my girlfriend going very slow on walk assist mode at 2.5km/h and being happy with that because it was slow.
I wish we can implement a good walk assist mode and not just the regular 6km/h...
Feedback for EndlessCadence: On my trip of yesterday with my girlfriend on a very step hills, I fount that current implementation: 1. is very slow to start the ebike wheel; 2. very low power of something like 50W or less.
Because of 2., the speed was VERY slow like 2.5km/h but that ended to working well for my girlfriend that was very tired and did prefer to walk at low speed on that very step hills... walk assist was very important for us, thanks!!
jbalat wrote:
Nov 03 2018 12:13am
Enjoy !!!
I just started this year when I got TSDZ2 and with our firmware running. Before I was using an hub motor and so I never did mountains.
Here are some links with sites that includes information for BTT tracks on our montains:
Aldeias Históricas
http://www.aldeiashistoricasdeportugal. ... ande-rota/
Aldeias do Xisto
https://aldeiasdoxisto.pt
Manteigas (Serra da Estrela)
BTT: http://centrodebtt.cm-manteigas.pt
Pedestre: http://manteigastrilhosverdes.com
vscope   100 mW
Post by vscope » Nov 04 2018 3:57pm
maybe it would make sense to have up to 9 walk speeds. using up/down buttons when in walk mode sets the walkspeed. 0-9.
kortina   10 mW
Post by kortina » Nov 04 2018 9:47pm
Would it make sense to have a static RPM of the front 42t cog?
EG:
If you want a faster walk speed, then just put the bike into 9th (11t rear)
If you want a slow walk speed, then put the bike into 1st (32t rear)
Aim to have the speed of 42t-11t gearing at 6km/h... for legal reasons.
jbalat   10 kW
Post by jbalat » Nov 04 2018 11:59pm
Just some testing on the inverse ramp factor to reduce lag
