stancecoke
- Joined
- Aug 2, 2017
- Messages
- 1,808
haiyi911 said:Did you drive by direct drive motor ?when i started the motor,there were some noise and the motor was shaking . then i changed the "motor special angle " as "160"(the best number),but i could still feel that the motor is shaking.are there any parameters to adjust?
I'm using the BionX IGH3 with our firmware. It's completely quiet except small resonance vibrations in the range of 12-14 km/h.
You can finetune the angles corresponding to the hall events. Xnyle has done this successfully, he implemented a function to show the details in BluOsec.
If there is massive noise, please swap the hall-sensor / phase wires to find the correct scheme.
geofft said:I'm currently running a Sempu T4 torquesensor using Stancecoke's fw in tqsr mode and this also works extremely well, pretty much faultless in fact.
Nice to hear you finally got it going!
regards
stancecoke
