sendler2112
Complete waste of engineering talent and resources. We have much better things we could be doing than to send 200 people to eventually die on Mars.cricketo said:Starship Hopper may get a first static fire this week.
Line losses are simple physics, and the parameters are well understood.cricketo said:Hillhater said:
That's business stuff, which is doesn't abide by the laws of physics. Yawn.
Hillhater said:Line losses are simple physics, and the parameters are well understood.
Underestimating them by several orders of magnitude, such that they significantly reduce the financial viability of the project, is a basic engineering error.
Last year, falls in marginal loss factors of 20 per cent or more were imposed on some projects as a result of grid congestion, or changes to load. That has the potential to dramatically alter the economics of a project, affecting equity owners and lenders alike.
sendler2112 said:Complete waste of engineering talent and resources. We have much better things we could be doing than to send 200 people to eventually die on Mars.
cricketo said:Yeah, tell me how you feel about our defense initiatives.
Or they could stay here and die . . .sendler2112 said:Complete waste of engineering talent and resources. We have much better things we could be doing than to send 200 people to eventually die on Mars.
billvon said:For example, if solar power satellites are ever going to become a possibility, then something at _least_ as large as the BFR (now Super Heavy/Starship) will be essential.
If you say so.sendler2112 said:GigaWatt scale microwave energy transmission from orbit is somewhere between won't happen and can't happen.
billvon said:If you say so.sendler2112 said:GigaWatt scale microwave energy transmission from orbit is somewhere between won't happen and can't happen.
IMO it is worth researching, since it solves the "no solar power at night" problem. With existing technology, solar power satellites could be launched via the BFR, and each one would generate ~100 megawatts.
sendler2112 said:billvon said:If you say so.sendler2112 said:GigaWatt scale microwave energy transmission from orbit is somewhere between won't happen and can't happen.
Generation is not the problem. Transmission is. This is an idea similar to inductive charging. Which seems really cool until you find out about the materials and losses involved. You immediately want to go right back to wires.
sendler2112 said:This is an idea similar to inductive charging.
For earthbound applications, a large-area 10 km diameter receiving array allows large total power levels to be used while operating at the low power density suggested for human electromagnetic exposure safety. A human safe power density of 1 mW/cm2 distributed across a 10 km diameter area corresponds to 750 megawatts total power level. This is the power level found in many modern electric power plants.
Which won't work in this case. A microwave link at 50% efficiency from orbit to Earth wins over an impossible wired link.sendler2112 said:Generation is not the problem. Transmission is. This is an idea similar to inductive charging. Which seems really cool until you find out about the materials and losses involved. You immediately want to go right back to wires.
sendler2112 said:A GW orbiting farm needs a 1 km2 transmitter array. i wonder what the cross section and mass of the wires would be to carry a GW. The ground array is 10 km2. Would humans need to be there to assemble it?
Which, for cost reasons are only used for long distance , interstate type, transmissions , and are uneconomical for a typical state grid network.cricketo said:As for line losses, the problem has been significantly reduced with (ultra)high voltage DC transmission lines.
Hillhater said:Which, for cost reasons are only used for long distance , interstate type, transmissions , and are uneconomical for a typical state grid network.
cricketo said:Hillhater said:Which, for cost reasons are only used for long distance , interstate type, transmissions , and are uneconomical for a typical state grid network.
Would be interesting to know what do you consider "cost reasons" in this case. There is nothing inherently expensive about DC transmission. DC has not been widely used due to difficulties and inefficiencies in voltage conversions, unlike AC. That was before solid-state devices were developed that make it easy and practical to work with DC. Now the only obstacle is the prevalence of AC systems, but when talking about new types of grids and power systems DC is a fair game.
Hillhater said:A HVDC substation costs around 190 Million Euros as compared to a HV AC substation at around 60 Million Euros.
This is a reason why HVDC is usually reserved for distances over 1,600 kM. Or where coupling different frequency systems ( 50 and 60 Hz for example)
HVDC does reduce line losses by 4% or so. But is only cost effective at voltages of 500 kV to 1000 kV. Very expensive components at those voltages.
Well, that 1km2 array would be comprised of thousands of synchronized magnetrons, each running at ~250kW or so. So each node would have to carry that 250kW.sendler2112 said:We have the rockets. We could try it. A GW orbiting farm needs a 1 km2 transmitter array. i wonder what the cross section and mass of the wires would be to carry a GW.
Odd question. Of course they would.The ground array is 10 km2. Would humans need to be there to assemble it?
And the only reason for the difference is semiconductor and control costs. The heavy metal (transformers, powerlines, breakers) are almost identical*.Hillhater said:A HVDC substation costs around 190 Million Euros as compared to a HV AC substation at around 60 Million Euros.
Yep. And long distance transmission is a great way to start. Put in a line from Phoenix to Texas, so Phoenix can help Texas deal with its 7-8pm peak load. (Sun will still be up in Phoenix.) Then put one from Texas to Atlanta - same effect. Then as controllers/inverters/rectifiers get cheaper, put substations along the way to let smaller cities benefit as well.This is a reason why HVDC is usually reserved for distances over 1,600 kM. Or where coupling different frequency systems ( 50 and 60 Hz for example) HVDC does reduce line losses by 4% or so. But is only cost effective at voltages of 500 kV to 1000 kV. Very expensive components at those voltages.
billvon said:Well, that 1km2 array would be comprised of thousands of synchronized magnetrons, each running at ~250kW or so. So each node would have to carry that 250kW.
Well, in the example I gave, ten BFR launches to LEO, then a tug to get it out to geostationary orbit - that would give you 1GW.sendler2112 said:So thousands of rocket flights (to geostationary altitude?)
If you could install that 4GW around the world and link them all with HVDC transmission - yes. But I don't know that that would be cheaper.to install super high tech 1GW. Wouldn't it just be much cheaper and less energetic to just install 4GW of cheap nameplate on the ground?
