Ok, greetings from Greece!
I am a happy owner of the TSDZ2 750W too!
I need some simple advice:
What settings should I change to optimize the power and how?
My bike is a 700c trekking and i use it to commute.
48V 10,4AH Battery.
I do the 30km daily comute and it is almost 50% down.
Right now, I use the out-of-the-box default settings and mostly do pedal-assisted commuting.
I would like to remove the 25kph limit and provide a little more power than the default (if possible)
I read somewhere that I can set the max Amper?
Is this true?
Any recommendations will be highly appreciated!
