Thrice said:
Offroader said:
Have any of you guys cut down the width of the handlebars? They feel kind of wide and I'm not sure if I should cut it down a little bit. They are 3" wider than my other ebike.
Congrats on your Sur Ron, I’m getting mine in two days, been lurking around this thread. This is my first post, anyways I know from My MX experience I have always cut my bars about 3/4” depending on the brand of bars I get, I know I will be cutting my bars when I get it. Some questions I got for you Offroader, at what charge was you pack at when you first checked it? What’s gearing did yours come with? Did you check your spoke tension on your wheels?
Thanks,
My battery was at 66% charge out of the box and my X version came with a 48 tooth.
I have been checking the spoke tension and you will have to stay on top of this until you notice the spokes are not coming loose. The spokes are not too bad and I have not had a spoke so loose that you can turn the nipple by hand. When I go around the spokes and tap them with my metal spoke wrench, there are a few spokes that don't make the clink sound and those spokes only need like a quarter turn to get back into spec.
I believe they didn't tension the spokes enough so what I did was I went around the whole wheel and turned each nipple a quarter of a turn after 2 rides. If any of the nipples were very hard to turn I wouldn't turn those. There is a proper sequence for tightening all the spokes like you start with the 1st spoke, and skip 2, then tighten the next, then when you went completely around you start with the 2nd spoke... You will have to look this up on you tube to do it properly. I would probably recommend you do this to tighten up the wheel just a little bit, maybe 1/4 turn each spoke or 1/2 turn each spoke after 2 passes.
Right now I"m just buying myself time, I know eventually I will have to unloosen all the spokes and rebuild the wheel with proper tension if I want a true and maintenance free wheel.
You may want to check the air pressure, I didn't because they felt tight but I noticed after my ride yesterday my front had 7 PSI, I didn't even notice it was that low when riding. The rear was 17 PSI, so I put 17PSI in the front.
The nipples measure around 4.5 - 4.6 mm , so you will need a spoke wrench in that size. I use this one because I had it for my other bike but it is 5.0 mm. It does the job just fine and works great for tapping spokes for listening for loose spokes, but it measure 5.0 mm and not 4.5 mm. I'm not sure if there are any 4.5 mm spoke wrenches which would have a much tighter fit and less prone to rounding the nipples. But honestly, if you are rounding nipples you are probably putting way too much tension on the spokes.
https://www.amazon.com/Motion-Pro-08-0520-Spoke-Wrench/dp/B009J7P3KW
EDIT:
here is a good video on how to tighten all your spokes properly, by skipping every 2 spokes, without getting it off true. I would do maybe 2 passes of 1/4 turns. I'm not sure if you would want more tension then that. If any nipple feel really tight then don't tighten it more, you may even want to back it off 1/8" turn. You will quickly get a feel to which nipples are too tight as there will be a few that are much tighter than the others.
I would do this for 1/4" turn once even before you ride it the first time.
[youtube]cFuRndMgerc[/youtube]
