bluetooth BMS?
alestoroz   1 µW
Re: bluetooth BMS?
Post by alestoroz » Feb 16 2019 7:29am
To my knowledge, there is no firmware version requirement to use the different JBDtools.
Over 1.1, 1.A has several improvements:
- ability to put the chip in sleep mode, for long-term storage of the battery
- more life counters
- config password protection
- ability to change/reset bluetooth PIN
- it "should" be multilanguage :mrgreen:
The official 1.A interface is a mix of taiwanese chinese and chinglish.. plus fonts and metrics of window objects are garbage.
As I don't have access to original code, I modded program resources and Hex-edited it.
flippy   1 MW
Re: bluetooth BMS?
Post by flippy » Feb 24 2019 10:11am
Goonman wrote:
Feb 08 2019 5:13am
@flippy :bigthumb:
I just found VBMS. I risked spending 10 Aussie rubles and I am glad I did. Holy mother f&$@ing son of a.... Downloaded opened and boom! It verks ya it's VERKING!
Worth every penny. Saved me adding this device mistakes pile in the shed.
i could have sent it to you for free. .... :roll:
Lithium beats liquid dinosaurs.
izeman   10 GW
10 GW
Re: bluetooth BMS?
Post by izeman » Feb 24 2019 11:14am
Thanks alestoroz for the translation. Much appreciated.
Is the firmware upgradeable? Do we have newer versions available to flash? Never thought of it yet, but if it got some improvments i'm always willing to try.
flippy   1 MW
Re: bluetooth BMS?
Post by flippy » Feb 24 2019 4:52pm
if peeps want the vbms apk:
https://drive.google.com/open?id=0B57Vy ... VtWXg1cUhr
this version should be able to give the thing a password to prevent people from changing your bms settings. handy for reselling batteries.
this the the most usable version but you cant install a password but it is in english, sorta:
https://drive.google.com/open?id=1YAztD ... goxXojhzlP
mind you: you cant install them at the same time due to having idential names.
ElectricGod   100 MW
Re: bluetooth BMS?
Post by ElectricGod » Feb 27 2019 1:13pm
flippy wrote:
Feb 24 2019 4:52pm
Thank you for your work on this! The Chinese apps can be so much better, but they won't put in the effort.
XB-502: viewtopic.php?f=10&t=83302&p=1222730#p1222730
Currie scooter: viewtopic.php?f=35&t=83830&p=1227407#p1227407
Benjamin Franklin - "Any fool can criticize, condemn and complain and most fools do."
dodjob   1 kW
Re: bluetooth BMS?
Post by dodjob » Mar 02 2019 9:33am
Puuh, it is a long time for me posting in the main forum 😅☝️
I just succeeded to tune one of them. Went from 14s30A to 15S 60A.
For those getting a shock like me. When you remove the 13-14s bridge and rewire everything, the 15S cell shows in the soft 26V... trust me, I unplugged it a few times 😅🙈
So you just need to recalibrate the cell, and all goes as intended.
For the 30-->60A I just repopulated the second side with some gets from a toasted one. And it works :)
Hope this helps!
Gruß,
H.
Felt beer-cruiser MAC 8T lifepo4 36V12AH 12FETS4110 http://www.bavarian-ebikes.com
MJSfoto1956   10 kW
Re: bluetooth BMS?
Post by MJSfoto1956 » Mar 05 2019 8:29am
Seems there is a "new" English version of the bluetooth app (I was just contacted by the vendor).
http://mysharegadget.com/564369408
Michael
P.S. I haven't tried it as I only have IOS not Android. YMMV
Voting has ended: viewtopic.php?f=26&t=102697
Слишком мало, слишком поздно
flippy   1 MW
Re: bluetooth BMS?
Post by flippy » Mar 05 2019 9:38am
that is the chinese app, no habla eniglsh.
use the other like i posted, that has the "proper" app.
MJSfoto1956   10 kW
Re: bluetooth BMS?
Post by MJSfoto1956 » Mar 05 2019 8:06pm
flippy wrote:
Mar 05 2019 9:38am
Are you 100% sure? They claim it is the English version. (I have no way of testing)
M
flippy   1 MW
Re: bluetooth BMS?
Post by flippy » Mar 06 2019 12:35am
MJSfoto1956 wrote:
Mar 05 2019 8:06pm
flippy wrote:
Mar 05 2019 9:38am
M
some buttons are chinglish but eveything else is quite litteraly chinese. the other app i posted is much better and does not show functions it does not support.
multifrag   100 W
Re: bluetooth BMS?
Post by multifrag » Mar 07 2019 6:59pm
Are there any benefits over the Xiaoxiang V2.1.1022 version? Your posted app didn't want to connect to my bms, but the interface was not as convenient as the Xiaoxiang.
flippy   1 MW
Re: bluetooth BMS?
