SO much good info here, thanks guys.
I have not measured sag in anyway or any location other than what the CA display tells me My workshop is a dull, un powered, un heated, damp garage and the only sparky gear I have is a cheap multimeter...I am the ultimate garage bodge jobber!
The battery should be good for 1000+ amp draw at 35c rating and 40ah but I have not tested it any way outside of balance charger internal resistance and all was good.
Current controller and motor connectors are still xt90 but my other esc has been upgraded to xt150 and i will swap the motor ones for 150s too when I get to the esc swap.
Then to find a decent isolation switch I can add a resistor to for a pre charge to replace the less than tidy loop key situation I have now
