Offroader said:L3chef said:I'm copying your battery build, except I will use Samsung 30q and I will parallel connect them.. So it will be difficult to fit a bms anywhere inside the frame. Also I cant find a smart bms that would fit width wise.
I know the MAX-E BMS fits in this location as I put it in there to see if it would fit. I would of course keep it encased in foam and make sure it is in there so it doesn't bounce around, you will have to push foam in there.
In the picture I circled in red the location I was going to put it.
I receieved my frame yesterday! Damn this thing is a beauty!
However, on my frame where you marked where you would mount the bms I got some reinforcement welded to the frame. Is it not present on the older frames?
https://ibb.co/jh6hfZX
