j bjork
I am still very interested in trying the fw, especially the cruise control would be nice to have though. The app looks nice, I hope I can get an old phone working and try to use it on.
I have to get the parts to be able to program before I can get much furter though.
I know there was some talk about getting the controller to run on higher voltage earlier, but I don´t know if it was settled what can be done. In the fw it seems possible to set any number of serial sells I want, or is there any limitations there?
I guess I should be able to at least run 14s with the controller with stock hardware?
It would be nice to be able to modify it to run 20s, but maby it is easier to get a controller for 20s in that case..
Another thing, I saw that I can use x4 for variable regen, that sounds nice. But it also says the same x4 for temp sensor in the motor. But I think there is already a wire for temp sensor, there is an extra wire in the harness for the hall sensors.
I liked the possibility to have regen when pedaling backwards, but that maby was in casinos fw?
