Odd thing
Lee30   100 µW
100 µW
Odd thing
Post by Lee30 » Mar 14 2019 1:46pm
Odd thing. This only does it at 20mph? Say I am travelling along on a flat road, motor power only. I get up to 20mph and keep it there for a short while, then reduce the throttle slightly, even though the power meter says that I have reduced power, I am still doing 20mph? Ok, 15 mph reads 3 bars on the meter, 20 mph, 4 bars initially, but after a short while, I can get it down to 3 bars, still doing 20 mph?
JBG   1 mW
Re: Odd thing
Post by JBG » Mar 14 2019 8:50pm
Of course that’s what’s happening. It takes more power to accelerate than to maintain speed.
My first build: 36V 500W hardtail
dogman dan   100 GW
Re: Odd thing
Post by dogman dan » Mar 15 2019 7:33am
And the motor may actually operate more efficiently at 20 mph.
But some of what you are seeing is just a time lag on that type of power meter. So you may be seeing a combination of things, efficiency improving, less needed to maintain 20 mph than it needed to get from 15 to 20 mph, and a small time lag on the input averaging built into the meter.
neptronix   100 GW
Re: Odd thing
Post by neptronix » Mar 15 2019 9:15am
You should really get a watt/volt/amp metering device. It will teach you a lot about power consumption. Whatever display you have will not indicate much of use ( what does a bar represent, exactly? :roll: ).
These have always been cheap and pretty reliable:
https://hobbyking.com/en_us/turnigy-180 ... lsrc=aw.ds
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
MadRhino   100 GW
Re: Odd thing
Post by MadRhino » Mar 16 2019 10:09am
neptronix wrote:
Mar 15 2019 9:15am
... what does a bar represent, exactly? :roll: ).
:lowbatt:
14.5 psi ?
:mrgreen:
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
