Electric free ride build from scratch
Bonneville
Greetings to all
Im a new user from India and this is my first post after joining the forum. but ive been a reader of the forum for many years .
so I started building this electric off-road freeride type bike a couple of weeks ago
decided to build from scratch and design and make the frame.
my prior experience in making an e-bike was what I did for my son couple of months back with a 350W motor and a custom frame built from mild steel angle bars
so this time I decided to make the bike a little more powerful ( which can do wheelies) and started buying the required components. I was kind of hooked on to RC motor mid drives thanks to builds by Tom Ttraton and Patric and Shumaker and also to the sticky index and blogs by a fellow submariner spinning magnets
I went on a buying spree and ordered a sensored RC outrunner by flipsky - 6374 and a VESC 4.12 controller which is yet to arrive . but now im really in a dilemma if this would suffice the requirement of doing effortless wheelies on the bike.
Im thinking of a 12 S Sensored set up with the vesc 4.2 controller which is capable of giving 50 amps continuous and very high burst current(claims > 200 amps )
as for the drive mechanism since the motor is a 190kv ill be using a reduction of 1:18 with two belt reduction drives of 4 each and a chain final reduction of 2.
total estimated weight of my bike will be less than 40 kg and my own weight is 72 kg. ive already built the frame and the main frame without the zoom shock absorbers weigh 7 kg.
It would be great if anyone in the forum can comment of the flipsky motor and vesc 4.12 controller would live up to the expectation of doing wheelies. if the motor and controller are not fit for the task then ill keep aside the plan for making a reduction gearbox by CNC milling and look for other motor oiptions such as a QS V3 motor being run as a mid drive.
kindly advice
PS: I am desperately trying to figure out how to ass pictures but somehow its not working the way i read it in the forum. im unable to drag and drop and also unable to add files. it says : It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct.
maybe the size is big
If you are posting a link to a remote image on a hosting site the file size doesn't matter. Just make sure you are copying and pasting the correct code. It should look like something this: (img)https://xxxx.com/xxxx.jpg(/img) I use a site called imgur that hosts for free. The image code actually uses square brackets [ ] not parenthses. I had to substitute parens or else it would just display a broken image. So your image code should look like my example but have [ ] at the beginning and end around the img text.
You can also easily add photos directly to your post by uploading them to ES. Just click on the "attachments" tab below the text box you type your message, then select the file on your computer. There probably is a size limit to do that but I don't know the exact number since I always do the remote method above. Good practice to downsize them to limit the storage space they consume on ES.
the design of the frame was inspired by the post by adam on lmx bike build
the first bike I built. custom frame 350 w motor
the free ride frame in the making
jig for steering neck alignment
laser cut jig for main frame welding
mock up . tyre was the wrong choice so scrapped it
thanks for the tip raylo32, I used a similar site photobucket. guess it works now
Photobucket is evil. I used to host my pics there for many years until they tried to extort $$ from all users.... then they stopped hosting literally millions of photos that "broke the internet". I have many many threads in other forums where the photos are gone forever. I wouldn't trust them.
Consider either the Eastgem D4500 or QS1000 mid drive motors. Either will run with just a single reduction to the rear wheel and come with controllers. Costs are similar although I think the QS might be built better.
I'm currently working on a design around the QS1000 but haven't ordered it yet.
To what wattage can the 1000 w QS be taken safely ?
Will the vesc 4.12 be able to run the 1000 w QS ?
Grantmac said:
At least 4kw. The "3kw" will do 15kw....
You have to email them: damon@tzquanshun.com
Thank you very much . I'll mail to the guy and get back.
You said 3 kW can go up to 15 kW. Is it a typo or ....
In the meantime the rear swing arm fixed in place. A rod welded just to keep it in position wrt the frame till I get the rear shocks
They are rated very conservatively and also according to their minimum voltage from what I can see.
Ok great. But my dilemma still continues . Denzel ds4500 and QS are good options
But is there any one who has used a vesc4.12 and 6374 outrunner configuration ?
Since I've already ordered it I want to know if this set up would work or not with a 12s lipo before I keep it aside and go for another option
Thanks in advance
[youtube]sgkiock4p9M[/youtube]
nice build! i have a similar one, do check out my build thread
btw is that your final swing-arm?
also the zoom fork is kinda dodgy for electric motorcycle use. i know coz i have one :lol: better find an RST R-One if you need a budget fork. i was supposed to use the RST for my build but someone bought it so i ended up w/ a rockshox domain
Superb build. I went through the whole thread . Quite motivated
No the swing arm and everything about it is temporary. I had a couple of days leave and wanted to see the bike with the rear wheel fitted so modified a Yamaha rx100 rear swing arm to accept the rear wheel
I really liked your swing arm design . Made some CAD models none in agreement with my weight target
I used normal bicycle wheels for rear as of now. Even I want to have something stronger in the rear.
How much does the wheels and hub weigh in you bike ?
Made these brackets from 3mm mild steel. But I need to make that also properly. Did this kind of a mock up because I was dying to see the bike on two wheels . I've just welded a steel flat bar because the shock hasn't arrived. I have ordered a " Do not move" shock :lol: but not the burner an AOY 36 for rear
Is zoom that bad ???? Found a little on stiffer side actually . Will progress with this one as of now and when I have sufficient funds I'll look for a better model like yours
yes the zoom is really bad. in fact it comes w/ a warning label. check it out. i says not for aggressive riding or something to that effect :lol: i cracked mine by simply tightening the pinch bolts so the metallurgy is very suspect. also they don't have any kind of damping i.e. they're pogo sticks, dangerous is use off-road
as for AOY-36 is that an air shock? probably not a good idea for a heavy-duty application like a 40+ kg electric moto. check out the leverage ratio of my swing-arm. i'm using a DNM RCP-2 which is a downhill shock, with 550 pound spring and it's too soft. i'll be getting a stiffer spring
Sad news about zoom
AOY 36 is air shock . Looks like my part buying spree was nt well planned.
check out this thread re zoom: https://endless-sphere.com/forums/viewtopic.php?t=68861
https://www.aliexpress.com/item/24X24MM-150-240MM-550-650-750-900-1100-DNM-22LAR-DV-Mountain-Bicycle-Rear-Oil-Suspension/32951530325.html
your air shock will probably work but i'm a bit worried about long-term durability because it was designed for lightweight XC bikes, not DH. check out the link i think these are even cheaper than the air shock. afaik they've been used successfully on the kuberg freerider. go for the 240mm version w/ 650lb spring
Thanks for the link. :bigthumb: will read the thread and get back
I made an electric pocket bike
SK3 6374 -192 -12s Multistar Lipo - VESC
https://www.youtube.com/watch?v=xZOdHgs2wxM
it lacks in topspeed (low power), slighty better than a 49cc chinese engine pocket bike, little less than a Polini 4.2 (hp)-40 cc engine pocket bike.
Torque is better than any "normal" not chinese engine pocket bike (in races motors start from 10 hp and above )
If you want to do wheelie i think sk3- 6374 is not the right motor
Thanks rudic
Now that was the little push I required after advice from overclocker and grantmac to take a decision on motor selection .
Lucky for me the 6375 and vesc I ordered are still not delivered even after 48 days. And now I have requested for cancellation and refund.
I also took a look at ds4500 and the 3kw golden motor as the next options.
After reading the thread on zoom shocks which overclocker sent me I'm in doubt wether to use them or not
The redesign of the rear swing arm is still in progress. Now that the motor option is getting clearer I'd rather go with a design like that of overclocker where in the motor is on the swingarm to avoid chain tensioning issues.
End result is I'm contemplating and no actual progress .
