First off, we have the same motor. Prestolite MTY4001 36v stock.
Just look at these two videos
https://www.youtube.com/watch?v=BGwtqgN_7no
https://www.youtube.com/watch?v=KObUDN7pMcE
the first is with EXTREMLY grippy wide tires.
the second is with normal gokart tires.
he is running 1.16:1
Same setup in both videos, only different tires. He is running 110v 500amp open revolt controller. In other words, yes more volt than mine, ive tested 84v, but again. today i tested 48v, and the burnout WITHOUT me in the cart is the same, just less high rpm wheel spin. (spun the tires at 480amp+ with the test yesterday @ 84v and today @48v, so seems the volt doesent make any different in when it starts to spin, both at 480amp+)
I did a test today with 48v. Pushing it against the wall, i wasent in the cart, so it only had around 60-70kg load at the back tires (motor and frame). Still same gear ratio 1:1. I added a clamp meter to be sure that the data from the controller wasent wrong, and yes, they was correct, i peaked 662amp @ 48v.
It started to spin the wheels at around 480amp+.
With me in the cart it would NEVER do any kind of burnout, and the wheels wouldent spin.
The motor is wired in this way
Plus to S-1
S-2 to A-1
Ground to A-2
Brush picture. I got 8 of these.