Post by flippy » Mar 08 2019 4:56am
multifrag wrote:
Mar 07 2019 6:59pm
can you post that version?
multifrag   100 W
Re: bluetooth BMS?
Post by multifrag » Mar 08 2019 7:43am
flippy wrote:
Mar 08 2019 4:56am
multifrag wrote:
Mar 07 2019 6:59pm
I've attached the .apk in 7z archive.
xiaoxiangprotection-2.1.1022.apk.7z
(4.4 MiB) Downloaded 269 times
angusinalberta   1 mW
Re: bluetooth BMS?
Post by angusinalberta » Mar 15 2019 2:34pm
Xiaoxiang V2.1.1022 screenshot:
Anyone know what the values mean?
flippy   1 MW
Re: bluetooth BMS?
Post by flippy » Mar 15 2019 3:11pm
angusinalberta wrote:
Mar 15 2019 2:34pm
you passed your exam?
multifrag   100 W
Re: bluetooth BMS?
Post by multifrag » Mar 15 2019 5:28pm
Mar 15 2019 2:34pm
Your series voltage is not very uniform. Mine is with in 0.03V and I get 93 for Voltage uniformity.
Check yours in Battery state/ Battery Voltage.
angusinalberta   1 mW
Re: bluetooth BMS?
Post by angusinalberta » Mar 15 2019 7:19pm
crossbeak requests
Hi, do you have an APK of the newer Version 2 app pls? The only source i now is the store
If your request was directed at me the version I'm using is Xiaoxiang V2.1.1022 as posted by multifrag on Mar 08 2019 5:43am
(4.4 MiB) Downloaded 23 times
crossbreak   100 MW
Re: bluetooth BMS?
Post by crossbreak » Mar 16 2019 9:24am
:oops: sorry I should have mentioned that I talk about the VBMS app. The one from the Google store link
tmho   100 W
Re: bluetooth BMS?
Post by tmho » Mar 16 2019 10:57pm
Goonman wrote:
Feb 08 2019 5:13am
@flippy :bigthumb:
Hi Goonman, may I know which bluetooth BMS you are using with the VBMS app?
I also want to buy it. But when I checked with the developer on which BMS it can work with, they sent me a link to an aliexpress post. Mine is not that model but from the same manufacturer. When I further asked them if it will work with mine, I got no reply.
\ (•◡•) /   1 W
Re: bluetooth BMS?
Post by \ (•◡•) / » Mar 16 2019 11:07pm
tmho wrote:
Mar 16 2019 10:57pm
Goonman wrote:
Feb 08 2019 5:13am
@flippy :bigthumb:
You guys are lucky, I never got my 300A Bms working with the $10 Vbms app, although it has always worked with the original V1 app - Strange, How did you get yours to connect?, I've tried everything I can think of with mine.
TilmanBaumann   100 W
Re: bluetooth BMS?
Post by TilmanBaumann » Mar 17 2019 10:38am
Bicycle analyst software mobile software works fine with the energus SmartBMS
flippy   1 MW
Re: bluetooth BMS?
Post by flippy » Mar 17 2019 3:53pm
ecat wrote:
Mar 17 2019 9:26am
I have tried Chinese “smart” BMS, and there is always a catch. I ended up with the Energus, and am now the Canadian distributor.
https://hilleater.ca/bms/energus-bms/
They do everything you need, the manual is in pretty good English. The 150/750 a version will drive a relay for higher power projects. No phone app yet, just pc but they are working on it.
i used a bunch of them in the past. but the price and 16S limit is a real bummer. also the pricing for shit you need like the balance wires is a separate buy. and i asked for longer wires a long time ago and its basically talking to a brick wall...
that said, i do use them for high end solutions if the customer wants to spend the extra money or i run into size constraints.
too bad they simply cant beat a chinese 32S 300A bms with a LCD screen in cost or features.
esvaf   1 µW
Re: bluetooth BMS?
Post by esvaf » Mar 22 2019 7:42am
Hello!
Friends, tell me, please, have you encountered the problem of reading and changing data in the BMS from a computer? In my PC version of the software, the first tab with cells info works fine, but if I try to do a calibration on the third tab or read the data on the second tab, I get a connection error, and the data is no longer read from BMS. To restore the connection with the BMS, i need to restart the PC application.
I really need to calibrate the bms because it show wrong data on the current measurement (displayed x 1.5 = real)
multifrag   100 W
Re: bluetooth BMS?
Post by multifrag » Mar 22 2019 5:02pm
esvaf wrote:
Mar 22 2019 7:42am
Hello!
I think it's because you click start in the first page for live voltage update. Instead you need to just click read eprom in the second page.
