Best controller for 20S 3kW motor?
BillyJ   10 mW
Post by BillyJ » Jan 02 2019 5:52am
Hi all,
Would you recommend me controllers for a 3kW motor, running a 20s 90A pack?
Also what is the cheapest FOC controller that fits these requirements?
Thanks! :D
999zip999   100 GW
Re: Best controller for 20S 3kW motor?
Post by 999zip999 » Jan 02 2019 3:19pm
Powervelocity 18fet BT controller. Or https://endless-sphere.com/forums/membe ... 3990.cheap.
Yermommy   10 W
Post by Yermommy » Jan 02 2019 5:39pm
Don't cheap out on your controller.
2WheelsMovesTheSoul   100 W
Post by 2WheelsMovesTheSoul » Jan 02 2019 6:09pm
Kelly KLS-7230S is a very solid controller, it will handle your 90a with no problems.
After 1,500+ miles, I only have 2 issues with the controller.
1. Accel ramp is not very exciting.... power comes on a bit slow for the first 10-15mph, then it rips your face off. I use 3T high speed motor which exaggerates this a bit more. Controller puts more emphasis on a slow and steady start ensuring traction over speed.
2. There is no dashboard or display that just plugs in. There is a BT dongle for programming but nothing like a SW900 or LCD3 display. I currently use a GPS based speedo and a 200a shunt with it's own little volt/amp meter display.
shortcircuit911   1 kW
Post by shortcircuit911 » Jan 02 2019 8:37pm
X2 what @yermommy said.
I bought a sabvoton 72150 w/tft and it was complete trash(lasted 50mi). I'm running a Mobipus controller now, its FOC, not sure it's the cheapest. SamD sells them if you're interested, Good luck.
N3mam   1 mW
Post by N3mam » Jan 03 2019 10:17am
QS motor selling 7230s with display same as sabvoton has
https://bit.ly/2R7p63t also https://endless-sphere.com/forums/viewt ... 5#p1426975
VECTOR TYPHOON 🚴‍♀️ QS 205 v3 5T 🔧 Kelly 7230s with 750C display 🔧 20s15p battery
BillyJ   10 mW
Post by BillyJ » Jan 03 2019 5:24pm
shortcircuit911 wrote:
Jan 02 2019 8:37pm
Just messaged Sam. The Mobipus looks very very promising! Thanks :D
Post by shortcircuit911 » Jan 04 2019 12:04pm
Seriously, its badass! I'm working on getting the tablet mounted to the bars right now,. There's some info on it in my build thread, let me know if you need help.
