APL
- Joined
- Aug 6, 2018
- Messages
- 1,113
Also, I wanted to follow up on the anodizing process, in case anybody is planning to try it.
I tried boiling the parts in a weak mixture of Simple Green and distilled water for about 5 - 10 minutes, and
that worked like a charm. It's amazing how clean that SG will get aluminum!
Then I put it in the sodium phosphate for three hours on the 2 amp setting, which shows up as about one amp
on the charger meter. That changes with the size of the part. The part will have a yellow tint to it when it's
ready for the dye. The longer you leave it in the anodizing tank, the better it turns out.
Use distilled water for everything.
I imagine different kinds of aluminum will act differently to the process.
Now the problem is getting two pieces with a matching color. It would be wise to do all of the pieces at the
same time, through the system, if you wanted equal tints.
I bought 2 lbs of sodium phosphate on the bay for about $12. and used about three quarters of it. The solution
doesn't seem to degrade,.. or at least, hasn't yet.
I plan to do the rotors in a very light gold, and the bearing caps in red. Ooooh
Rotors are up next, at long last!
